I purchased my 31 Tudor about 11 years ago. Sold it after a short while of having it on the road. Was a boxed frame with a suicide front end, coil overs on the rear. Short story I bought it back 2 years ago. More of a "rat rod". New plans are totally traditional hotrod rod build. 32 frame, 36 radius rods, 40 rear spring, front will be a 4 inch 36 dropped axle and 37 spindles done by Okie Joe, flat crossmember, f1 shock mounts, reverse eyed spring. 40 hubs with 56 f250 brakes with Buick drums.
Get at it! I need to get over there. Gonna be another awesome build!! Sent from my iPhone using H.A.M.B.
Thanks Grant! Made a template of the bottom of the car. I'm looking for a low riding ch***is. I really like the Max Built coupe. I've been searching for the ch***is pics. Here's my debate. Do I widen the rails to follow the contour then pinch them front and rear?
I tried to see the car you are referring to and found a few. Definitely a sweet *** ride!!! The thread here on the HAMB is useless because all of the photos were thru photobucket and are not available[emoji53] I'd love to see them but doesn't look like it'll happen. Anyway, in one pic I did see I noticed the rear track bar is in the spring mount. Where is the spring?? I saw shocks but no spring or provisions for one??? Sent from my iPhone using H.A.M.B.
Picked up a few parts this weekend. Offy 6x2 and a nice little sbc bumpstick Sent from my SM-T350 using The H.A.M.B. mobile app
Also picked up some 40 hubs I'm needing for my 55 F250 BUICK drums Sent from my SM-T350 using The H.A.M.B. mobile app
Haven't posted in a while. Ch***is is slowly coming together axle from Joe's Speed Shop with spindles Sent from my SM-G950U using The H.A.M.B. mobile app
Wishbones mounted using the through the frame tie rod mounts from welderseries. Sent from my SM-G950U using The H.A.M.B. mobile app
I liked the steering set up on a article i read in hot rod magazine i believe. How to fabricate a ground hugging 32 ch***is. Only difference is I'm going spring over the axle set up rather the spring behind. Sent from my SM-G950U using The H.A.M.B. mobile app
Its a vega box on its side. I do realize the possibility of bump steer and i am in know way wanting to start a discussion about it. Sent from my SM-G950U using The H.A.M.B. mobile app
Picked up these beauties the other day 33-34 17 inch wires Sent from my SM-G950U using The H.A.M.B. mobile app
I finally got it off the table. I have a roller. Gotta finish up a few things yet. But the ride height is pretty much right on. Sent from my SM-G950U using The H.A.M.B. mobile app
Started bending up my headlamp brackets. Couldn't finish though. Ran out of gas[emoji853]. Need to bend it more away from the grill yet Sent from my SM-G950U using The H.A.M.B. mobile app
