Technical 292 inline 6 swap into a 49-52 Chevy styline
Discussion in 'The Hokey Ass Message Board' started by 51dodgetruck, Feb 1, 2018.
  1. 51dodgetruck
    51dodgetruck
    from tyrone,pa
    I have recently purchased a 292 6 and wanted to use it in my 52, but I don't know how to go about it because the mounts are different, the guy I got it from had it in a 63 nova and clipped it and is now getting ready to swap a v8, could I just use his clip?
  2. 51dodgetruck
    51dodgetruck
    from tyrone,pa
    12bolt.com sells the 62-67 Chevy II mounts could I use those?
  3. Mr48chev
    63 Nova clip absolutely will NOT come close to working on your Chevy. If you have the stock frame. That is a stamped sheet metal piece with built in spring towers.
    The 12 Bolt Tom mounts won't do you any good as you don't have a frame with mounts for a V8 already and as I said the nova stuff won't work.
    I just bought mounts to put a 292 in my pickup from Ch***is engineering inc that use a pad on a bracket on the frame rail and are real simple Problem is that the company sold to Heidts after the owner p***ed away and they are in the process of moving the production facilities. http://www.ch***isengineeringinc.com/chevy-parts/ The mount comes off the side of the block similar to this one on a 250 does and uses a motor mount biscuit like Ford Flatheads use. The left side mount for the 292 is offset to match the p***enger side and keep the mounts straight across. If you haven't checked the right side mount pad on the block is about three inches in front of the left side pad. On the 292 the fuel pump is behind the mount rather than in front of it. 250 motormount.jpg
    Here is a link for some made for your stock frame and stock suspension. Solves a lot of problems especially if you are just starting out doing engine swaps.
    These are a bit spendy but Davis builds some nice stuff. this is everything you would need for mounts Ebay item Put this in the ebay search 222097737378
    51dodgetruck likes this.
  4. 51dodgetruck
    51dodgetruck
    from tyrone,pa
    Thank you! I've read that it's possible to use an s10 rear end but there's a difference between models and size? And that they are pretty much a bolt in..
  5. 56sedandelivery
    56sedandelivery
    You want a rear end that's about 60 inches outside of drum to outside of drum; the 4 X 4 Blazer/S-10 is the rearend you need. The 55-57 Chevrolet are almost a bolt in only requiring redrilling of the spring pad locator hole 1-1/2" forward, and 1/2" inward on each side. Tri-Five shock mount plate and U-bolts also work well. Since you're using a later six, and not a V-8, the firewall supports don't have to be cut, and you retain your parking brake. Sent you a P.M.
    I am Butch/56sedandelivery.
  6. RICK R 44
    RICK R 44
    292 is longer t6han the old 216. You will have to move the rad forward or modify yhe fire wall
  7. mr.chevrolet
    mr.chevrolet
    292 in a 37
    ThrottleLobotomy and tb33anda3rd like this.
  8. 51dodgetruck
    51dodgetruck
    from tyrone,pa
    How would I go about moving the rad forward? Is there enough room that I won't have to mess with the grill?
  9. 51dodgetruck
    51dodgetruck
    from tyrone,pa
    Does the 4x4 drive s10 rear bolt right in or is there fabbing to do?
  10. 56sedandelivery
    56sedandelivery
    ^^^^Almost anything, other than a Tri-Five or some of the late 60's/early 70's Camaros/Novas, will need to have the spring mounts added/moved/re-drilled. There's enough room in front of the radiator support to scoot the radiator forward, or you may get by just by adding an electric pusher fan. Do a search here on the HAMB; there are hundreds of threads on the Stovebolt Chevrolet's. I am Butch/56sedandelivery.
  11. gimpyshotrods
    gimpyshotrods
    Dude, piece of advice: You have about 10-posts. They appear to be all questions about one of the most popular models to modify that you will find on this board. They all have been answered, in every way that they can be, numerous times.
    Eight years ago, I had not worked on a single one of these. Now, I have worked up 14.
    Want to know how I figured it out?
    Right here, on this board.
  12. Mr48chev
    55/57 rear axles are somewhat hard to find now but as 56 Sedan Delivery said in post 10 that was the rear axle of choice back in the 60's and 70's when swapping a later enginem trans and rear into one of those cars was pretty common. I've never owned one that got the rear axle swap but in the 60's and 60's helped guys with a number of them. That S 10 4x4 rear has pretty much replaced the tri 5 Chevy rear for that swap.
    In my truck on the 250 that is in it now I shortened the shaft on the water pump a bit and ran a shorter top pulley. That gave me minimal radiator clearance for a flat fan but it worked for 100k miles. I think I have a short pump V8 Chev pulley on mine but the pulley came out of my pulley box and was one that worked. On some you can gain about a half inch or so by sliding the radiator flanges down inside the core support and run the bolts in from the back and put nuts and washers on from the front. Moving it much further takes other mods though.
    Shortening the water pump shaft running the shorter pulley and then running an electric pusher fan if you don't have decent fan clearance is probably the simple no mess way out. I am not a big fan of pusher fans but this time around I think my truck is getting one with the 292 going in it.
  13. 51dodgetruck
    51dodgetruck
    from tyrone,pa
    Sorry I just don't know how to use this app / site
  14. 4X4 s10 rear diff needs perches moved
    55-57 rear end bolt in with minimal mods
    67-69 camaro is a bolt in
    2nd Gen camaro minimal mods
    You can move the rad forward to gain space
    You can cut the stiffening ribs off the fire wall and move it back
    You can use a shorter water pump and a v8 pump pulley
    Look on eBay for mount kits etc a few guys selling them
    Ooooor the search function works also
    These cars are great easy to modify and make things work
  15. 51dodgetruck
    51dodgetruck
    from tyrone,pa
    Thank you
  16. NashRodMan
    NashRodMan
  17. 51dodgetruck
    51dodgetruck
    from tyrone,pa
    I planned on using a th350 as the ******, could I use the crossmember mount from a 67-69 Camaro or is the a specific adapter I would have to use?
  18. NashRodMan
    NashRodMan
    You could try to adapt the Camaro cm if possible or just make one yourself out of heavy C channel or box tubing. I doubt anything would be a bolt in.
  19. gimpyshotrods
    gimpyshotrods
    Look up Waltonfabrications.com.
    Sent from my SM-G900T using The H.A.M.B. mobile app
  20. rusty1
    rusty1
    ...yup, Walton fab,..get in touch with HAMBer Bob Klessig, he ran a 292 in his 50's ragtop.
