Customs carb adapters
Discussion in 'The Hokey Ass Message Board' started by gasmonkeyrodder, Feb 8, 2018.
  1. gasmonkeyrodder
    gasmonkeyrodder
    from uk
    Hi help needed, can anyone tell me if there are any carb adapters/spacers to fit a Mopar six pack intake to convert from Holley to Stromberg big 97`s as I want to run a more period set up on my 1940 Plymouth coupe custom. Thanks all help much appreciated.
  2. Cosmo50
    Cosmo50
    There are 4 bolt carb to 3 bolt carb adapters out there.
  3. gasmonkeyrodder
    gasmonkeyrodder
    from uk
  4. egads
    egads
    gasmonkeyrodder likes this.
  5. Mike VV
    Mike VV
    from SoCal
    There's always aluminum plate and a mill.
    Or at worst, aluminum plate, a hack saw, and files..!
    Mike
  6. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>I want to run a more period set up>>>
    Wood. Jack E/NJ
    egads likes this.
  7. Cosmo50
    Cosmo50
    Those 4 bolt to 3 bolt adapters work with the small base Rochester 2G carburetors. So if your Holley has the same bolt pattern, it should fit fine. Otherwise you would have to use an additional adapter or a custom adapter.
