History Let's See Some Blown/ Supercharged Flatheads
Discussion in 'The Hokey Ass Message Board' started by Speed Gems, Nov 16, 2016.
  1. Looks ''F'' head. JW
  2. mgtstumpy
    mgtstumpy
    Speed Gems likes this.
  3. Doc.
    Doc.
    I see a couple of my blown flatties in the picks. Cool thread.
  4. 55willys
    55willys
    Here is the pattern that I am going to use to cast some flathead blower intake manifolds. IMG_20170118_202200712_HDR.jpg IMG_20170119_120153737_HDR.jpg
    Carter and Speed Gems like this.
  5. 55willys
    55willys
    I really think that the 4-53 GM blower is the best for use on a flathead. I am working on a pattern for an intake manifold too accept one of these. I see that you used the stock oiling system instead of using sealed bearings. Nice job on running the oil lines by the way. Does this setup work well for you? I have a blower setup guy about 30 miles North of me that has a number of 4-53s.
  6. Blake 27
    Blake 27
    Rusk likes this.
  7. acme30
    acme30
    from Australia
    Hi 55willys
    In terms of the oiling there are a few of them running around in Oz using the stock oiling system. If you want to use sealed bearings there is not a lot of meat in the case to fit them so the ones I have seen use the stock pressure fed system.
    The one's I have seen just oiled from the one side but I figured it might be better to pressure feed from both sides that way each bush/bearing gets the same amount of oil so that's what I did. I was concerned about loosing oil pressure to the rest of the engine so I put a restrictor in the feed line. I am using the pressure feed from the back of the engine with a Y adaptor into the Y...... I tapped a thread so I could screw a carby jet into the feed line. I figured that way I could adjust the oil flow if I needed to but haven't had to worry about it.
    The other thing I did was so that the front snout and rear cogs ran in oil I inserted some small drain pipe into the front case so that the oil 1/3 fills the case before overflowing into the return drain pipe.
    PS good luck with your casting enterprise. My buddy who did all the machining and one off parts for me and I looked at casting some of the inlets and adaptors but in Oz we came to the conclusion that the market is just small and the cost too high to make it seem like a worthwhile exercise.
    46international likes this.
  8. acme30
    acme30
    from Australia
    Sorry for the delay in pics (like my build I am a bit slow) Not the greatest machining pics but you get the idea
    mgtstumpy and 46international like this.
  9. DDDenny
    Nice spread, thanks.
  10. Blown35
    Blown35
    Kiwi 4d and mgtstumpy like this.
  11. mgtstumpy
    mgtstumpy
    rod1 and Speed Gems like this.
  12. mgtstumpy
    mgtstumpy
  13. mgtstumpy
    mgtstumpy
  14. Elco Heads
    Elco Heads
    A friends Flathead V8 4-71 blower and he is using my 4-71 blower intake and 3x2 4-71 blower top plate intakes that I manufacture. I also make a multi purpose Flathead intake and 4x2 471 blower top plate intake,[ photos below. ben 2.jpg
  15. Flat Roy
    Flat Roy
    IMG_0010.jpg IMG_0011.jpg Maybe not so traditional
    Donuts & Peelouts likes this.
  16. mgtstumpy
    mgtstumpy
  17. Bandit Billy
    Bandit Billy
    I posted on this thread a few years back while under construction. It did get finished and has been racking up the miles.
  18. mgtstumpy
    mgtstumpy
  19. Fordors
    Fordors
    loudbang and mgtstumpy like this.
  20. Kiwi 4d
    Kiwi 4d
    An original Italmechanica which we ran on our 37 coupe. It ran ok. Used it with our 34 pickup display at the national hot rod show In December 1999
    akoutlaw, loudbang and mgtstumpy like this.
  21. Kiwi 4d
    Kiwi 4d
    We got offered what I thought was silly money for the above IT blower , let it go. Bought a new H&H one put it on a 265 flathead . Could never get it to make decent boost using the H&H supplied pulleys ,all it did was look good and get in the way of the intake charge . So now sadly it’s wall art.
  22. Kiwi 4d
    Kiwi 4d
    A couple of kiwi ones at the pre 49 event this year.
    AB01D1B5-4C47-47BB-B245-8D67C7E8FE55.jpeg 31BBF34A-86D4-4C69-97A2-AA180152B7DB.jpeg
    kidcampbell71, fauj, akoutlaw and 2 others like this.
  23. flatmotor40
    flatmotor40
    from georgia
    Kiwi 4d I had thought about getting one from H&H for my 40 but I was really not need a lot of boost for my bottom end is stock rods and main caps.really for the looks.Mine is a 040 over Offy heads Reed cam 2 97.It runs great but just need a change.You are never finished changing things
  24. Kad60
    Kad60
    from Australia
  25. JimSibley
    JimSibley
    Jack Runners blown t bucket. Firse with the 6-71, and later, swapped to a 4-71, which worked a lot better. DB48840F-FEB4-49A1-AF66-1BBE1C6863B3.png C5E5D8FD-F902-498A-9C12-DABCA9C59828.jpeg 4A042D33-0C19-4745-816C-7C39D4AF216C.jpeg
