Customs 1938 Zephyr 4dr sedan to 2dr kustom convertible conversion
Discussion in 'The Hokey Ass Message Board' started by SKOTY CHOPS KUSTOMS, Jan 30, 2018.
  1. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    Got to put some time in tonight making the p***enger side convertible top mount surface. 20180208_203400.jpg 20180208_204300.jpg
    dwollam, kiwijeff, ClarkH and 7 others like this.
  2. cretin
    cretin
    I'm planning to do an early style Westergard inspired custom. With some other ideas spliced in.
    I also came across that '54 you're finishing up on instagram, looks bad*** dude.
  3. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    Awesome, sounds like rad car. Look forward to seeing it. Thanks buddy, car should be out in a few months
    Sent from my SM-N920T using The H.A.M.B. mobile app
  4. mike bowling
    mike bowling
    You making two of everything? Your work is really top shelf (you tired of hearing that lol) Stunning transformation.
    SKOTY CHOPS KUSTOMS likes this.
  5. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    Thanks buddy, it's nice to hear and really motivates me. I appreciate the positivity alot.
  6. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    Pretty stoked, my convertible parts showed up today. I still need to extend the doors and quarters to match the stock 2 door dimensions [​IMG]
    dwollam, Stogy, kiwijeff and 4 others like this.
  7. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    Got to play with the zephyr over the weekend, had to pre heat and weld nuts to the hinge bolts to break them free and get them out so I can start extending the doors, quarters and get my convertible windshield section installed. Soon enough there will be no traces of the 4 door sedan. [​IMG][​IMG]
    dwollam, williebill, kiwijeff and 7 others like this.
  8. James D
    James D
  9. el Roach
    el Roach
    Wow! You are definitely a talented man Mr. Chops!
  10. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    Thanks buddy
    chryslerfan55 and el Roach like this.
  11. Amazing what "desire, talent, and determination" add up to when turned loose. Beautiful work.
  12. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    Thanks buddy
  13. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    Spent some time tonight cutting out the original 4 door sedan windshield section so I can install the 38 Zephyr convertible windshield section. [​IMG][​IMG][​IMG][​IMG]
    dwollam, lewk, Nailhead A-V8 and 10 others like this.
  14. el Roach
    el Roach
    I bow to the Master of Metalwork!
  15. philo426
    philo426
    Yep the dude has awesome metal working talent.Has a concept in his mind and his hands transform it into a reality!How cool is that?
  16. ClarkH
    ClarkH
    Just went through the whole thread. Stunning. Look forward to more.
  17. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    I took a coach building cl*** awhile back and it opened my eyes and mind to not create my own barrier and to just get to doing it, when you get stuck or mess up you learn the most. I truly believe if you want it bad enough you can make it happen.
    Sent from my SM-N920T using Tapatalk
  18. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    Thank you buddy, I still have a lot to learn and look forward to those experiences
  19. SR100
    SR100
    Which cl*** did you take?
    chryslerfan55 and Turbojoe71 like this.
  20. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    I went to Wray schelins in Boston and then have been mentored by another coach builder by me
    Stogy, chryslerfan55 and SR100 like this.
  21. vtwhead
    vtwhead
    Well, all i have to say is that you are a "quick learner" for sure. I am beyond amazed at this project and your skills!
    And i should say that I am very thankful that you are posting your progress for us mortals to review.
    Stogy and chryslerfan55 like this.
  22. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    Thank you buddy, I have p***ion, pride and a vision pushing me. Someday I'd like to build myself my own version of a delahaye out of aluminium
  23. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    Got the 38 Zephyr convertible windshield section cut down and somewhat mocked up, need to trim back a few spots and get everything perfectly lined up so I can weld it all in. Pretty exciting for me to see this in place. [​IMG][​IMG][​IMG]
    dwollam, lewk, kiwijeff and 10 others like this.
  24. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    Today I was able to get the Convertible windshield section welded in and I figure while I was there might aswell cut it down, I chopped down 3"[​IMG][​IMG][​IMG][​IMG][​IMG]
    dwollam, Stogy, lewk and 5 others like this.
  25. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    Pretty crazy how much lead is on this stock convertible pillar, I went to melt off the lead so I can weld it together and discovered the lead was actually holding it together in that section. Sheet metal was toast. Looks like I will be making some new pieces to fix this and glad I caught this now because after it's painted that would ****[​IMG][​IMG][​IMG]
    dwollam, Stogy, chryslerfan55 and 6 others like this.
  26. Weedburner 40
    Weedburner 40
    Is that where the factory weld was?
  27. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    No I had cut that section out, I have another pillar from the sedan I can use parts of it to replace what's bad.
  28. 1-SHOT
    1-SHOT
    from Denton
    Never seen that much lead in a windshield post before unless some one tried to cover something up.
  29. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    I've talked to a few friends that have convertible also that chopped them and they said there's where like that also. The pillar from bottom to top is all lead on both sides. Crazy, the story is that lincoln took some coupes off the line and made them convertibles. Not sure if that's 100% true but I could see that.
    dwollam, kiwijeff and chryslerfan55 like this.
  30. SKOTY CHOPS KUSTOMS
    SKOTY CHOPS KUSTOMS
    from BAY AREA
    This is the other side before I cut it and exposed the stock weld where they added the convertible top section. Pretty crude how this was all done factory. [​IMG]
