Projects 65 Ranchero Southeast Gasser build
Discussion in 'Traditional Hot Rods' started by colbyw, Dec 28, 2017.
  1. powrshftr
    powrshftr
    It will probably help with traction a bit just by getting the weight of the tailgate out a foot or so farther behind the axle.
    Thor1, D-Russ, rawcjw19 and 2 others like this.
  2. savannahDan
    savannahDan
    following, working on a 63 falcon hardtop for SEGA here. And the engine location measurement was helpful for me too!
    Thor1, colbyw, Gammz and 1 other person like this.
  3. colbyw
    colbyw
    Yeah the percent is found from the wheelbase I’m not sure on a mid or rear engine car
    Thor1 and loudbang like this.
  4. rawcjw19
    rawcjw19
    Evidently all great minds think alike. We have already had the weighted tailgate discussion [emoji3]
    Thor1, catdad49, loudbang and 2 others like this.
  5. Hombre
    Hombre
    As to the Tonneau cover and wind resistance. I have a buddy that has a Dodge Ram ***mins truck he swears that when he added his tonneau cover his mileage went up to 23 mpg. Well I also have a Ram ***mins truck to be honest I never ever got the mileage that most ***mins guys got or claimed they got. I am damn happy with 14 MPG but I added a tonneau anyway. Yea it made a big difference I am now all the way up to about 14.1 MPG . They look good and protect stuff in the back but the wind resistance thing I am pretty sure is a myth.
    Thor1, catdad49 and loudbang like this.
  6. Cabbage
    Cabbage
    10 percent of the wheelbase measured from the spark plug closest to the radiator. Its good to see another southeast car coming together welcome to the club!
  7. Hang'emHigh
    Hang'emHigh
    Sub'd! I have a soft spot for Rancheros. Looking forward to seeing how this one comes together!
    Thor1, loudbang and Gammz like this.
  8. Ft.ValloniaStreaker
    Ft.ValloniaStreaker
    Thor1, loudbang and D-Russ like this.
  9. southcross2631
    southcross2631
    Set back is measured from the center of the front spindle to the Front spark plug hole. With the modern track prep and the good tires today a 10% set back will make for a wheelie machine.
    Back in the day where track prep was hit or miss and the tires were as hard as a minister's **** you needed the set back.
    Thor1, AHotRod, sidevalve8ba and 2 others like this.
  10. rawcjw19
    rawcjw19
    [​IMG][​IMG][​IMG]
    We started on the ladder bars today. I caught a few action shots of him actually working.
    Thor1, brEad, catdad49 and 4 others like this.
  11. rawcjw19
    rawcjw19
    Thor1, brEad, AHotRod and 6 others like this.
  12. Gammz
    Gammz
    from Lincoln Ne
  13. colbyw
    colbyw
    [​IMG][​IMG]
    Spent the day building the ladder bars, the drive shaft loops, and the crossmember for the front of the ladder bars this is what we ended up with
  14. BCCHOPIT
    BCCHOPIT
    Rules say NO Corvair’s ....
  15. Hombre
    Hombre
    No that is not what the rules say. It says no " V8 Corvair's"
    Thor1 and Doctorterry like this.
  16. OahuEli
    OahuEli
    from Hawaii
    Great project you have going here! If you want any photoshop work just let me know. Been a Ford guy forever. Subscribed!
    Thor1, loudbang, colbyw and 1 other person like this.
  17. sidevalve8ba
    sidevalve8ba
    I wonder if that means with the engine in the front or in the rear 'cause I've seen them either way! :eek: :rolleyes: o_O
    Thor1 likes this.
  18. Hombre
    Hombre
    You know sidevalve that is an interesting question, but I believe it answers itself when it says NO V8 Corvairs.
    The SEG is all about the 60's and g***er's from that era. Thank the lord!! I am sure that the founders would not allow anything that is outside of that box, and I say good for them. But with that said wouldn't it be interesting to see a straight six corvair rear wheel drive. I wonder if that was ever done?
    Thor1, loudbang and Doctorterry like this.
  19. southcross2631
    southcross2631
    He is lucky to have such a well equipped shop and a willing teacher. Good job both of you.
    Thor1, rawcjw19, Hang'emHigh and 3 others like this.
  20. colbyw
    colbyw
    Thor1, AHotRod, TFoch and 5 others like this.
  21. Gammz
    Gammz
    from Lincoln Ne
    Are you running coil overs or leaf springs? I so want to do ladder bars on ours.
    Thor1, loudbang and colbyw like this.
  22. Hombre
    Hombre
    Someone correct me if I am wrong, but I am pretty sure that the SEG has a rule against "Coil Overs"
    Thor1, AHotRod and loudbang like this.
  23. colbyw
    colbyw
    I’m running a leaf spring setup pretty much identical to Jeff Jacobson’s Skairlane
    Thor1, AHotRod, Gammz and 1 other person like this.
  24. colbyw
    colbyw
    You can run a coil spring but no coil overs
  25. colbyw
    colbyw
    Also finished up the crossmember today for the ladder bars and driveshaft loop
    Thor1, brEad, AHotRod and 5 others like this.
  26. southcross2631
    southcross2631
    Nice job . It will also make a good mounting point for your floor pan.
    Thor1 and colbyw like this.
  27. rawcjw19
    rawcjw19
    The teacher is just winging it most of the time. Lucky for us all of you skilled car builders on the H.a.m.b are nice enough to post pictures. We do have access to a nice shop. I work at a small company that builds manufacturing ***embly equipment. It is a pretty well equipped shop. I also have a couple local shops I use for laser cutting.
    Thor1, catdad49, OahuEli and 2 others like this.
  28. rawcjw19
    rawcjw19
    I will admit the ladder bars take a lot longer than I thought. Tapping the tubing for the rod ends wasn’t much fun for Colby. If I had to do more we would fire up the Cnc lathe
  29. enloe
    enloe
    from east , tn.
    VERY COOL BUILD
  30. So floater mounts? Also how ling did you make your bars?
    Sent from my SAMSUNG-SM-J320AZ using Tapatalk
