"Build" My 1935 Ford 5 Window Coupe... Chopped & Channeled!
Discussion in 'The Hokey Ass Message Board' started by TWO9FORD, Feb 19, 2018.
  1. TWO9FORD
    TWO9FORD
    So I picked up a complete 1935 Ford 5 window coupe in East L.A. at the end of last year to teach myself how to build a Traditional Hot Rod.... Car was in decent shape minus the floors and frame being rotted and the motor was shot....
    Here's how I got her out of a closed down shop...
    EVL401, spurgeonforge, ABONES and 2 others like this.
  2. TWO9FORD
    TWO9FORD
    Removed the gl***, floors, and fenders...
    Working on the chop lines...
    Went for it and chopped it!!
    Playing with the heights and angle...
    Probably not the "correct" way to chop it... didn't want to chop the pillars...
    ABONES, Stogy and chop job like this.
  3. TWO9FORD
    TWO9FORD
    Frame was shot!
    Picked up a 1940 Ford Frame in way better condition minus the front crossmember, which I was able to salvage off the original frame...
    Working on the roller.... new drop axle, lowering spring front n rear....
    Picked up a 1950 Ford 239ci 8BA motor..... dropped it in...
    spurgeonforge, ABONES and Stogy like this.
  4. TWO9FORD
    TWO9FORD
    Body is Chopped and about ready to be removed from the frame...
    20180124_160755.jpg 20180129_105933.jpg Did all the work myself so I had to find a way to pull the old frame and mount the body on the new one...
    Body is on the new frame...
    EVL401, brEad, spurgeonforge and 3 others like this.
  5. TWO9FORD
    TWO9FORD
    Louvered deck lid...
    Starting to take shape... Body is Channelled and has a slight lean forward.
    Working on the front end... lights, shocks, hood, grille...
    New short radiator mounted...
    Making some wild zoomie headers....
    EVL401, brEad, spurgeonforge and 2 others like this.
  6. 41rodderz
    41rodderz
    from Oregon
    WOW !!! Was not sure I would like a 26 chopped but man that has a Bonneville salt flat look. I am impressed . Nice work.:cool::cool:
    ibflyin and TWO9FORD like this.
  7. chop job
    chop job
    from Wisconsin
    Wow you learn fast that is one sweet ride. Very nice work!
    TWO9FORD likes this.
  8. brady1929
    brady1929
    Nice chop
  9. hfh
    hfh
    from Western MA
    Looks great. Are you putting the fenders back on?
  10. vtwhead
    vtwhead
    Wow, you got yourself a "hot rod" there fella! Nice work, takes a bit of guts to start a project like that.....you did real good!
  11. Petejoe
    Petejoe
    from Zoar, Ohio
    Good work.
    Looks like a fun project.
  12. bskustoms
    bskustoms
    from Aloha, Or.
    For a home project, couldn't ask for better workmanship. Keep up the great work!!!
  13. TWO9FORD
    TWO9FORD
    No. Going to keep it like it is. I do have the fenders but there not in the best condition.
    Thank you! Its been a learning experience....
    Thank you I appreciate that!! Not sure if I just threw caution the the wind or was ignorant to what all was involved.... but im glad I did and even more glad to start seeing the end to it.... if there is an end. lol!
    Thank you! Hoping to learn with what I have and start getting some better quality tools.... I figured the stuff I have is better then what hot rodders had back in the 40's/50's....
    brEad likes this.
  14. deuce1932
    deuce1932
    from Australia
    excellent work. !:)
  15. TWO9FORD
    TWO9FORD
    Ordered some 750-16 tires for the rear, should be here any day....
    Next step is to finish wiring it and fire it up!.... then the floors, windows, steering box, and a ton of loose ends!
    spurgeonforge and ABONES like this.
  16. I think that will look great without fenders ! I have a 36 that I want to do fenderless.
  17. TWO9FORD
    TWO9FORD
    Yeah I am a big fan of the fenderless hot rods.... they just look mean.... I thought about trying to run the fenders but wanted that salt flat racer look..... I like the look of the 36 slammed, chopped, with fenders....
    ABONES likes this.
  18. Any more on this build?
