1925 Ford Model T Roadster / Speedster
Discussion in 'Cars For Sale' started by VWFOOL, Jan 19, 2018.
  1. VWFOOL
    VWFOOL
    City: Yachats
    State: Oregon
    Price: $5200 obo
    1925 Ford Roadster / Speedster project – Complete original drivetrain, engine turns over with good compression. I bought this ch***is to originally build a speedster but then I found a ’25 roadster tub, then I got a set of wire wheels and hubs and just kept collecting parts. My goal was to build a car that could do descent in traffic with a descent top speed. Here is a list of everything the car comes with:
    - Ruckstell big drum rear end that needs rebuilt with correct original shifter (Ch***is still has original ’25 rear end)
    - 3 to 1 Ring and Pinion for higher top speed
    - Original Warford auxiliary transmission w/ shortened torque tube and radius rods
    - ’25 Roadster tub (tacked together with only a couple tacks for mock up and dreaming)
    - ’26-’27 original wire wheels and hubs, tires are shot but hold air
    - Speedster style gas tank, nice original windshield frame, battery holder w/ 6 volt battery, exhaust pipe and muffler pieces, 4 coil boxes, good steering wheel to replaced cracked one currently on the car, dash panel, extra fire wall, extra cowl top, running board brackets, 2 hoods (not sure if either is correct, might be tall ones and this needs a short one?)
    - 2 different pairs of disc wheels. Not sure off of what but was starting to collect disc wheels for this build. Also comes with 3 model A wheels too.
    - Extra front end from a ’26-’27. Spindles will lower the front a bit and I was going to use the spring and front end to be sent off to Sid’s Drop Axle for reverse eye spring and 3” drop but never got that far.
    - Rear spring already has a reverse eye treatment done to it
    - Comes with a new set of shackles for the front end, new outside oil line kit and a new generator mounted on the engine.
    I have additional pictures I can email.
    Follow this link to the pictures since I am too dumb to figure out how to post them on here.
    https://www.thesamba.com/vw/cl***ifieds/detail.php?id=2134320
    Clear current ***le
    Located in Yachats, Oregon 97498 (Central coast of Oregon)
    International buyers welcome, I can provide references.
    $4500 firm.
  2. VWFOOL
    VWFOOL
    Reduced
    $4500 firm
  3. VWFOOL
    VWFOOL
    Last price drop.
    $4000 firm
  4. VWFOOL
    VWFOOL
