Technical ‘32 dash for model A recommendations
Discussion in 'The Hokey Ass Message Board' started by Dino 64, Feb 15, 2018.
  1. Dino 64
    Dino 64
    from Virginia
    Time to get a 32 dash for my 31 coupe. Who’s the best source for it ?
    Thanks in advance.
    lothiandon1940 and chryslerfan55 like this.
  2. Brookville Roadster makes a steel `32 dash that's just the lower part that you combine with your stock A dash rail..... i have one in my `30 coupe and `28 sedan
  3. Dino 64
    Dino 64
    from Virginia
    Thanks, are you satisfied with the quality ?
  4. WTF really
    WTF really
    My we see?
  5. norms30a
    norms30a
    I welded the Brookville lower to the A upper, I think it is good quality 64 004.JPG
  6. Mo rust
    Mo rust
    I use stock 32 dashes in Model A's and they are easy to install. A pickup dash just fits a coupe or sedan or you can use a 32 sedan/five window dash if you add about 3/4 inch to the ends.
    Dino 64 likes this.
  7. Dino 64
    Dino 64
    from Virginia
    norms30a and lothiandon1940 like this.
  8. Dino 64
    Dino 64
    from Virginia
    Sounds cool, do you have a pic ? Thanks
    lothiandon1940 likes this.
  9. WTF really
    WTF really
    Looks good thanks
    norms30a likes this.
  10. shortypu
    shortypu
    I used the one from speedway and it fit pretty good. IMG_3684.JPG IMG_4267.JPG
    383deuce, Hot Rod Nut, bct and 2 others like this.
  11. Model A Gomez
    Model A Gomez
    I did the same thing as "norms30a" and mounted my ignition and light switches under the dash on each side of the steering column.
      143 KB
      229.4 KB
      158.2 KB
    norms30a, lothiandon1940 and Dino 64 like this.
  12. Dino 64
    Dino 64
    from Virginia
    Looks great! Did you have to fabricate the transition between the two ? Thanks for the pics [emoji106]
  13. chopndrop
    chopndrop
    How much room is left between the new dash and stock tank with these? Enough to mount gauges without having to cut up the tank?
  14. Dino 64
    Dino 64
    from Virginia
    None, the stock tank has to be removed.
  15. Model A Gomez
    Model A Gomez
    All I did was cut the dash molding along the square edge using about 3/4 inch edge and weld it to the Brookville panel and drill the mounting holes. I used machine screws to pull the holes in like the factory panel counter sink and a little body work.
    Dino 64 likes this.
  16. Dino 64
    Dino 64
    from Virginia
    Just Gary likes this.
  17. sponge
    sponge
    from Austin tx
    I used a brookville and it fitted like a glove. brookville all the way I say.
    Dino 64 likes this.
  18. Dino 64
    Dino 64
    from Virginia
    Thanks guys, just ordered mine from Brookville
  19. Mr48chev
    Which Brookville lower are you using, the one sold for 30/31 or the "universal" one?
    Dino 64 likes this.
  20. Dino 64
    Dino 64
    from Virginia
    It’s the one for a 30-31 coupe. I spoke to Pete, if it’s wrong, it’s his fault [emoji15] Got a HAMB discount too[emoji106]
  21. Mr48chev
    Thanks, I need to order one. Thanks for the heads up on the Alliance discount too.
    Dino 64 likes this.
  22. Dino 64
    Dino 64
    from Virginia
    No problem, just tell them your user name, guess they check with the boss. It’s 10% discount.
  23. Russ B
    Russ B
    Got mine from Snyder’s and it was an easy fit behind my cabriolet dash rail, and it accommodates many instrument panels.
    soonrodder and 48fordnut like this.
  24. Dino 64
    Dino 64
    from Virginia
    I think they get them from Brookville. Love that gauge cluster. Looks like a Plymouth ?
    Thanks
  25. Dave Friend
    Dave Friend
    Hi
    I left the stock tank in my 30 coupe. plugged the fuel guage hole and drilled hole on front of tank for fuel sender. put 32 dash in front and full set of electric auto meter gauges. I will try to find pic
  26. chopndrop
    chopndrop
    Dave, did you find pictures of your dash?
