Technical late 31 coupe mild chop
Discussion in 'Traditional Hot Rods' started by Flop, Sep 9, 2017.
  1. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Beautiful work as usual Flop! Thanks for sharing.
    You started with a really clean canvas. Looks like someone's Rod project began with the purchase of a very straight restored car?
  2. Rex_A_Lott
    Rex_A_Lott
    Always enjoy seeing good metalwork, thanks for posting.:)
  3. mcsfabrication
    mcsfabrication
  4. topher5150
    topher5150
    It's dangerous letting me look at builds like this.....I get ideas going, then I try them, then I "F" something up majorly
    Dino 64, Jugornot and Denns1989 like this.
  5. That is the working description of hot rodding. Keep screwing it up until you finally get it right.
    subneil56 and Jugornot like this.
  6. 55Deso
    55Deso
    from Wyoming
    Looks great!
  7. Flop
    Flop
    Dino 64 likes this.
  8. Joliet Jake
    Joliet Jake
    from Jax, FL
    It would be great if I could get my hands on one of those front visor pieces you made! Great job!
  9. spanki
    spanki
    from valley
  10. spanki
    spanki
    from valley
    volvobrynk likes this.
  11. spanki
    spanki
    from valley
  12. bryanyeskie
    bryanyeskie
    from Hixton
  13. 41 C28
    41 C28
    I like it keep us posted please.
  14. Looks great. Nice job on the chop.
  15. Flop
    Flop
    Thanks guys . Probably the nicest original car I will ever have the chance to cut up . Not one patch in the car all original steel .
  16. dinglebarry
    dinglebarry
    In this case less is more.
    The conservative haircut was the way to go. The metal work/welding is quite impressive
    Sent from my SM-G550T1 using The H.A.M.B. mobile app
    Flop and nunattax like this.
  17. 1lucky1
    1lucky1
    from Morgan NJ
    The Walden insert you used,is it for a 32,Did you have to trim it,Looks great,Are you bringing the piece you made to Hershey,Thanks Lucky
    Flop likes this.
  18. nunattax
    nunattax
    sure is looks great and its still a usable car well done flop.moderators take notice
    Flop likes this.
  19. Flop
    Flop
    Yes I plan on bringing some . It's an A insert and yes it needs trimmed on each side .
  20. 1lucky1
    1lucky1
    from Morgan NJ
  21. Never2low
    Never2low
    Any chance some will make an appearance in the cl***ifieds?
    Perhaps with shipping to Michigan....;)
    Flop likes this.
  22. Happydaze
    Happydaze
    Great job as always. I'd be interested in the details of making the roof panel removable, or more crucially the attachment method!
    Chris
  23. Never2low
    Never2low
    That's what I was wondering as well.
    My first thought was simple threaded studs welded underneath, that would slip through holes drilled into the ribs, then nuts and washers.
    It might not look super clean, but should function, depending on headroom.
  24. 31 Coupe
    31 Coupe
    We use PEM type clinch studs for this type application in our sheet metal cabinet work.
    Probably not ideal for a painted panel (could crack the paint when tightening them) but they would be excellent for a vinyl covered one.
    http://www.pemnet.com/fastening-products/studs-and-pins/
  25. Ron Amittone
    Ron Amittone
    I love that insert.i would like to buy one.
    Ron from alameda ca,94501.can you ship one to me
    Sent from my SM-G955U using The H.A.M.B. mobile app
  26. Ron Amittone
    Ron Amittone
