Hot Rods Speedway Motors Radius rod split kit question...
Discussion in 'The Hokey Ass Message Board' started by RPU Rick, Feb 19, 2018.
  1. RPU Rick
    RPU Rick
    Greetings,
    I would like to go to my local NAPA and purchase a pair of tie rod ends such as used in the Speedway Motors Radius Rod kit. However...they need a part number! Can someone tell me a part number and/or the correct vehicle to ask for? I plan to machine my own bungs.
    Thank You in advance.
    Rick.
    Chucky likes this.
  2. Unkl Ian
    Unkl Ian
  3. RPU Rick
    RPU Rick
  4. Mr48chev
  5. Corn Fed
    Corn Fed
    If you are making your own bungs, step up from the 11/16" car rod end to the 3/4"-16 truck rod end. The part number of the 3/4" is ES150R (Moog & others). They are used on a variety of 3/4 or 1 ton trucks.
  6. Model A Gomez
    Model A Gomez
    11/16-18 is early ford' tell them you need right hand thread tie rod end for a 48-64 Ford 1/2 ton pickup. That is how Speedway lists them.
  7. kasselyn29
    kasselyn29
    why not get them from speedway ncp 2692241 is napa number three times as much at napa
  8. Blues4U
    Blues4U
    from So Cal
    I didn't notice anger or frustration in the OP, just asking for a part # or year/model vehicle. Seems like a reasonable question to me.
    46international and Fordors like this.
  9. RPU Rick
    RPU Rick
    I'm not mad, no progress to be made if one is mad. I called my NAPA with my needs and was told if I had a part number, an example or the year/type of vehicle the search would be simple. I like to buy local..will pay more if it helps my home town. I am in business too...and I appreciate when customers come to me as opposed to an outside source. Thanks for the feed back and info, all has been well received.
    Rick.
  10. Unkl Ian
    Unkl Ian
  11. Unkl Ian
    Unkl Ian
    3/4-16 might be easier to get a tap for.
    46international likes this.
  12. Good thought
  13. uncle buck
    uncle buck
    Exactly . The 11/16-16 Tap is an uncommon size. Speedway sells them too, which you are trying to avoid. Take a look at a NAPA # ES150R . It's 3/4-16 thread and fits '65 Ford F100 and should be easy to find. The 3/4-16 tap is T-110 NAPA. Be careful not to get left hand thread tie rod ends too. Also remember you need a make tapered hole to seat the stud into so it doesn't rock in the hole and shear on you
  14. roundvalley
    roundvalley
    There is a left hand thread and a right hand.
  15. old ford tie rod ends 11/16-18 Moog ES416L for left hand thread and ES416R for right
  16. 56don
    56don
    Lets not get started down that rat hole again. There have been numerous long threads about that subject. There is no winning that one, something we must live with nowadays.
  17. mike bowling
    mike bowling
    The rat hole has been deleted- I was just relating to the OP's story. I'll say 2 Our Fathers, 2 Hail Marys, and go without food and water for 3 days. (It's not easy being Irish Catholic.)
