Hot Rods Save of the day!!(single seater)
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Mar 14, 2017.
  1. rusty rocket
    rusty rocket
    Started cutting on my frame this afternoon. Started at the cowl and started pushing the frame out to match the body/subrails. IMG_2485.JPG IMG_2486.JPG IMG_2487.JPG IMG_2488.JPG
    brEad, Stogy and sodakmini like this.
  2. rusty rocket
    rusty rocket
    I dont have the measurements off the top of my head. It is a two core instead of a stock one core. I know some of those tuner Hondas are making several hundred horse power. I would hope my L head six dodge is going to work its not high compression but being an older motor might tend to heat. My buddy and I where thinking for extra coolant we could fab a tank like the F.E. fords cooling systems.
  3. alchemy
    alchemy
    I was wondering if it might fit in the small shell I'm using on my T.
  4. rusty rocket
    rusty rocket
    Google Honda civic tuner radiators, I believe its 14.5 wide 16.5 tall
  5. rusty rocket
    rusty rocket
    Got my frame rails both ruffed in this afternoon. IMG_2489.JPG IMG_2490.JPG IMG_2493.JPG IMG_2494.JPG
    brEad, Stogy, Blues4U and 1 other person like this.
  6. rusty rocket
    rusty rocket
    brEad, brad2v, Stogy and 1 other person like this.
  7. Racer29
    Racer29
    Seem's like your moving along fairly quickly. Looking good!
  8. rusty rocket
    rusty rocket
    From my eyes it seems like I'm not getting **** done. Its a design as you go build and I have a lot of time to design things in my head! :)
    sodakmini likes this.
  9. sodakmini
    sodakmini
    Old man probably forgets his plan before he grabs the welder. Ha! Jk
  10. rusty rocket
    rusty rocket
    You are correct. I forgot what I did yesterday!! I remember giving you **** this morning tho!
  11. rusty rocket
    rusty rocket
    A buddy had some 46 front fender stainless so i'm going to use it! Damn it looks Kool!! IMG_2503.JPG IMG_2504.JPG IMG_2505.JPG
  12. Fabber McGee
    Fabber McGee
  13. sodakmini
    sodakmini
    I really dig it buddy! Definitely adds something kool and different to the build
  14. rusty rocket
    rusty rocket
    might as well use the holes that were already in the fenders.
    Atwater Mike, Stogy and sodakmini like this.
  15. rusty rocket
    rusty rocket
    juan motime, Speed~On and Stogy like this.
  16. vtwhead
    vtwhead
    the trim looks great...real nice touch
  17. rusty rocket
    rusty rocket
    I did a bit of mocking up this morning. IMG_2510.JPG IMG_2511.JPG IMG_2512.JPG IMG_2513.JPG
  18. rusty rocket
    rusty rocket
    Did a bit more pinching of the frame this afternoon also cut the tail end off and made a kickup. I will then weld the tail end that I cut off back onto the kick up. IMG_2515.JPG IMG_2516.JPG
  19. onekoolkat1950
    onekoolkat1950
  20. shivasdad
    shivasdad
    from Texas
    That little thing is coming out so cool!
  21. rusty rocket
    rusty rocket
    Made a template on the tail end to make sure the sheetmetal is the same on both sides and then started bending the frame around to match the body. IMG_2519.JPG IMG_2520.JPG IMG_2521.JPG IMG_2522.JPG
  22. rusty rocket
    rusty rocket
    Thanks man, hows the tank coming along?
  23. timwhit
    timwhit
    Great work man!!!
  24. Atwater Mike
    Atwater Mike
    I'm really following this, good thinking on the lower body flanges. (I was thinking 18 ga. angle and shrinking!)
    Great outcome...
    Rear spring mount: Short tube member with flat perch plate beneath? (if transverse rear spring is retained)
    If you do use Dodge p***. 'selector' type trans, a simple one-stick linkage can be made up: flat plate bracket fitted close to side of trans. Tubular 'stick' with single pole ****on at top. Single wire goes down tube to a 12 volt relay, ground activated; power to an early Chev starter solenoid, mounted inside frame rail. Short cable connects solenoid plunger to selector arm. Push ****on to pull selector arm to engage1st/reverse rail inside trans. Selector has return spring inside trans, so let go of ****on, stick now shifts 2nd and 3rd. Fastest speed shifts in the world! (good ground is ensured by attaching a flexible ground strap from bottom of stick to an attaching bolt...strap can come from hood ground strap on BMW in wrecking yard. Or outside yuppie watering hole)
    I did this one on a '31 Plymouth PA coupe with hemi and selector trans. Called it an 'electric shift'! Took 2 hours to make it...
    brad2v likes this.
  25. rusty rocket
    rusty rocket
    Thanks Tim. Been a fun build, is been a design as you go build for sure.
  26. rusty rocket
    rusty rocket
    My plan is to get one side of the frame done make a template and do the same on the other side. I will add material to connect the two together. My other thought is to add a plate in the back to locate the spring as far back as I can get it and still be under the body. Thanks for the info on the transmission, I really would like to get a top load three speed though.
  27. rusty rocket
    rusty rocket
    I got the back half of the frame ruffed in and did a little bench clean off. IMG_2527.JPG IMG_2529.JPG IMG_2530.JPG IMG_2532.JPG
    sko_ford, brEad, brad2v and 7 others like this.
  28. rusty rocket
    rusty rocket
  29. raven
    raven
    All i can say is WOW. I was going to suggest using the stainless trim pieces to give it a 'finished' look, but you beat me to it.
    r
  30. rusty rocket
    rusty rocket
    Thanks man. My buddy bought an older guys 42-48 stash, He had a bundle of front fender trim and out of all that trim there was one good left and one good right. It was meant to be:)
