Projects Something from nothing. 29 roadster build
Discussion in 'Traditional Hot Rods' started by wheeldog57, Oct 8, 2016.
  1. wheeldog57
    wheeldog57
    I had a spare support so I used it.
    It was a wee bit wide so I sliced, hammered and welded it.[​IMG][​IMG][​IMG]
    Sent from my E6810 using The H.A.M.B. mobile app
  2. wheeldog57
    wheeldog57
    Fabbed up the p*** side tonight, came out pretty good I think[​IMG][​IMG][​IMG][​IMG]
  3. wheeldog57
    wheeldog57
    Stogy, Jet96, kidcampbell71 and 4 others like this.
  4. wheeldog57
    wheeldog57
    OLLIN, Stogy, Jet96 and 4 others like this.
  5. sloppy jalopies
    sloppy jalopies
    guess I missed her ! ... bummer.
    It is at this point that I like to trim off the harder curved trunk gutter and replace it with a home made gutter that follows the quarter's radius down to the floor where I drill a drain hole which I drop a screw with lock washer into, water drains around the washer but not much gets back in...HIH.
    mike bowling and biggeorge like this.
  6. 42˚18'N 83˚09'W
    42˚18'N 83˚09'W
    Ron, the next time you want to dimple a panel like this try drilling a small hole in the center first then put your dimple in. You should find the metal will move much easier. Please note the hole will also get larger so I stress "small hole". See ya in the spring...
  7. wheeldog57
    wheeldog57
    Thanx for the tip ****
  8. wheeldog57
    wheeldog57
  9. attitudor
    attitudor
    from Finland
    It's been a while when I was here but I just read the whole thread. Cool car, good work.
  10. wheeldog57
    wheeldog57
    Thanking
  11. wheeldog57
    wheeldog57
    Been working crazy hours for WAY too many days now. Today is day 37 in a row-13hour days. I can't wait to get a few days off to sneak into the hideout.
    I need to finish the bodywork on the roadstah, put a rebuilt generator, swap the short rear tires for 7.50s, and add a two pot intake. That'll probably do it for this year. I got the car registered awhile back so I plan on driving the **** out of it and just enjoying the car.
    brEad, Jet96, chryslerfan55 and 2 others like this.
  12. wheeldog57
    wheeldog57
    I did score a neat old helmet at the swap Sunday morning (I snuck out of work for two hours, don't tell)[​IMG]
    Stogy, brEad, kidcampbell71 and 6 others like this.
  13. avachace
    avachace
  14. avachace
    avachace
  15. wheeldog57
    wheeldog57
    So I need to thrash on my car next couple of weeks.
    I was accepted to race in NJ this June. This year I will be way more prepared.[​IMG]
    Stogy, Jet96, Nailhead A-V8 and 9 others like this.
  16. Mikel50
    Mikel50
    wheeldog57 likes this.
  17. ramblin dan
    ramblin dan
    Great pics. Making your own parts. That's what hot rod building is what it's all about to me. Anyone can buy parts. You just made this your own!
    mike bowling and wheeldog57 like this.
  18. mike bowling
    mike bowling
    You gotta make custom parts to fit a guy this big into a Model "A"! Lol DSCN2989.JPG
  19. sloppy jalopies
    sloppy jalopies
    do you have to "****er" a guy that big to get him IN and OUT ?
  20. wheeldog57
    wheeldog57
  21. nunattax
    nunattax
    when I grow up I will get a nice side by side double garage like that
    chryslerfan55 and wheeldog57 like this.
  22. wheeldog57
    wheeldog57
    Haha I out grew this garage already. We ALL want more garage space!
  23. nunattax
    nunattax
    easily done my garage is a double , 40x13 internally one space behind the otherif I had the width id have built a side by side u lucky devil
    biggeorge and wheeldog57 like this.
  24. sloppy jalopies
    sloppy jalopies
    24' by 32' ... was a barn when I built it... now it is pathways !
    go wd57 go !
  25. oldrodder43
    oldrodder43
    Well WD57, you sure did what you labeled the build, "Built Something Our Of Nothing", and then some. Hat's off to you.
    brEad, wheeldog57 and 48fordnut like this.
  26. wheeldog57
    wheeldog57
    Pulled out the roadster today to meet it's brother from the same father[​IMG][​IMG]
  27. biggeorge
    biggeorge
  28. wheeldog57
    wheeldog57
    Cut out of work last two days. 10 hrs instead of 13. Right into the garage I went. I had to secure the body to the frame and subrail. Last year it was sheet screwed and wired.
    So I lined up the cowl, doors, and quarters. Now both doors open, yay!
    Mounted a new panel below the trunk. Tomorrow is rumble lid time.
    chryslerfan55, patmanta and brEad like this.
  29. nunattax
    nunattax
    that's a pretty picture
  30. T&A Flathead
    T&A Flathead
    Looking good. Wish I was headed back to jersey to see it.
