Hot Rods A new project - 1941 Ford Shop Truck
Discussion in 'The Hokey Ass Message Board' started by the-rodster, Oct 11, 2016.
  1. the-rodster
    the-rodster
    Exhaust manifold fresh off the gas grill...
    nunattax, PONTNAK123 and olscrounger like this.
  2. the-rodster
    the-rodster
  3. nunattax
    nunattax
    what edelbrock inlet manifold is that with the front oil filler tube?.thanks
  4. the-rodster
    the-rodster
  5. The37Kid
    The37Kid
    Truck is looking real nice, I've got the exact same pile of parts to build my '39 out of. Good luck with all the wires, I don't understand that stuff. Bob
  6. the-rodster
    the-rodster
    For some reason, I really enjoy wiring.
    Rich
  7. rd martin
    rd martin
    from indiana
    looking really good!
  8. 36couper
    36couper
    from ontario
    I will be wiring my 40 truck soon. Is there a reason why the wires are coming out high on the firewall? I'm not being a smart-***. Just curious and I'd do the same when the time comes for me to run the wires.
  9. treb11
    treb11
    That's where the factory wires come through. There is a neat rounded cover that goes over it.
    Sent from my SM-G950U using The H.A.M.B. mobile app
  10. Chaz
    Chaz
    THIS is how old trucks should be rebuilt!!!! Great taste, great execution!
  11. joel
    joel
    The cover is the same as 40 p***enger car
  12. the-rodster
    the-rodster
    It's how Henry intended :)
    Ford Farmer likes this.
  13. The37Kid
    The37Kid
    Sure is enough of it for two headlights and directionals.:confused: Bob
  14. 36couper
    36couper
    from ontario
    I
    I guess mine was welded over sometime in its life.
  15. 1940rpu
    1940rpu
    Truck is coming along great! Any chance that you could post the part numbers for the Flywheel, Clutch, Pressure Plate and Throw-out Bearing that you used to mate the NV3500 to the Gen 1 two piece seal SBC? I think that you contributed to a different thread that talks about that combo but I was hoping you could share part numbers. I am headed that direction with my '40 coupe and it would be nice to use a known formula. Looks like the shifter ends up in a great location.
  16. the-rodster
    the-rodster
    I didn't keep track of part numbers.
    For the flywheel and starter, I just looked for 1970 Camaro 350, 168 tooth.
    For everything else, clutch, pressure plate, throw-out bearing, slave cylinder,
    master cylinder is all 1994 Chevy pickup stuff.
  17. Looking really good. What did you end up doing with the PCV valve?
  18. the-rodster
    the-rodster
    I was looking at valve covers on Ebay and found this set, super nice, and none of the corvette guys were bidding
    on it because one cover had been modified for the Offy breather. Then it occurred to me, buy the valve covers, seal the breather and then drill a hole in the side for PVC. So that's what I did.
    Fordor Ron likes this.
  19. 1940rpu
    1940rpu
    Thanks t-rod
  20. the-rodster
    the-rodster
    Made a new shifter for the 5 speed.
    joel and Hamtown Al like this.
  21. the-rodster
    the-rodster
    The truck is fully wired except the headlights and taillights...
    speed v8, RICH B and Hamtown Al like this.
  22. the-rodster
    the-rodster
  23. the-rodster
    the-rodster
  24. the-rodster
    the-rodster
    I didn't realize that the fan sits so high on a SBC equipped 40 Ford.
    So, I fabbed up a shroud...
    RICH B likes this.
  25. the-rodster
    the-rodster
    Front-end sheetmetal mock up..
    Everything fits.
  26. the-rodster
    the-rodster
    Now, the next problem.
    The grill is kinda beat. It's broken at all four corners, and missing a chunk of the middle.
    I had no idea that these were no longer being reproduced!
    Good ones are few and far between and $$$$$$$.
    I just got some Super Alloy 1 from muggyweld.com, we'll see how the repairs turn out.
  27. The 39 guy
    The 39 guy
    So here I was thinking "oh they still make those grills " then I download this and notice old back order Bob is out of them again. The other thing is I noticed the price has gone up $500.00 since he put out the 40 ford catalog just 3 years ago. I hope your repair project goes well. Please show the process.
  28. 1-SHOT
    1-SHOT
    from Denton
    There use to be a company that made a adapter to drive the fan off the crank shaft
  29. nunattax
    nunattax
    $1249 is a bit rich for me
  30. nunattax
    nunattax
    thatgrill is not too bad.one step at a time.
    RODIST likes this.
