Hot Rods FORD IN A FORD
Discussion in 'The Hokey Ass Message Board' started by Frames, Jun 18, 2016.
  1. Frames
    Frames
    This 1955 F1oo has been on the back burner for a loooong time. I got into building open wheel hot rods. I chopped the top 1" above the back gl***, 1" through the back gl*** and 3" below the back gl***. I did it that way to center up the back gl*** with the side window. I used the top center sheet metal from a 1956 cab. I think it is about 1/2" lower. I raised the windshield opening 1" up into the roof. I cut off the drip rail and added rod to look like 33 Ford. I love the SBC but more than that I like something different. Out comes the SBC [and the cold air induction] in goes the 312 Y-block. It is .060 over with a mild cam. I built the block hugger headers from u-bends not a SBC kit. FATHERS DAY 013.JPG FATHERS DAY 011.JPG FATHERS DAY 012.JPG FATHERS DAY 014.JPG FATHERS DAY 015.JPG
  2. 19Fordy
    19Fordy
    Very nice job. Like the way you hid the front of the engine.
  3. Texas Webb
    Texas Webb
    That's for the watch cat.Looks good,like that 312.
    Dino64 likes this.
  4. mike bowling
    mike bowling
    Henry is smiling.
  5. Dino 64
    Dino 64
    from Virginia
    Where did the grill come from ?
    Great looking y block !
    falcongeorge likes this.
  6. Jalopy Joker
    Jalopy Joker
  7. Frames
    Frames
    I made the bar and the teeth are 54 Chevy.
    Dino64 likes this.
  8. Frames
    Frames
  9. falcongeorge
    falcongeorge
    from BC
    I see traces of shopcat.:D Love the 4x2 Y-block, I was just browsing through the early '70's PHR Y-block build. You don't see that intake very often.
  10. Frames
    Frames
    That's an Edelbock 2x4 with Offy adapters. I did the same thing on a SBC Offy and a Cadillac Wieand. Most other 2x4 intakes don't have enough room.
  11. Dino 64
    Dino 64
    from Virginia
    How did those Edelbrock work out ? Are those the repo 94's ?
  12. Frames
    Frames
  13. broke hotrodder
    broke hotrodder
    from NY
    Looks good. I like the fact it won't have a chevy in it. 350's are easy, and thats ok for most, but I think thats what holds some people back. A little extra love makes it right.
    Are you putting inner the stock style inner fenders in? A friend of mine took a second set of outers. He trimmed them to make a nice transition to the inner lip of the frame, which was boxed. It was pretty slick, sorry no images.
  14. Frames
    Frames
    I built the ch***is 1990. 1-26-13 001.jpg img103.jpg img108.jpg img107.jpg img106.jpg img105.jpg img104.jpg
    kidcampbell71 likes this.
  15. Frames
    Frames
    Yes but I will make aluminum inner fender panels. the rear attachments have been installed on the firewall.
  16. Frames
    Frames
    I used a donner upper cab [ I think I paid $35.00 1989] that meant I did not have to add filler pieces everywhere. I used the center roof panel from a 1956 F100. It is about 1/2" lower. img097.jpg img099.jpg img098.jpg img100.jpg img101.jpg
    dana barlow and kidcampbell71 like this.
  17. broke hotrodder
    broke hotrodder
    from NY
    Looks like you are going without running boards. I would like to do away with them and run side pipes in there place. I see you raised the bed kick , did you modify the front to compensate at all. Going to start putting cab parts together to see the rough alignment. I don't want the front fenders to feel like they are out of whack. How much did you kick it up in the back. looks like more than 3"? Your frame is pretty slick. Do you have any images of the cab on the frame with a little more detail in relationship to the kick up?
  18. big duece
    big duece
    from kansas
    Nice work Dennis, love the chop on the cab.
  19. Frames
    Frames
    I can't get to it to measure the kick up and don't have the blue print any more but studying the first picture I would say at least 6". I will be fabricating running boards. Tucked up close to the door. 1" outer flange. Step sides should have running boards. Your side pipe idea is a very good alternative.
  20. HOTRODPRIMER
    HOTRODPRIMER
    Love the Y-Block. HRP
  21. Stogy
    Stogy
    Those are awesome trucks...That metal shroud covering the engine is cool but it covers the other work of art. Perhaps you could incorporate some gl*** or lexan to allow a view to the shiny cool stuff...Just thinking...:rolleyes: Happy New Year Frames
  22. scrap metal 48
    scrap metal 48
    Cool truck with great modifications but I bet when you open your hood at a car show most people will think that cool Y-Block is a sbc.....
  23. mammyjammer
    mammyjammer
    from Area 51
    ..they wouldn't notice the top chop or the grill either....
    scrap metal 48 likes this.
  24. broke hotrodder
    broke hotrodder
    from NY
    6" is a pretty healthy kick up. I was going to block up the bed on dimensional lumber ( 3/8" incriments) so I could whittle build the kick up and see everything in the same plane. To me, the bed a touch higher than stock. I don't like how low it sits in relationship to the front when you start messing with the hood height. I think the hood looks better with a little nip and the bed a touch higher.
    What tires are you running in back 32's? If I had 1/2 the metal skill and twice the motivation, I might get something completed. Love your truck tip to toe.
  25. Frames
    Frames
    Ya I think my bed is more than a touch higher than stock. I don't remember how much. Did you see the bed front panel has a roll at the top? Oh oh. sorry I guess i don't have a picture. I am going to pie cut the hood. no more than 1.5". The rear tires are Mickys. 29-15-50-15. I call it a mini Pro street.
  26. Frames
    Frames
    I made the smooth panels behind the headlights. [ first picture ] I tunneled the sealed beams about 1/2". I sectioned the headlight buckets 1" to move the headlights back. I frenched the rims. Installed the engine. The progressive linkage is my own design. 312 002.JPG 312 004.JPG img109.jpg for a smooth look. Will take a little time to adjust the beam, but once and I'm done.
  27. Frames
    Frames
  28. BJR
    BJR
    I love a Y block with 3X2's and T Bird valve covers. They just look so cool.
    ffr1222k likes this.
  29. rustymetal
    rustymetal
    looking very nice love the roof
  30. 1946caddy
    1946caddy
    from washington
    You got a drill press for every size bit?
