Projects I found her and she is pretty 1933 ford
Discussion in 'Traditional Hot Rods' started by Spencer Caldwell, Feb 3, 2018.
  1. rusty valley
    rusty valley
  2. Spencer Caldwell
    Spencer Caldwell
    I think they are Buick headlights when researching them but could be wrong I will post pics later.
    Sent from my SAMSUNG-SM-G930A using The H.A.M.B. mobile app
  3. '33 5window coupe, the absolute best of the model 40s in my opinion. That car has got *** on spades. :cool:
    A little caution and a chance to learn from my mistakes, do not over think it. It is off to a good start as it is, do what is necessary to make it go and drive it. Maybe you'll want to change it up later but give it a chance to run and drive and make you happy first.
  4. murpa
    murpa
    from .
    Now that is a great find ! Your a Lucky dude
    loudbang and Spencer Caldwell like this.
  5. Spencer Caldwell
    Spencer Caldwell
    Tim thank you so much for coming out and checking out my project and giving me a gauge panel and ring. Very nice to meet u and your friends. I really appreciate the advice.
  6. timwhit
    timwhit
    Spencer, your car has great bones. The ch***is will be an easy build since it has all the basic parts, just needs refurbished. The bodt needs some but nothing time and work cant handle. Keep us posted!
  7. MR CLEAN
    MR CLEAN
    Spencer Caldwell,
    Congrats.......Looking forward to watching your Model 40 Build.
    I would highly recommend reaching out to Tom for all your Sheet Metal Replacement Panel needs during your build.
    R & J Enterprises
    Arkansas City, KS
    620-441-0032
    MR CLEAN
    ls1yj, RODIST, timwhit and 3 others like this.
  8. Spencer Caldwell
    Spencer Caldwell
    Alright tonight was a start, I removed some weird spray Styrofoam from the inner cowl and found no patch panels to the lower cowl and then felt frisky and yanked the 8b out. Next, will be dis***embly of the motor and send it to the machine shop. I am going to remove the ****** and get it overhauled. Next will be removing the same foam from the rear quarters. Then splitting the body from the ch***is and then soda blasting here we come. Thanks everyone for all the help and timwit for all the wisdom.[​IMG]
  9. rusty valley
    rusty valley
    good to get that spay foam outa there, it holds moisture. i am a 59ab sorta guy, but many folks like the 8ba block. what is the ******, have you pulled the shift cover off? easy to tell if its got the good later gear set in there. if the slot for the shift fork goes in the center, like slicing a bagel in half, its old junk, and if its slot is way over at the edge, its the "39" style. best wishes
  10. Spencer Caldwell
    Spencer Caldwell
    I have a 59ab sitting next to the car and I will send u a pic of inside the ****** cover and you could let me know if it's junk!! Thanks alot for the info!!
  11. Spencer Caldwell
    Spencer Caldwell
    The web is still there!
  12. timwhit
    timwhit
    Spencer,, your going to be in good hands with all these guys around. Are you going to build the 59ab or the 8ba? You might be carefull about putting the 59 block on an engine stand. Generally thought of as being hard on the bell housing. Send us pics of the frame when the body is off. Glad your going after it. Tim
  13. Spencer Caldwell
    Spencer Caldwell
    Thanks Tim, the 59 was on the engine stand when u came to visit this week. But i think i am going to build the 8b because i already have a tanny, and driveline made for it. So, i figured i should just rebuild everything and get the car on the road. Like you said its got good bones just needs refurbished!! Thanks again for the gauge panel!!
  14. moparnate
    moparnate
    from minnesota
    this car oozes with cool, cant wait to watch the build.
  15. rusty valley
    rusty valley
    ****** and drive line are the same for the 59ab, just unbolt the front ring off the trans and then the ****** goes on the 59ab. 8ba's are a tight fit in model 40's because the belt and pulleys got farther away from the block to make room for the distributor. its been done, but tight. some folks put all the early parts on the 8ba block to shorten it up again. change the cam to run a crab dizzy, and then the early water pumps, and heads go on too. some food for thought
  16. Spencer Caldwell
    Spencer Caldwell
    So this is the inside of the ******. Any ideas???[​IMG][​IMG]
  17. rusty valley
    rusty valley
    its looks a little crusty, but it does have the later "39" style synchro with the slot way to the rear, and not in the center. i would take it apart and see how bad the rust is. individual parts are expencive and you may find another whole ****** for less, but tear it down to see first. i suggest buying the book from vanpelt sales, you will be glad to have it. the later gear sets are harvested from 40-48 side sift (3 on the tree) ******s, that are common and cheap. they come in two ratios, one with a lower first and second, identified by the front gears in the case 29 teeth on the cluster, and 15 on the input shaft, or the more preferable 16 input, and 28 cluster for a little taller 1st and 2nd. buy the book, tear it down, its easy. http://www.vanpeltsales.com/ some times parts can be had at ebay too .lets see the top of the shift cover to see if you got the good one
  18. Spencer Caldwell
    Spencer Caldwell
    I will get pictures of it. The guys mention he installed zephyr gears but I will have to count them when I dis***emble it.
  19. NewGuyOldFord
    NewGuyOldFord
    I have two 48 ford car ******s just laying in my garage if you need anything. Cool project. BART.
  20. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Go to Costco and buy a couple gallons of cheap white vinegar. Don't know what it would do to syncros, but the steel will come out looking new.
    Nailhead A-V8 and loudbang like this.
  21. Spencer Caldwell
    Spencer Caldwell
    Here is the shifter!!![​IMG]
  22. rusty valley
    rusty valley
    looks like the good double detent 81A . you saved 150 bucks right there
    Spencer Caldwell and loudbang like this.
  23. Spencer Caldwell
    Spencer Caldwell
    Alittle update for the guys who are helping me... I started with the front suspension trying fix the issues ordered all the new parts. So hopefully that will be done soon. I got a new engine that wasn't sitting outside for 20 years with the heads off. That will be taken to the machine shop to get punch out and rebuilt. I am rebuilding the transmission while the motor is away. Thanks everyone for the help!!!![​IMG][​IMG]
    kidcampbell71, expavr, ls1yj and 3 others like this.
  24. MMM1693
    MMM1693
    Great score! Good luck with your build and have fun!
  25. dumprat
    dumprat
    from b.c.
    Be careful soaking cast iron in vinegar. I turned a set of Johnson lifters into chalk that way. A good soak in solvent is probably a better idea.
    On steel vinegar works fine. But mol***es works better.
  26. neatoldclassics
    neatoldclassics
    from Montana
  27. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Sweet five window....
    Spencer Caldwell likes this.
  28. Itchy-Pit
    Itchy-Pit
    Watching, Congrats!
  29. Jake Sippl
    Jake Sippl
    from Detroit MI
    this is looking like it's going to be a good one. definitely subscribed!
