Hot Rods Shifting issues
Discussion in 'The Hokey Ass Message Board' started by cool37, Feb 18, 2018.
  1. cool37
    cool37
    from SoCal
    Okay Gents....
    Have a 350/350 combo with an idit column. Going down the road if I hit a bump or jump on the gas it shifts to a lower gear. Have checked the fluid and the linkage...all good. What else could cause this? Something in the column?
  2. 56shoebox
    56shoebox
    Broken trans mount? Sometimes the vulcanized rubber on the trans mount will tear.
  3. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Down shift cable adjustment off a little?
    KK
  4. cool37
    cool37
    from SoCal
    Will check both.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    You didn't exactly say if the shifter lever dropped. Did it?
  6. cool37
    cool37
    from SoCal
    Lever Dropped a little.
  7. Boyd Wylie
    Boyd Wylie
    post a picture of your shift linkage please.
  8. GordonC
    GordonC
    Motor mount?
  9. cool37
    cool37
    from SoCal
    See pictures...
  10. Boyd Wylie
    Boyd Wylie
    With the rod running straight to the transmission,when the engine/trans rocks from a bump or acceleration it is forcing the shift arm to downshift.
    Johnny Gee likes this.
  11. Johnny Gee
    Johnny Gee
    from Downey, Ca
    To further add. The weight of the rod going down to the trans and the shift lever it's self are on gravity's side. Does the shifter have a detent? or I should ask does it have a non stock design that allows N D 2 1 to just float between one another without any sort of lock out? A visual example being...... [​IMG]
    Frankie47 likes this.
