Projects '32 Henry steel Roadster build
Discussion in 'Traditional Hot Rods' started by ericjustus, Aug 5, 2016.
  1. ericjustus
    ericjustus
    from Chino, CA
    Progress you can't see
  2. ericjustus
    ericjustus
    from Chino, CA
    Grill and plates fitted up
    ChuckleHead_Al and Stogy like this.
  3. ericjustus
    ericjustus
    from Chino, CA
    Lyons wheel covers. Rare find. Score.
    ChuckleHead_Al, Stogy and waxhead like this.
  4. what parts are you looking for?
    Sent from my SM-J700T using The H.A.M.B. mobile app
  5. ericjustus
    ericjustus
    from Chino, CA
    Original lower stanchions, radiator cap, ford logo, e-brake, steering wheel, deck lid handle, all 4 shock arms and a rear spreader with luggage tabs. Easy stuff, right?
    Stogy likes this.
  6. yeah pretty sure I got alla that. just gotta look thru my pile, might take a little bit to find it. 95 percent I got it all... let's keep in touch
    Stogy likes this.
  7. ericjustus
    ericjustus
    from Chino, CA
    Ooooh nice! You can email me atdkrmember@aol.com
  8. ericjustus
    ericjustus
    from Chino, CA
  9. ericjustus
    ericjustus
    from Chino, CA
    Haven’t had much time lately but working on this right now
    Stogy likes this.
  10. ericjustus
    ericjustus
    from Chino, CA
    Metal work is taking a bit longer than expected and I had to finish up another project car that took up a lot of my time the past 2 months. Up next is chopping the 32 top irons and dialing in the finish work on all the metal. I would like to use skim coats to fine tune the paint rather than fine tune the body. The holidays will slow things down a bit. I will post more pictures once the body is done with metal work, gaps are all done and the car is fully or close to pre-***embly before taking it all apart to start the final body work for paint.
  11. ericjustus
    ericjustus
    from Chino, CA
    Got it rolling on the right shoes. It has now left my garage to finish up the doors, dash, top iron chop and a few other odds and ends
  12. 383deuce
    383deuce
    I have the matching headlights on my 3 window if ya want to sell this let me know..Thanks
  13. ericjustus
    ericjustus
    from Chino, CA
    Sold awhile back, sorry
    Back2school likes this.
  14. ericjustus
    ericjustus
    from Chino, CA
    Took an eighth of an inch out of the frame, m***aged it a bit more to flow with body lines and swapped out stanchions. P***enger door is done and drivers door is close to it. Chopping the 32 top irons this weekend. It’s a 3” chop but im making it specific to my height so the 3” will have some give and take. Once we’re done with that Im going back over the frame to chamfer all the holes drilled, get the rivets put on permanently and then we will tackle the hood. Lots going on right now
  15. ericjustus
    ericjustus
    from Chino, CA
    Chopped the top today. Mocked it up with masking tape.
    kidcampbell71, treb11, brEad and 4 others like this.
  16. ericjustus
    ericjustus
    from Chino, CA
    Getting the hood situated and then we will finish up the headlight bar placement
  17. ericjustus
    ericjustus
    from Chino, CA
    Needed to drive today so I took the 55 out to a local cars & coffee with my buddy in his deuce roadster. 210hp and 100hp zipping down the streets. A nice break from building ****.
    kidcampbell71, Stogy, brEad and 4 others like this.
  18. ericjustus
    ericjustus
    from Chino, CA
    Got my transmission all wrapped up. About as new as you can get with old stuff. Swan neck polished up nice, too.
  19. x77matt
    x77matt
    Love your build! Very good choices on this...
    ericjustus likes this.
  20. ericjustus
    ericjustus
    from Chino, CA
    Ready for paint and chrome
  21. ericjustus
    ericjustus
    from Chino, CA
    Justin Veazie started working on the hood channel repair and fit. Two things you’ll see is the welting and the gap on the front grill she’ll still need some work. You should get the idea of the project with the pics.
    Stogy likes this.
  22. ericjustus
    ericjustus
    from Chino, CA
    Ojos
  23. ericjustus
    ericjustus
    from Chino, CA
    Was able to locate a 36 LB that runs. Sold off some of my other 21 stud **** to help pay for this. Now I will tear it down and build it back up.
    Stogy and ChuckleHead_Al like this.
  24. ericjustus
    ericjustus
    from Chino, CA
    Rebuilt and prettied up 97’s with arrowhead bases to match the Edelbrock slingshot intake. Do not know what I will top the carbs with (air cleaners, scoops, etc.)
  25. ericjustus
    ericjustus
    from Chino, CA
    Broke out the masking tape and Ford green. This transmission is a wrap. Well, I am holding back from bolting on the repop e-brake. Will still search for a good original.
  26. ericjustus
    ericjustus
    from Chino, CA
    Just cuz I wanted to look even tho it’s backwards
    Stogy, ChuckleHead_Al and waxhead like this.
  27. ericjustus
    ericjustus
    from Chino, CA
    Started the tear down. Looks good so far, few wrong parts, pretty bad paint job & needs a good father figure to bring out the best in him.
  28. ericjustus
    ericjustus
    from Chino, CA
    For anyone reading I’m still looking for a stock 32 steering wheel, a 34 fuel pump stand, 32 transmission cover and original e-brake
  29. ericjustus
    ericjustus
    from Chino, CA
    More one off ****. Mike at Early Ford Store occasionally opens me up to his stash.
  30. WiredSpider
    WiredSpider
    I ***ume you know that the trans mount ring is on backwards?
    Stogy and ericjustus like this.
