Technical Oldsmobile window woes
Discussion in 'The Hokey Ass Message Board' started by gbgh, Feb 15, 2018.
  1. gbgh
    gbgh
    image.jpeg Got this very solid Cutl*** Wagon , mechanical work well on on
    It's way. One minor problem ! Doors do not work from the inside. Replaced the latches, , made the Exterior door handles much better. Not so much inside! Any help greatly appreciated
    Bruce Fischer likes this.
  2. karl share
    karl share
    Pull the door trim off and check what the rods or linkages do when you operate the handle, could be as simple as a retaining clip fallen off or broken.
  3. gbgh
    gbgh
    I wish...
    Everything is correct, and mechanically functional. Odd that both doors just don't quite disengage from inside only....
  4. Texas57
    Texas57
    On Fords it's possible to install some of the linkage on the wrong side (P***enger door vs driver's door), with the results being what you're describing. Ask me how I know......I just can't remember what exact part it was. Maybe that could have been done on your olds. Just a thought.Your post heading mentions window woes, but your post talks of door latch problems??
    What did you replace the latches with? Is it all 4 doors, or just the fronts?
  5. squirrel
    is there an adjustment on the remote control? like slots where the mounting bolts go, and you need to pull it forward to take up slack?
    If you post some pictures of the door, showing the linkage, we might be able to get some ideas. A few words don't paint much of a picture :)
  6. gbgh
    gbgh
    Trying that this weekend....
  7. Boy. Gbgh.I like your wagon. Bruce.
  8. Terrible80
    Terrible80
    Well if the exterior works well, I'd ***ume an adjustment would get the inside working. Maybe parts switched side to side as mentioned , or tighten up / bend something to get the play out. Could be wear, but I'd think the drivers door would be worse than the rest. Back doors good?
    Sent from my LG-TP450 using The H.A.M.B. mobile app
  9. BJR
    BJR
    Your wagon gave Bruce a woody!
  10. AGREED!!!!!!!!!!!!!!! LOL.
    BJR likes this.
  11. gbgh
    gbgh
    Can't have it!
  12. gbgh
    gbgh
    Back doors are fine. Working on it as we speak
  13. Oh gbgh.I figured that. Have fun with it. LOL. Bruce.
  14. ol-nobull
    ol-nobull
    Hi. Google might be your friend on this. Search for front door latch adjustments for that model wagon. It might surprise some how many of today's auto "technicians" cannot fix anything without doing that first.
    Good luck, Jimmie
