Technical Tri Pak troubles
Discussion in 'Traditional Hot Rods' started by carnut62, Jan 27, 2018.
  1. carnut62
    carnut62
    Hi, I’m new to the site and I’m building a 1932 Chev Cabriolet. I’m doing it in traditional style. It has a 66 327/350 combo. I recently found a tri pak manifold with Rochester cars. I m having issues with alternator mounting now, as the front carb and filler neck are now in the way. I tried the driver side like mount but it won’t clear my steering linkage. Also we have found that the distributor cap rests on the rear carb slightly. Any one that is experienced with this situation? Thanks Darrell
  2. jimmy six
    jimmy six
    Small cap dist the one before the style you have, usually aftermarket or 55-56. Mount the alt up on top right or left. And run a hood. Good luck. Hotrodding ain't ez
    rjones35 likes this.
  3. carnut62
    carnut62
    I’ll be running the hood too only with no sides. One thing that’s not helping is the engine has no accessories holes in the front of the heads.
  4. carnut62
    carnut62
    I’ll get some better pics tomorrow. Standard Chev mounts.
  5. brigrat
    brigrat
    from Wa.St.
    Your running SBC side type motor mounts? That would mean your drivers side, lower front mounting holes are not being used? If not you can mount small Honda, fork truck type Alt. in that location? Forget the GM standard size Alt.
    You can drill mounting holes into those heads you know..............................
  6. Sheep Dip
    Sheep Dip
    from Central Ca
    If your just running the basics with no real amperage draw I have seen the little alternators from a lawn tractor mounted low on the motor, have no idea what amperage they were, or what exactly it was off of but have seen them.
  7. carnut62
    carnut62
    Never new there was such a setup. I’ll have to look in to it. Thanks
    Looks like I’ll havevto explore a few different options. I know powermaster makes a small body but it’s pricey
  8. quicksilverart46
    quicksilverart46
    I agree. There are many bracket kits to mount a small Honda Or Chevy S-10 alternator at the lower front of the engine . Much cleaner than the OEM TOP MOUNT!
  9. carnut62
    carnut62
    Yeah I want it out of the way so the engine is the focus not accessories......
  10. brigrat
    brigrat
    from Wa.St.
    Here's what I run in most cars/trucks that don't require a lot of Amps. This one puts out 70 I believe. Looks like your running a short water pump?. The bracket in pic is drilled for a BBC but the SBC looks the same................................
    mad mikey and flynbrian48 like this.
  11. clem
    clem
    7CEC60D6-122B-4F96-8F7E-40FAD6396953.jpeg DE6EEB9F-D9F0-463F-8CB6-6E139A86F1B1.jpeg Or you could go with the big ugly original style alterator.
    Tickety Boo likes this.
  12. carnut62
    carnut62
  13. brigrat
    brigrat
    from Wa.St.
    Pinion mounted alternator? A couple obvious draw backs!
  14. carnut62
    carnut62
    Yes a friend runs that on his Ford. I’ve got a 10 bolt diff so haven’t see one on a Chev diff
    rtp likes this.
  15. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^^^^^^ Make your own brackets^^^^^^^^^^^^^^^^^^^^
  16. carnut62
    carnut62
    Might come to that.....
  17. DDDenny
    This is a full size alt. from Ford Motorsports, was tight but rectified it in short order.
    None of it came out of a kit either.
  18. brigrat
    brigrat
    from Wa.St.
    2 words, Race Mate, or put together one word....................................
  19. chevyfordman
    chevyfordman
    If you can use a long water pump, I mounted an alt. off a junked out Toyota Tercel sitting out in the field and mounted it to the engine mount holes in the front of the block. I had to cut out an L shaped block of aluminum for the alt. mount and fabricated an adjuster. DSCN2651.JPG
  20. flynbrian48
    flynbrian48
    24129844_10215524199840757_4440013479773916511_n.jpg Looks like you have an HEI dizzy, use a small base aftermarket HEI or original points one, problem one solved. I don't have a photo of the low left side alternator mount, but it's in there. I think the mount was around $30, chrome, I was going to make one, it's very simple, but for that, I couldn't have done it myself, let alone have it chromed. Since I had that shiny bit I put a chrome alternator on as well. Mounts to the engine mount holes, cleared everything, looks pretty aside from the overspray...
  21. flynbrian48
    flynbrian48
  22. The little fork truck alternators are great on simple hot rods.
    With a little digging you can get them easy enough and very reasonable.
    Or you can pay too much for the "race alternator" in an easy to find kit with great tech support. They've also got the brackets and mounting all figured out for you it's TOO easy but you pay for it.
    mad mikey likes this.
  23. The racemate is pretty damn slick.
    It like the guy took apart his Harley stator and said hummmm? Wonder if this will fit on a Water pump. Very ingenious
    flynbrian48 and mad mikey like this.
  24. A generator up high in the stock location would look best. Make a bracket.
  25. Shouldn't have to make stuff to do that. Just duplicate the ram horn mounting boss.
  26. Well he will have to duplicate (make) the ram's horn bracket will he not? Unless he gets some old Hedman's already set up for that (which would be even cooler! :cool:)
    Nice Chevy by the way!
  27. manyolcars
    manyolcars
    I made this bracket to mount down low on the p***enger side
    I've never heard the term Tri Pak before
  28. Unwashed
    GM Tri power
    Mopar six pack
    Of course it's a tri pack
    egads and cactus1 like this.
  29. Here is the ‘57 283 in my ‘34 Chevy. The gen bracket is a Jitney Jake Jacobs item. (I think he made an alternator version too?) ‘57 distributer. Edelbrock C357 intake.
    I could have made something off the Fenton bosses but switched to those later.
  30. flynbrian48
    flynbrian48
    I am intrigued by your exhaust manifolds, I've never seen dual outlet, cast manifold like that. Or, am I seeing things? ;-)
    cactus1 likes this.
