Call me a coward if you will but I will tear a motor down ,build rear end do body work but automatic ****** scares me to death. Therefore this LOKAR shifter is kind of daunting for me. I have visions of springs and little pieces flying all over the place with no idea what goes where after while I install the shift lever in an open case of my freshly rebuilt transmission. Have any of you tried it or should I just throw up my hands and pay the transmission guy?
Installing the shift lever is a piece of cake. You shouldn't encounter problems as long as you are careful. Setting up the kickdown cable is the tricky part. Doing it wrong and driving it can ruin the ******. Experienced hands on here can help you avoid catastrophe.
You'd be surprised how important that kick down adjustment is. I had a Lincoln Mark VII that had the AOD, and there were pages and pages on forums about shifting problems. Turns out that it was usually just the plastic bushing that connected the kick down cable to the throttle body that had disintegrated.
It is not a kick-down cable, it's throttle pressure. Thats why the adjustment is so critical, and why the trans can burn-up on a test drive around the block.
The AOD cable adjustment is very easy with a pressure gauge hooked up to the middle port on the right hand side of the trans. Real good YouTube videos on the adjustment. At idle the pressure is almost zero, off idle about 5/16 of an inch and the pressure should go to 30 to 40 PSI. That's all there is to it. I have a Lokar shifter installed on mine and it was real easy. The shifter has nothing to do with the throttle trans cable adjustment.
The shifter is cake. Follow Lokar's instructions. Worst case, you have to drop the pan and put in a new shift lever into the ******. Even that is relatively simple, just a roll pin, jam nut, and 6 mm bolt for the detent spring, just ****s laying on your back doing it in the car as the remaining ****** fluid drips onto your head.
You're right, I misspoke. TV cable, and following detailed instructions should keep your ****** safe.
Watch this video and also part #2 Also check out steps 10-17 here if you get that "rooster comb" wrong you end up with 1st and Reverse only Not uncommon http://www.mustangandfords.com/how-...nstall-the-lokar-aod-shifter-shifty-business/
