Projects 1933/34 ford roadster project
Discussion in 'Traditional Hot Rods' started by Elvis100, Jan 13, 2018.
  1. Very nice work. Keep the pics coming please as they will be very helpful when (if I ever?) get started on my phaeton!
    loudbang and Elvis100 like this.
  2. Elvis100
    Elvis100
    [​IMG][​IMG]
    Finished up the wood for both sets of doors. Still need to do all the screws, final sanding and I think I will stain them. That will all wait until after the rest of the metal work.
    nunattax, Stogy, Atwater Mike and 7 others like this.
  3. Elvis100
    Elvis100
    Thanks, will do
    Stogy and loudbang like this.
  4. Elvis100
    Elvis100
    Thanks, I’m still learning myself
  5. Vanness
    Vanness
    Looks great! Can you make an error, break something, or have to do something twice; so we all can feel better. That’s how most of our projects go...the wood work is looking great! What was the production numbers for those roadsters?
    Stogy, loudbang and Elvis100 like this.
  6. Elvis100
    Elvis100
    Thanks, here is a good thread with the production numbers
    https://www.fordbarn.com/forum/showthread.php?t=58077&showall=1
  7. Vanness
    Vanness
    Low production for sure. That’s cool.
  8. Gary Addcox
    Gary Addcox
    DAMN, that purple baby has "the look".
    Elvis100, loudbang and Cyclone Kevin like this.
  9. Elvis100
    Elvis100
    Just got back from a week in California picking up the rear clip and some other parts.
  10. Elvis100
    Elvis100
    [​IMG][​IMG]
    Worked on replacing the d-nuts in the door latch beds and finished the one latch bed I had to make.
  11. uncle buck
    uncle buck
    Did you get lucky enough to make a stop at the GNRS or Turlock swap meet on your trip?
  12. Elvis100
    Elvis100
    I did, didn’t find anything I needed. I did get a super nice steering box, column and wheel off Craig’s list in Tracy on the way back.
    loudbang and heavydumper like this.
  13. Elvis100
    Elvis100
    [​IMG][​IMG]
    Spent the last day and a half drilling 34 holes (8 threaded) in the b-pillar brackets. I am using reproduction castings from Flathead Ted in New Zealand. It would have been a few hours quicker... but I broke a tap of and spent a couple hours chipping it out.
    Stogy, tb33anda3rd, loudbang and 2 others like this.
  14. Angry Frenchman
    Angry Frenchman
    Amazing! The ability to find the parts and then ***emble it!
    Sent from my LGMS210 using The H.A.M.B. mobile app
  15. Elvis100
    Elvis100
  16. This is awesome, watching!
  17. Elvis100
    Elvis100
    Off:)
  18. Are the hole locations marked on those and just not drilled?
  19. Elvis100
    Elvis100
    No, I was lucky to have a loaner pair of originals to map the holes. They were from a channeled car had been hacked up. That combined with The drawings Ed Solari sent me a while back were immensely helpful. Most of the info from Ed is available on the following webpage.
    http://www.the34fordroadster.com/the-build/page/9/
  20. Elvis100
    Elvis100
    [​IMG][​IMG][​IMG][​IMG]
    Worked on repairing the original drivers door. About 2 inches between the hinges and several inches in the bottom front area are like lace. I replaced the metal between the hinges and the bottom half of the edge tin. There were also about 20 pin holes that I was able to weld up.
    Stogy, kidcampbell71, v8paul and 6 others like this.
  21. Elvis100
    Elvis100
    [​IMG][​IMG]
    Replaced the hinge bed and other repairs to one of the p***enger doors.
  22. Elvis100
    Elvis100
    Worked on the “new” drivers door. Received the door edge tins from McPhearson Auto. Steve and his team did a great job on these. [​IMG]
    There was a bit of fitting and t******* of the edges to set them up for the wooden structure and latch.[​IMG]
    Should be able to install the screws tomorrow[​IMG]
    lewk, brEad, Stogy and 8 others like this.
  23. Squablow
    Squablow
    That door is impressive, a difficult mix of metalwork and cabinetry?! Well done.
    Stogy, Elvis100 and loudbang like this.
  24. el Roach
    el Roach
    Wow great work!!!
    Elvis100 likes this.
  25. 392
    392
    Very nice work. Kick *** build.
  26. Elvis100
    Elvis100
    Here is how the wooden structure is attached to the skin on the bottom. There is a 28 1/2 inch X 2 inch metal strip screwed from behind
    Stogy and BigDTexasKid like this.
  27. Elvis100
    Elvis100
    Got the screws installed a final fit check on the second door
    Checking fit and function of the door handle. These are one year only handles for roadster and phaeton.
    [​IMG][​IMG][​IMG]
    Doing the repair on the third door, fitting and welding the edge tins.
    Bigdog5, Stogy, kidcampbell71 and 3 others like this.
  28. AngleDrive
    AngleDrive
    from Florida
    Something new? A three door Ford roadster?
    kidcampbell71 likes this.
  29. Elvis100
    Elvis100
    Thanks, it’s been a lot of fun
  30. Elvis100
    Elvis100
    el Roach likes this.
