Projects 65 Ranchero Southeast Gasser build
Discussion in 'Traditional Hot Rods' started by colbyw, Dec 28, 2017.
  1. colbyw
    colbyw
    Yes and the ladder bars are 47 inches long. They’re a little longer than what I wanted but I wanted to have my crossmember for them to also work with my driveshaft loop
    Thor1, catdad49, Gammz and 1 other person like this.
  2. Doctorterry
    Doctorterry
    colbyw and loudbang like this.
  3. Hang'emHigh
    Hang'emHigh
  4. colbyw
    colbyw
    Not to much too show, been stuck finishing up my sisters car for the meltdowns. Currently working on putting the springs under the car [​IMG][​IMG][​IMG]
    Also got measurements for the mid plate most likely gonna have a local metal shop laser cut one for me and that will be next.
    Thor1, AHotRod, TFoch and 8 others like this.
  5. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Obviously not a G***er and totally non-SEG compliant, I absolutely love this one.
    Oh, and the Ranchero is looking good!
  6. Gammz
    Gammz
    from Lincoln Ne
    You get them springs special or take apart a pack and only using one?
    Thor1, loudbang and colbyw like this.
  7. colbyw
    colbyw
    They are mono leaf springs from a 1st gen camaro they came on the convertible cars
    Thor1, loudbang and Gammz like this.
  8. cracker head
    cracker head
    Awesome.
  9. 6sally6
    6sally6
    Love the little SBF stuff!
    Compression is your friend!
    Turn the pistons around backward for free HP.
    Have you put together any "ideas" on the engine?
    I'll be watching!
    Maybe see you in Myrtle Beach this June?!!
    6sally6
    Thor1, colbyw, loudbang and 1 other person like this.
  10. southcross2631
    southcross2631
    Ranchero is looking good. Like you my progress on my Morris is going slow.
    Thor1, dvonyeast, enloe and 1 other person like this.
  11. rawcjw19
    rawcjw19
    He has been pretty patient on the ranchero build. I have been having him help me finish his sisters 66 dart and we replaced the rear end components on the model a. A couple more weeks and we should be able to concentrate on the ranchero
    Thor1, chriseakin, OahuEli and 5 others like this.
  12. colbyw
    colbyw
    Plan on building a 331
  13. southcross2631
    southcross2631
    I am finishing up my 308 in motor ,but I have a freshly machined 65 289 block that will either be a 297 or if the car drives decent a 334 for C/Gas. I hate the thought of having to add 600 lbs to the car just to make cl*** weight.
    enloe and colbyw like this.
  14. glrbird
    glrbird
    Need fender well headers?
  15. Mike Colemire
    Mike Colemire
    Those mono leafs work good. Had them on a 68 camaro with floaters and ladder bars years ago.
    AHotRod, OahuEli, rawcjw19 and 2 others like this.
  16. colbyw
    colbyw
    Got the motor mounts, transmission crossmember, front end, and mid plate in place. Cage kit should be in within a week.
    Thor1, AHotRod, rawcjw19 and 6 others like this.
  17. colbyw
    colbyw
    Thor1, brEad, AHotRod and 8 others like this.
  18. Gammz
    Gammz
    from Lincoln Ne
  19. Hang'emHigh
    Hang'emHigh
  20. colbyw
    colbyw
    Cage is about halfway done, at the point where I need too figure out where my seat is going too continue also been working on replacing some rough spots on the car like the rear corners and a few other spots. put in the second driveshaft loop a while back. I have been working on collecting parts slowly but surely. I have a flaming river Vega box that I got off a fellow H.A.M.B. member and have the material coming in too get my steering nearly finished.
    Thor1, AHotRod, Gammz and 4 others like this.
  21. Doctorterry
    Doctorterry
  22. Gammz
    Gammz
    from Lincoln Ne
    Thor1 and loudbang like this.
  23. rawcjw19
    rawcjw19
    The jegs cage fit pretty well. The front down bars go down straight and we’re going too try too get some with a bend in them
  24. rawcjw19
    rawcjw19
    Thor1, powrshftr, Doctorterry and 5 others like this.
  25. colbyw
    colbyw
    [​IMG][​IMG][​IMG]
    Have been doing a little bit more work on the Ranchero. Cage is pretty well done, seats are mounted in place and steering is partly done once I get some material for the column it will be put in place then next is going to be pedals and narrowing the rear end. All my wheels and tires have been bought so that’s another piece to the puzzle. Everything’s been going well just had a busy summer and spent some time on another project. Sorry for the slow update.
  26. Hang'emHigh
    Hang'emHigh
    Slow beats never.... Looking good!
    Thor1, loudbang, Hombre and 2 others like this.
  27. pumpman
    pumpman
    Slow is my new way of life so it works for me kid.
    Thor1, loudbang, Hombre and 1 other person like this.
  28. saltflats
    saltflats
    from Missouri
    Looks like you are gettin to where going faster is gettin closer. ;)
    Thor1, Hang'emHigh and loudbang like this.
  29. catdad49
    catdad49
    Progress is progress, great work, it'll get there! Understand there may be a grudge match brewing, you and a certain El Camino?!
    Thor1, colbyw and loudbang like this.
  30. Gammz
    Gammz
    from Lincoln Ne
