Projects 1931 Roadster AV8 Project
Discussion in 'Traditional Hot Rods' started by mit311, Nov 29, 2017.
  1. sloppy jalopies
    sloppy jalopies
    you would have to make the "screen and filter" tubes,
    then cap them with aluminum fence post tops/caps... they come anywhere from crude to fancy. HIH...
  2. walter
    walter
  3. Stogy
    Stogy
    Mit these are aluminum elbows that have a 3"OD doesn't say what ID...I think the carb opening is 2 5/8" I have photoshopped the 9499 elbows on. You would have to run a shim inside to take up any ID issues if these would work at all. You could run the same height if you rotated each elbow slightly and you could run bugscreens at fwd openings as I have depicted. Hope this gives you a better idea. The height of the aft scoop is very slightly under hood scrub and may require a short straight section due to height above fwd elbow.
    Version 1
    https://www.spectreperformance.com/search/product.aspx?prod=9499#customer_feedback
    This version has some straight pipe added on aft elbow to raise it above fwd elbow.
    It also sports bug screens at fwd openings.
    Version 2
    https://www.spectreperformance.com/search/product.aspx?prod=8698
    31hotrodguy and Vanness like this.
  4. mit311
    mit311
    Thanks! I will look into that.
    Stogy likes this.
  5. mit311
    mit311
    Got the fuel pump stand sorted out. Sectioned the back off to clear the stock firewall, affixed a permanent oil filler tube. Still enough room for the stock fuel pump rod to engage the fuel pump!
    brEad, bct, heavydumper and 5 others like this.
  6. hombres ruin
    hombres ruin
    Amazing
  7. mit311
    mit311
    Some detail work complete. Wiring harnesses soldered and done, throttle linkage in, front cross bar/license plate bracket is complete, and I found my carb air intakes. The stack up of carbs, air intakes, coil, fuel pump stand, oil filler, etc., all fit, but barely.
    Cut down brake shaft used for front cross bar/plate holder:
    "Air cleaners." I was looking for simple unfiltered elbows as prewar/wartime generally filtered air cleaners did not exist yet except the thickstun or stock. These are elbows from the stock Model A zenith air filters adapted for strombergs:
    brEad, 31hotrodguy, Stogy and 6 others like this.
  8. ct1932ford
    ct1932ford
    Love this Roadster. It Looks Great! :cool:
  9. 117harv
    117harv
  10. waxhead
    waxhead
    from West Oz
    I like some of the little individual touches you are adding, nice work.
  11. 62pan
    62pan
    Outstanding !!!!
  12. Krash
    Krash
    from Cleveland
    Man, love this thing!
  13. mit311
    mit311
    Got the dash wired up. Was able to include an on/off switch on the 2gauge cluster for the dash light/gauge lights. At this point I just need upholstery and exhaust. Got a set of drive shaft pipes and flange plugs for what I guess you can call "side pipes."
    FB2A5A5C-D5DC-485A-8A05-22823A4CCDE3.jpeg AFB93D7E-3C14-4E43-806E-D989EEE8E05E.jpeg F682FCEB-86B1-4E00-B656-7AC5E3D738C4.jpeg AD8BD32F-C4B6-4A50-B6A9-599DF0442135.jpeg
    brEad and Stogy like this.
  14. sloppy jalopies
    sloppy jalopies
    love the model A emergency brake cross shaft as the front spreader bar... yup !
    Nailhead A-V8 likes this.
  15. mit311
    mit311
  16. Stogy
    Stogy
    Wow...great job there @mit311...looks aces...;)
  17. mit311
    mit311
    Just a note; I learned the hard way that macs windshield gl*** only fits ORIGINAL frames. I also learned that it is very hard to buy a new frame with holes for finger pulls. Speedway and snyders are completely free of holes. Brattons sell them with finger pull holes AND snap holes, but they are out of stock with no date for resupply. CW Moss in Orange, CA had one in stock with holes for finger pulls.
    New gl*** has been cut, will install in a week. At that point, just need to have the cushions and hip panels upholstered.
    Stogy likes this.
  18. triumph 1
    triumph 1
  19. Vanness
    Vanness
    Good point. I ordered mine from Brattons and kept waiting... finally 3 months later it showed up w gl***. It was one of the last things I was waiting for.
  20. louisb
    louisb
    Looking good!
  21. mit311
    mit311
    Dannerr, brEad, lodaddyo and 6 others like this.
  22. sloppy jalopies
    sloppy jalopies
    what about finding the right size tail light bezels and attach your screens to it... HIH.
  23. mit311
    mit311
  24. mit311
    mit311
  25. Stogy
    Stogy
    Niiiicccce...hey Mit...What dia. are your rad support bars 5/16"...3/8" just curious I hope your out making noise with that...still some summer left...;)
    48fordnut likes this.
  26. mit311
    mit311
    I don't have access to the car at present but they are stock brand new from macs.
    Stogy likes this.
  27. RidingMechanic
    RidingMechanic
    from Cincinnati
    Wow, this is easily one of my favorite A's ever. Its just the right amount of of original and hot rod.
  28. mit311
    mit311
    Thanks much! I had originally intended this to be something of a "daily driver lakes racer," but the paint and interior is too nice for that. So it's kind of a hybrid I suppose. I found most if not all of the tech ideas here on the forum which was a HUGE help. The most challenging thing to find was info on moving the steering box outboard of the frame.
    A little old lady in a minivan gave me a huge thumbs up the other day and that's what I want to see!
    brEad, louisb and Stogy like this.
  29. louisb
    louisb
    Funny how that happens. :D
    —louis
    barrnone50 likes this.
  30. ghalperin
    ghalperin
    I know this thread is from last year. I really like the style of your car. My 29 banger is similar, but I’ve been collecting AV8 parts. I really want to keep the mechanical brakes and positive ground 6V. How are your ****** mounts holding up? Do you have any better photos of the mounts?
