Technical Door Glass Replacement 1955 Ford Customline
Discussion in 'Traditional Hot Rods' started by customline3859, Feb 1, 2018.
  1. customline3859
    customline3859
    Hello all. I was hoping for some technical ***istance with door gl*** removal and installation on my Customline. I have the door panels removed, but I'm just not sure how the gl*** comes out of the track. I was unable to find much help on youtube. Do I need to remove the vent windows first? Thanks in advance.
    David
  2. typo41
    typo41
    Its been awhile,
    With the door panel and window frame off, wind the window down until you see the window hit the window stop, the stop is screwed or bolted in place. Remove it and don't lose it. The window will now crank below the track and the wheel should come out of the track, keep your hand on the window as it will drop to the bottom of the door and will break.
    You should now be able to rotate the window 90 degrees and shove the gl*** up through the door.
    If I remember right....
  3. Typo41 is right. I have a '55 that my parents bought new, the method he describes is what I did when I replaced a door gl*** on mine. One suggestion that might be helpful is an old towel or two rolled up down in the bottom of the door for the gl*** to land on if it slips out of your grip.
    Mr48chev likes this.
  4. danman55
    danman55
    You need to lower the gl*** as stated after removing the lower gl*** stop. However, the vent window needs to be tilted inward. Give me your email address through a private message and I can send you a screenshot of the shop manual. Also visit hotrodreverend.com for some more info
  5. danman55
    danman55
  6. customline3859
    customline3859
    Awesome. Thank you for the info.
  7. evintho
    evintho
    Very nice write-up, danman55! '1955 Ford part #37: Door vent window ***emblies and door gl***' for those searching 'hotrodreverend.com'. I'll be referring to this when installing my gl***!
    danman55 likes this.
