Projects Something from nothing. 29 roadster build
Discussion in 'Traditional Hot Rods' started by wheeldog57, Oct 8, 2016.
  1. mike bowling
    mike bowling
    I like jello shots when I get hurt.................
    brEad, Jet96, Mikel50 and 1 other person like this.
  2. 42˚18'N 83˚09'W
    42˚18'N 83˚09'W
    Dr. Mike's prescription works for me thanks!
    mike bowling and chryslerfan55 like this.
  3. wheeldog57
    wheeldog57
    Been working a lot lately but was able to sneak out early today(don't tell).
    Welded out the trunk skin, I have a hard time welding sheet metal- flop I am not.
    More very soon. Once I get rolling, I tend to keep rolling. . .[​IMG][​IMG][​IMG]see the wave on the left of weld, maybe I was going too fast
    Sent from my E6810 using The H.A.M.B. mobile app
  4. sloppy jalopies
    sloppy jalopies
    Grinding will worp the sheetmetal every bit a bad as welding... you should bounce around grinding just like when you welded it...
    I WAS WRONG, FLOP HAS STRAIGHTENED ME OUT...
    The welding and grinding shrink the steel, pulling the metal inward, in a perfect world you should weld a spot every inch, then flip it over and weld a spot next to each of the outside welds...
    the same process for grinding wouldn't hurt...HIH.
    chryslerfan55 and wheeldog57 like this.
  5. Eh, try the hammer Ron. Whenever I overheated the metal, it just shrunk the area. Nothing a hammer and dolly couldn’t fix- sometimes five minutes with a three pound makes it look a lot better!
  6. Flop
    Flop
    Science isn’t on your side in that one . More starts and stops equal more shrinks in one area . Weld as far as you can . Tight and uniform gaps with perfect panel alignment are going to eliminate a lot of your warp problems .
  7. Flop
    Flop
  8. wheeldog57
    wheeldog57
    Thanx for the tip, I always jump around and let it cool but. . . Not anymore.
  9. sloppy jalopies
    sloppy jalopies
    flop, is that with mig and tig ? if mig I will try some Wednesday...
  10. Flop
    Flop
    Tig I haven’t had a mig welder in the shop in 5 years or so
  11. sloppy jalopies
    sloppy jalopies
    can I run a long weld with a mig... ?
  12. wheeldog57
    wheeldog57
    I watched Mike Casey weld two razor blades together with a tig. He then ran a long bead on a quarter panel patch. Heat control is key, perfect panel alignment is key, cleanliness is key, knowledge is key. That's a lot of keys!
  13. wheeldog57
    wheeldog57
  14. sloppy jalopies
    sloppy jalopies
    Tried to run a continuous bead like flop says...
    I'm sure running a continuous bead works for flop, but with the thin tin I use it doesn't happen... got to be a spot here, spot there, then connect them...
    chryslerfan55 and biggeorge like this.
  15. wheeldog57
    wheeldog57
    I am going to run this Offy intake and Strombergs, the air cleaners are from Jere Sheehan's 34 roadster[​IMG]working on paperwork for the car so with any luck it'll be on the road this early spring
  16. wheeldog57
    wheeldog57
  17. wheeldog57
    wheeldog57
    I pulled the back end off to straighten out a few things I threw together last year.[​IMG][​IMG][​IMG]
  18. wheeldog57
    wheeldog57
    My homemade subrail setup (1x1 tube) was too tall to mount the quarter properly so I cut and spliced[​IMG][​IMG][​IMG]
  19. mike bowling
    mike bowling
    looks like wire brush and paint time? You brought some Joisey home with you!
  20. toreadorxlt
    toreadorxlt
    from Nashua, NH
    ronnie i sent you a text.. give me a shout if you want. I guess i didnt realize you had the quarters off the car, bring them up any night after work and we can buzz em through the planisher, won't take long.
  21. wheeldog57
    wheeldog57
  22. wheeldog57
    wheeldog57
    [​IMG][​IMG]the sub rails and frame now in chassis black.
    Got garage up to 43 degrees tonite- paint will dry in a couple days.
  23. mike bowling
    mike bowling
    protect your investment! Looks great. Can't wait to see the rear quarters ironed out.
  24. wheeldog57
    wheeldog57
    Toreadorxlt helped me out tonight, he ran the left quarter through his handmade planishing hammer [emoji375]. Steve then hammer and dollied a nasty spot behind the brace. [​IMG][​IMG][​IMG]
    Pictures don't do it justice. This thing was killed (some by me) and Steve whipped it into shape. Thank bud.
  25. wheeldog57
    wheeldog57
    So, the quarters we're mounted too high in the rear. I thought I knew what I was doing. . .
    With adjustments and tweaks- both doors open now. Kind of a big deal[​IMG][​IMG]
  26. wheeldog57
    wheeldog57
    The rear subrail mount needs to be replaced. I have a plan- just need to execute[​IMG][​IMG]
  27. chryslerfan55 likes this.
  28. wheeldog57
    wheeldog57
    Got some great news today; the roadster is now "on the road". Going to be tough to keep from driving it in the salt and snow
    Mikel50, patmanta and greaser like this.
  29. wheeldog57
    wheeldog57
    I got a 4x4 sheet of blah blah blah gauge sheet metal and bent it up in the brake, cut off the old sub rail mount and welded these on. They will have gussets tomorrow. I measured a million times but I still welded them on a little crooked. The inner quarter supports will be bolted on these too, that'll stiffen it up a bit. [​IMG][​IMG]
  30. wheeldog57
    wheeldog57
    Concentrated on left side today then got some done on pass side[​IMG][​IMG][​IMG]
