Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Paul
    Paul
    Editor
    I have been wanting to start another build lately,
    another Model T based, Olds powered late '50s early '60s styled car
    this one will take design cues from the first T buckets like Grabowski's Lightning Bug and Tommy Ivo's T.
    the body will start with a 1923 Model T touring, which I do have
    and a shortened Model A pickup bed that I will have to find.
    the ch***is will be based on a Model A frame,
    a V8-60 tube axle with fabricated four link similar to Norm's
    an early Olds engine, stick transmission and Olds rear.
    probably the '58 J2, '37 Roadmaster 3 speed stick and an Olds 9.3 with 3.08 posi
    all these parts because I have them.
    this thread may literally take years
    so be patient I will update as work progresses.
  2. Paul
    Paul
    Editor
    I picked up this body at The Early Bird Swap Meet in Puyallup last Saturday
  3. mikeallcars
    mikeallcars
    Keep us posted good luck on the build
    Stogy and Paul like this.
  4. Paul
    Paul
    Editor
    today I pulled the skin off the wood inner structure 20180221_152455.jpg 20180221_152622.jpg 20180221_152635.jpg 20180221_163312.jpg 20180222_135312.jpg 20180222_135318.jpg
    winr, Stogy, kidcampbell71 and 7 others like this.
  5. Paul
    Paul
    Editor
    and did a rough mock up with vice grips to see what the inside proportions will look like
  6. Paul
    Paul
    Editor
    'haven't decided if I will keep the square panel between the doors like Norm and Tommy did
    or remove that panel to give the body the curved bottom like a regular roadster
    28Hud, Stogy and Sancho like this.
  7. Paul
    Paul
    Editor
    the name was already painted on the rear when I got it
    it might as well stay for the time being..
    28Hud, Stogy, Sancho and 1 other person like this.
  8. A Boner
    A Boner
    Looks like there is an opportunity to do a slight stretch. You might want to sit in it before you get too far.
    Greg Stokes, 28Hud and Paul like this.
  9. junkman8888
    junkman8888
    Agree with a *****. Nothing worse than building a car you can't fit in. My recommendation is to stretch the cowl and use a dropped floor, that way you sit "in" the car, not "on" it. For some inspiration you can look up the David Thacker T-roadster, 2004 Rodder's Digest. Best of luck with your project.
    Greg Stokes and 28Hud like this.
  10. vtwhead
    vtwhead
    I will follow along....always interesting watching Paul doing his thing
    Paul likes this.
  11. dirt t
    dirt t
    I like it, I like it !
    Paul likes this.
  12. Paul
    Paul
    Editor
    next phase in mock up,
    set clamped together body on stock A frame
    with Olds 9.3 rear and Ford V8-60 front axles
    and dirt tires
    with '49 Olds engine and LaSalle transmission
    wheel base will likely stretch a little at front with suicide front
    frame will come down a little with a kick at rear (adding to current frame/housing clearance)
    body will be channeled depth of frame max.
    engine will come down a little in relation to frame
    tires will change, these were handy and bolted up.
    engine will likely be either a '58 371 with J2 tri power and 3 speed stick
    or '60 371 with dual fours and early T10
    something to look at anyway and mental shift components on..
  13. Paul
    Paul
    Editor
    three quarter rear..
  14. I'm in!
    Looks like you've done this once or twice
    Stogy, kidcampbell71 and Paul like this.
  15. Paul
    Paul
    Editor
    'thing about mock ups is you see so many possibilities.. like
    maybe in keeping with the name it will stay up high and get a blower on the late 371..
  16. That's why there is a mock up
    Paul likes this.
  17. Paul
    Paul
    Editor
    ok, here is the same 303 but with later heads and blower on top..
    fordman1, don colaps, brEad and 7 others like this.
  18. Stogy
    Stogy
    Hmmmmm me thinks the 49 version because of balance...the blown version engine pulls the eye to it in an almost overpowering way...and that may just be why you like it...but thats the fun of it all as you say throw it together add this n that sit back and go Hmmmmm
    Just thinking out loud...great stuff underway...@Paul
    After looking and staring at the 2 choices you have put forth either has merit so you have a tough decision with either choice being a winner.
    sko_ford, 28Hud and Paul like this.
  19. Dick Stevens
    Dick Stevens
    subscribed!
    Paul likes this.
  20. Paul
    Paul
    Editor
    phone walk around..
  21. Stogy
    Stogy
    Very convincingly nice...you have me thinking like the wind @Paul...what grille are you thinking?
    Great video...;)
    Paul likes this.
  22. Paul
    Paul
    Editor
    Grill choice will be dependant on which build style I decide on.
    Right now I'm thinking T,
    That would work with an Ivo style bucket,
    or the drag roadster, Gr***hopper? style.
    I do have a very crusty chopped '32 shell though, if it goes Lightning Bug style.
    sko_ford and Stogy like this.
  23. It's so good already.
    When I see the blower the word "Hairy" comes to mind.
  24. swade41
    swade41
    from Buffalo,NY
    Pretty cool so far
    Stogy, 28Hud and Paul like this.
  25. Hitchhiker
    Hitchhiker
    If you don't put a blower on this thing, I will be very disappointed...
    I have a NOS T grill if you wanna go that route...
    Cool build as always
  26. vtwhead
    vtwhead
    following along.....I like it Paul!
    Paul likes this.
  27. pitman
    pitman
    V-belts or Gilmer?
    Nice!
    Paul likes this.
  28. Paul
    Paul
    Editor
    V belts would be cool,
    2" Gilmer might fit best,
    and should work if it's not too "hairy"
    Stogy and kidcampbell71 like this.
  29. pitman
    pitman
    With a muffled motor, a toothed gilmer sounds mean!
  30. Mr. Mac
    Mr. Mac
    I used a 34 chev grill cause I like things that are different and because my wife bought it at a garage sale:) You would be amazed how many people never notice it's not a 32 grille.
    I also used the 4 bar with tie rod ends like back in the day. You have a kool build going on Paul.
