Projects '37 FORD TRUCK / 348 W MOTOR (FULL BUILD P.1-11)
Discussion in 'Traditional Hot Rods' started by '37-4D, Feb 23, 2017.
  1. '37-4D
    '37-4D
    Xmas come early!!! [​IMG]
    Totally stoked for these gauges w/ the custom crescent moon add-on from Cl***ic Instruments.
    Be looking at these lots so decided to spend a little on them!
    Some shiny parts:
    ...and wheel bling[​IMG]
  2. pprather
    pprather
    What are the hubcaps?
    Phil
    '37-4D likes this.
  3. Max Gearhead
    Max Gearhead
    from Wisconsin
  4. '37-4D
    '37-4D
    They are '42' to '46 - Ford baby moon caps. + beauty rings for 16" wheels
  5. '37-4D
    '37-4D
    More progress. Body is almost done and ready for prep and paint.
    Here the truck bed got it's skirt.
    I am loving how it flows. I think skunkvictim nailed it.
    [​IMG] [​IMG]
    Fern 54, brEad, Stogy and 2 others like this.
  6. spurgeonforge
    spurgeonforge
    Me likey!!!!
    '37-4D likes this.
  7. Schwanke Engines
    Schwanke Engines
    '37-4D likes this.
  8. '37-4D
    '37-4D
    Tail lights + master cylinder cover
    [​IMG] [​IMG] [​IMG]
    chop job, Fern 54, brEad and 2 others like this.
  9. '37-4D
    '37-4D
    Some last details on body
    Trunk space and battery box in bed and
    '1937 Ford dash getting some tlc.....
  10. '37-4D
    '37-4D
    Original front frame ends welded on to the custom frame.
    Head lights mounted, rad + grill mock up...
    brEad, Max Gearhead and Stogy like this.
  11. '37-4D
    '37-4D
    More teasers
    Hub caps + rings
    Dumps
    [​IMG] [​IMG]
    putz and Fern 54 like this.
  12. Stogy
    Stogy
    Evil, Wicked , Mean & Nasty
    You gotta be real happy with this unfolding
    with your hard work and attention to detail...
    Ya know just @'37-4D looking at the shot from the front alongside that slick it
    would be cool and of course more denairos to have a set of piecrust www
    slicks to change it up for a different flavour every once and a while. The Firestones however rock regardless.
    '37-4D likes this.
  13. '37-4D
    '37-4D
    Hahaha.......you nailed it with the four words.....bang on, that's the look we were going for.
    Although our vision aligned, the credit for lines, rake, detail and hard work goes to my man skunkvictim of Binbrook speed and custom shop near Hamilton Ontario in Canada. Thinking alike is definitely the winning recipe.
    Inspired by a few like Rudy Rodriguez’ ’35 Ford pickup + the Hunter speed Kustom build, Billy Gibbon's truck by Kirby Stafford and Canada custom ford truck by Laurie Peterson. We took our own direction on this one trying to produce our version with a little cartoon feel to it.
    I like ww's, not a big fan of slicks. I am a ****er for traditional.
    If you look beside my truck, he is building a crazy custom Ford delivery sedan with a 1000HP motor sporting the slicks, if I'm lucky enough it's owner, a friend, will let me have a go!!! :cool:
    Stogy likes this.
  14. Stogy
    Stogy
    Compliments to all involved 37. So if I read you correctly you prefer Blackwalls to WW's so those are borrowed rollers for the build?
    Either to me is traditional although BW is quite desired and no doubt the cheaper tire back in the day and cheap fits alot of budgets back then and even today.
    '37-4D likes this.
  15. '37-4D
    '37-4D
    No, I prefer WWs to BWs. What is on now, is what I'm using. The slicks at the back there belong to another build!
    Not my cup of tea for this truck :)
    Stogy likes this.
  16. '37-4D
    '37-4D
    -Last minute finishes to cab + bed
    -Hammer + dolly bumps
    -Body + frame rails getting picked up for prep + Paint this weekend
    -Motor gone to dyno
    -Parts to be chromed gone to Chrome guy (-minus headers)
    -Seating lumber going to upholsterer next week
    "Crossing my fingers that all cording to plan" [​IMG][​IMG]
    Stogy, brEad and Max Gearhead like this.
  17. '37-4D
    '37-4D
    Motor finally alive!!!!!!
    270hp 325 ft-lb
  18. bryanyeskie
    bryanyeskie
    from Hixton
    Ya I guess that's cool!
    '37-4D likes this.
  19. '37-4D
    '37-4D
    Some pics
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Stogy and Max Gearhead like this.
  20. '37-4D
    '37-4D
    '34 grill getting a facelift
    ls1yj, Stogy, brEad and 1 other person like this.
  21. Max Gearhead
    Max Gearhead
    from Wisconsin
  22. '37-4D
    '37-4D
    Haha :D
  23. '37-4D
    '37-4D
    Body got blasted and is getting its epoxy primer coat.
  24. '37-4D
    '37-4D
    Grill direction
    Stogy and brEad like this.
  25. '37-4D
    '37-4D
    Body + bed in black epoxy ready to patch and sand
    [​IMG] [​IMG]
  26. '37-4D
    '37-4D
    Frame....from patch to final paint and ready to re***emble with motor!!! [​IMG]
    [​IMG] [​IMG]
    and Painted !!!! [​IMG]
    [​IMG] [​IMG]
  27. brEad
    brEad
    Frame and grill are really looking good!
    '37-4D likes this.
  28. Stogy
    Stogy
    You sir are on a roll...Love the grill work...nice personal twists.
    Keep it up @'37-4D you'll bring on and early spring
    '37-4D likes this.
  29. '37-4D
    '37-4D
    Some more body shop pics.
    Spray putty
    while the frame is being re-***embled [​IMG]
  30. '37-4D
    '37-4D
    Level 2 on the cab.
    The back was very bad.
    Most of the cab bottom had to be redone with new patch panels as well as the doors as it seems it sat in the dirt.
    And the brown areas is were the metal was fairly thin and had to be cut out and replaced with sheet metal. So the repair was extensive!
    So here is it now. Still more sanding and another layer of primer and probably a little more sanding and a final layer!!
    brEad likes this.
