Technical What is this?
Discussion in 'Traditional Hot Rods' started by Patrick StringerStine, Jan 28, 2018.
  1. I have a motor that I pulled out of a 73 GMC I'm wondering what it is because it looks like it has triple camel hump heads on it. somebody please help me!!! I will attach a picture of the heads and engine stamp.
  2. 49ratfink
    49ratfink
    that is not an SBC
    RaginPin3Appl3 likes this.
  3. Then what exactly is it?
  4. Sbc...... small block chevy.
  5. tb33anda3rd
    tb33anda3rd
    it is not a small block chevy. looks like pontiac blue/green. can you post a whole picture?
    3340 and RaginPin3Appl3 like this.
  6. oldolds
    oldolds
    How about a pic of the complete engine?
    Not SBC
  7. Motor
  8. Side
  9. 33 cdan man
    33 cdan man
    Looks like an Olds engine. 350-455.
    3340, dan c and zzford like this.
  10. Anderson
    Anderson
    Oldsmobile - ‘77-‘80 350 according to the head casting
    zzford likes this.
  11. greybeard360
    greybeard360
  12. timwhit
    timwhit
    First impression says Olds.
  13. Head
  14. Can you please tell me how you read the head casting numbers? I want to learn.
  15. Anderson
    Anderson
    This website is a good source of information
    http://www.442.com/oldsfaq/ofhed.htm
  16. BJR
    BJR
    Spark plugs above the exhaust manifold = Not a Sbc.
  17. Grumbler
    Grumbler
    Modern small block heads are identified by a single number and usually an accompanying letter like this one you posted, 7A. That and 5A are the most common. For big blocks there will be a single letter such as C, D, E, F (all desirable) or J (smog head, tiny exh port)
  18. arkiehotrods
    arkiehotrods
    From the site Anderson referenced
    3A '77 - '80 350 75 554716 1/2" bolt holes.
  19. dan c
    dan c
    you lucked out. back then, lots of people bought oldses and got sbc's in 'em. gm wound up paying everybody!
  20. cshades
    cshades
    from wi
    Are you sure the truck was a 73? A lot of late 70s diesel trucks had olds gas motors put in them after the 350 diesels expired.
    Terrible80 likes this.
