Hot Rods 8ba: lifter/oil galley, oil diverter shields & clips
Discussion in 'The Hokey Ass Message Board' started by steve hackel, Feb 2, 2018.
  1. steve hackel
    steve hackel
    Hello; I am working on a 50 8ba engine, and in the oil galley are the 2 oil diverters/shields with their clips riveted to them to install on the center pipe - although my shields are there, both clips are broken Has anyone replaced the clips, has anyone found a good replacement clip that is available, anyone have a solution or suggestion on how to fix them? Thanks, Steve
  2. paleot
    paleot
    from louisiana
    Steve those things are readily available used post in the wanted section I bet someone there can help You.
