Projects 31 "Two Timer" Sedan
Discussion in 'Traditional Hot Rods' started by ty johnson, Sep 7, 2017.
  1. ty johnson
    ty johnson
    [​IMG] I purchased my 31 Tudor about 11 years ago. Sold it after a short while of having it on the road. Was a boxed frame with a suicide front end, coil overs on the rear. Short story I bought it back 2 years ago. More of a "rat rod".
    New plans are totally traditional hotrod rod build. 32 frame, 36 radius rods, 40 rear spring, front will be a 4 inch 36 dropped axle and 37 spindles done by Okie Joe, flat crossmember, f1 shock mounts, reverse eyed spring. 40 hubs with 56 f250 brakes with Buick drums.
    slv63 likes this.
  2. ty johnson
    ty johnson
  3. ty johnson
    ty johnson
  4. sloppy jalopies
    sloppy jalopies
    all the makinz...
    ty johnson likes this.
  5. jackalope
    jackalope
    Get at it! I need to get over there. Gonna be another awesome build!!
  6. ty johnson
    ty johnson
    Thanks Grant!
    Made a template of the bottom of the car. I'm looking for a low riding ch***is. I really like the Max Built coupe. I've been searching for the ch***is pics.
    Here's my debate. Do I widen the rails to follow the contour then pinch them front and rear? 20170909_200630.jpg 20170909_200630.jpg 20170909_200645.jpg
    Stogy likes this.
  7. jackalope
    jackalope
    I tried to see the car you are referring to and found a few. Definitely a sweet *** ride!!! The thread here on the HAMB is useless because all of the photos were thru photobucket and are not available[emoji53]
    I'd love to see them but doesn't look like it'll happen.
    Anyway, in one pic I did see I noticed the rear track bar is in the spring mount. Where is the spring?? I saw shocks but no spring or provisions for one???
  8. jackalope
    jackalope
  9. ty johnson
    ty johnson
    It's an elliptical setup
  10. jackalope
    jackalope
    I saw that in the link you texted me. Interesting!! Very cool.
  11. ty johnson
    ty johnson
    Picked up a few parts this weekend. Offy 6x2 and a nice little sbc bumpstick
    Sent from my SM-T350 using The H.A.M.B. mobile app
    Tim_with_a_T and jackalope like this.
  12. ty johnson
    ty johnson
    Also picked up some 40 hubs I'm needing for my 55 F250 BUICK drums
    jackalope likes this.
  13. choptop40
    choptop40
    That's gonna be sweet....
  14. ty johnson
    ty johnson
    Haven't posted in a while. Ch***is is slowly coming together [​IMG] axle from Joe's Speed Shop with spindles
    Sent from my SM-G950U using The H.A.M.B. mobile app
  15. ty johnson
    ty johnson
    Wishbones mounted using the through the frame tie rod mounts from welderseries. [​IMG][​IMG][​IMG]
    WelderSeries and jackalope like this.
  16. ty johnson
    ty johnson
  17. jackalope
    jackalope
    Awesome. Keep it up!
  18. ty johnson
    ty johnson
    I liked the steering set up on a article i read in hot rod magazine i believe. How to fabricate a ground hugging 32 ch***is. Only difference is I'm going spring over the axle set up rather the spring behind. [​IMG][​IMG][​IMG]
    spurgeonforge likes this.
  19. ty johnson
    ty johnson
    Its a vega box on its side. I do realize the possibility of bump steer and i am in know way wanting to start a discussion about it.
  20. ty johnson
    ty johnson
  21. ty johnson
    ty johnson
    Picked up these beauties the other day 33-34 17 inch wires [​IMG]
    spurgeonforge and jackalope like this.
  22. 392
    392
    Nice work.
  23. jackalope
    jackalope
    I’m pumped to get out there and see it!
  24. ty johnson
    ty johnson
    I finally got it off the table. I have a roller. Gotta finish up a few things yet. But the ride height is pretty much right on. [​IMG][​IMG][​IMG]
  25. ty johnson
    ty johnson
    Started bending up my headlamp brackets. Couldn't finish though. Ran out of gas[emoji853]. Need to bend it more away from the grill yet[​IMG][​IMG][​IMG]
  26. jackalope
    jackalope
    Lookin rad! Keep it up
  27. ty johnson
    ty johnson
