Technical Divco wheels
Discussion in 'Traditional Hot Rods' started by markjaramillo, Dec 9, 2017.
  1. MarcA
    MarcA
    There was a set for sale a couple months ago with tires mounted in the cl***ifieds.
  2. I know it's not "traditional" to be concerned with this...... but what do these wheels weigh?
  3. 1lucky1
    1lucky1
    from Morgan NJ
    Got mine today,They are well worth the money,Lucky
    MarcA likes this.
  4. rust&patina
    rust&patina
    around 30 lbs. each...
  5. neverdun
    neverdun
    I got mine last week. Very nice. Powder coated satin black. Now for the tires....
  6. Stovebolt
    Stovebolt
    I got the same quote from Amanda via email.
    boy, the prices change regularly enough to send your head into a bit of a spin.
  7. neverdun
    neverdun
    I'm guessing that all the orders around Christmas was the reason for the increase.
  8. Malcolm
    Malcolm
    from Nebraska
    I placed an order for a pair of wheels on Dec. 28th and hadn't heard a word from E-STOPP. I decided to email them yesterday (01/09/2018) to check on status. Within a few hours I had an email with tracking numbers.
    So, if any of you ordered and haven't heard anything, you might want to check with them for an update.
    I'm not sure why it took me asking for an update to get them shipped, but at least they're on the way.
  9. I picked up a set locally at the factory last week 5x5.5 bolt circle.
    Very Nice!!
    ** Other bolt patterns available.
  10. ls1yj
    ls1yj
    from Kentucky
    Hey guys... I picked up a set of 18x5’s for the rear, and found some thing I wanted to run by you all that have purchased these wheels:
    The hole in center of wheel checks 3.100”, and the hub on my axle is 3.060, which fits my drum ok. I am ***uming that the lugnuts are designed to take all the load? Because having .040 thou clearance puts all the lug bolts in shear... let me know if any of you see this on your wheels
    Atwater Mike likes this.
  11. alchemy
    alchemy
    Isly, up until modern times, all wheels were held on with just the lugs/studs. Fitting tight to the hub center was never even dreamed up yet. I don't know how any wheel manufacturer could make them to fit the hundreds of different hub diameters out there nowadays on these hot rods?
    Max Gearhead, neverdun and ls1yj like this.
  12. ls1yj
    ls1yj
    from Kentucky
    Thanks for reply... I know I’m over-thinking it, but I design components every day for living, and I try not to side-load the fasteners, and prefer a key/hub or other similar feature to take majority of the load, and fasteners only hold it down... I’ll quit obsessing over it...;)
  13. alchemy
    alchemy
    If you have a nice smooth side of the hub on your axle sticking out (we don't know what kind of axle you are using), you could turn a collar and press it into the wheel to take up the space. Might want to bore the wheel's hole bigger first to make sure the collar is thick enough.
    Atwater Mike and ls1yj like this.
  14. ls1yj
    ls1yj
    from Kentucky
    Alchemy,
    I was already thinking of it... I was looking online for stainless bearing sleeves, for repairing bad races, pockets, etc... they are Dutchman axles, and have a nice 1/2” tall hub turned in center. Thanks for advice
  15. Randysbelvedere
    Randysbelvedere
    from Toronto
    Mounted a 255/70r18 Kelly radial on today just to get a look. It’ll do while I save up for Coker’s. Hope to get a pic on the car soon.
    ls1yj and WhoDoYouFink like this.
  16. A Boner
    A Boner
    Looks good.....what load range are thoses Kelly tires? What Coker tires are you thinking of getting?
  17. banjorear
    banjorear
    I agree. Not sure I would change them.
  18. gimpyshotrods
    gimpyshotrods
    They look good, but if they are a light truck (LT) tire, they might have sidewalls that have so many plies that they are too stiff for a light vehicle, even at a low pressure.
  19. gimpyshotrods
    gimpyshotrods
    On checking, that appears to be a Kelly Safari Signature tire. It is a light truck tire, and carries a load rating of SL, or 2,469lbs, per tire.
    That is more than my entire Model A weighs.
  20. Randysbelvedere
    Randysbelvedere
    from Toronto
    You’ve got the specs right, but that’s at 50lbs of pressure. The sidewalls are pretty soft and only two ply. I think with the large diameter and lower pressure they’ll be okay.
    I’ll let you know when the snow clears...
    ls1yj and gimpyshotrods like this.
  21. flatheadpete
    flatheadpete
    from Burton, MI
    The 'SL' stands for 'standard load'. It's not a heavy duty truck tire but it is made for a larger vehicle. Drop the air pressure to make it ride right and it'll be fine. Hell on something that light I'd start about 20psi and adjust from there.
    And, btw, not a bad looking tire at all. I'd run it!
    Randysbelvedere likes this.
  22. willys1330
    willys1330
    What tires is everyone going to run on thease wheels??
  23. Tin Lizzie
    Tin Lizzie
    from Ohio
    Anyone else having trouble getting on their website ?
  24. brady1929
    brady1929
  25. neverdun
    neverdun
    Call them, I posted their number.
  26. Tin Lizzie
    Tin Lizzie
    from Ohio
  27. Tin Lizzie
    Tin Lizzie
    from Ohio
    Anyone else bought any wheels lately ?
  28. A Boner
    A Boner
  29. brady1929
    brady1929
    I am watching the price on these. Hopefully they will go on sale again soon.
  30. junk yard kid
    junk yard kid
    I regret not getting a set when they were on sale
