Hot Rods Fiberglass body
Discussion in 'The Hokey Ass Message Board' started by vbarker, Jan 23, 2018.
  1. vbarker
    vbarker
    This will be my first HR built and have questions:
    Has anyone use the Spirit 1927 roadster body? If so would like to hear the Pro./Con on this.
    My plan is to install it on a 1931 Model A frame with A running gears. Mayb hop up the 4 Banger or go with a Flat head eight, OR a cool hop up Flat head mopar 6 cylinder,later down the road.
    What is your thoughts.
    Vern B.
    Donuts & Peelouts likes this.
  2. dan31
    dan31
    Got any pics of that body?
  3. You may be in over your head of this is going to be your first build. As I recall those are a fiber gl*** shells. Don't even have working doors or a deck lid.
    I could be wrong.
  4. Frames
    Frames
    this was a very rough shell. layed up by an
    amature. no floor. i bought it at a local swap meet for $700.00. lot's of primer and block sanding. i cut out the rear deck and made a Dzused on deck lid. the doors don't open. I have never burned my legs on the side pipes. If the ROADSTER 1927. 7-17-14 012.jpg ROADSTER 1927. 7-17-14 013.jpg price is right, go for it.
    AHotRod, rooman, dan31 and 6 others like this.
  5. You build some cool stuff Frames
    loudbang and gimpyshotrods like this.
  6. mountainman2
    mountainman2
    You are. Can be had in various stages of completion.
    Check their website...... spiritcars.com
  7. Kerrynzl
    Kerrynzl
    You sir, have got the profile correct on this build [probably the best stance I've seen on a T Roadster]
    gimpyshotrods likes this.
  8. vbarker
    vbarker
  9. vbarker
    vbarker
    go to www.spirit.com
  10. Torana68
    Torana68
    from Australia
    loudbang and Donuts & Peelouts like this.
  11. 022.jpg 023.jpg Here's one we built in the 80's. It started with just a bare bones 27 body from Speedway Motors. A boxed Model A frame, dropped axle, with split bones, { front and rear} and a junkyard SBC. The seat folded forwards to fill the gas tank. Just a hop in and out, with no doors or deck lid.:rolleyes: I used 3/4'' marine plywood to gl*** in the floor. It had 36 Ford wire wheels, stock fronts with motor cycle tires, and widen rears with Firestone dirt tracks. It was a very CHEAP, and FUN little roadster. :) Ron...
    AHotRod and Nailhead Jason like this.
  12. Turbo26T
    Turbo26T
    When I built the roadster ,I started with just a body shell . The doors supplied were just skins. I ended up building a DOM tubing body frame , building complete doors, fabricating the hinges , building a complete new floorpan and reworking the dash.
    But , I learned a ton about working with fibergl***... It's not a scary as you would think and I got some great advice from a pro..To me ,a great part of any project is the skills you learn as you build it.
    Go for it !!!
  13. Hey vbarker...where are you located? I ask because I know of a pretty cool original steel track T roadster project that a non computer savy friend of mine has (in Oregon) that might fit your bill without having to get into all that itchy stuff (frp). Send me a conversation if you'd like to hear more.
  14. vbarker
    vbarker
    I'm from N/W pa but dwollam on the HAMB may be interest he's in Madis OR.
  15. dwollam
    dwollam
    Thanks Vern but I don't need another project! I chat with Vern every Tuesday night and have been offering him my guidance and advice on this project. He has been researching and exploring the options and asking lots of questions. I've been pushing him towards a traditional build, although 'gl***, since he will most likely be using the A banger engine. The Spiritcars body looks like a good one. He can handle the job! Vern is not new to old cars, just hot rods.
    Build on Vern!
    Dave
    Madras Oregon
