Projects Glass '32 5 Window
Discussion in 'The Hokey Ass Message Board' started by Splitbudaba, Feb 6, 2017.
  1. daveh1932
    daveh1932
    from UK
    Thanks, I’m very pleased with the seating position and steering wheel location now. They are on tracks but I like the seat as far back as possible as I like my legs stretched out when I’m driving. The only other tweak I need to make is to move the throttle peddle.
    It’s a 4 point roll cage and was installed very tight to the roof and sides to be as unobtrusive as possible and was a very nice job. The only problem was that it was too tight and the front posts were touching the doors which would prevent then from being trimmed. I did consider removing it. However, having been in a fairly major accident with my gl*** 3 window a couple years ago I decided to keep it and have it narrowed as I have experienced how little protection you get in a gl*** rod. It is currently in a workshop having this done together with the rear exhaust sections being modified so that I can lower the back end as it sat too high in my opinion. I’m hoping to get it back tomorrow.
    I’ve also changed the centre caps to the no-name aluminium type as I wasn’t very keen on the plastic ones that came with the wheels
  2. big duece
    big duece
    from kansas
    As much as I LOVE torq thrust wheels, I really like the look of your 5w with the slots like in your avatar.
    chryslerfan55 and Splitbudaba like this.
  3. Splitbudaba
    Splitbudaba
    Good to know. I think I might do the cage in mine, just for the safety. I haven't mounted the seats yet, and have a little wiggle room front and back. What size tubing was used for your cage? I might run Bonneville in the future. They have 2 cl***es for hot rods that mine could fit into. I think there is a 135 mph cl*** and a 150. Might be a great bucket list item to do at the young age of 70. Time will tell!! Great pic, two sets of wheels are fun, you could even mix and match styles. No rules!!
  4. daveh1932
    daveh1932
    from UK
    it was a difficult choice but the Torque Thrust Originals did it for me. The slots looked great but were very 70’s, I prefer 60’s styling and my aim is to gradually give it a 60’s make over.
    Splitbudaba likes this.
  5. daveh1932
    daveh1932
    from UK
    That would be fun and something to aim for after the house build. I’m not sure about the tube diameter, I will check it out when I get it home tomorrow but it’s quite substantial. Only one set unfortunately, the slots had to go to help fund the Torque Thrust’s. Rod parts are at a premium in the UK due to import costs and few homegrown parts. The other decision to keep the roll cage was that I became a grandfather 16 months ago and I want to take out my grandson out in it as much as possible when he’s older and had seat belts fitted to the cage for safety reasons.
  6. Splitbudaba
    Splitbudaba
    AGREED, I have 2 sets of torque thrusts, street long haul radials and the cl***ic bias front cheaters for the rear.
  7. Splitbudaba
    Splitbudaba
    Congrats, my kids are 25 (Steph) and 23 (Bryan), they say no way to grandkids, but I bet that will change, I remember saying the same thing, over and over. Now look, can't imagine life without them!!!
  8. DDDenny
    If there is any thought to your coupe seeing dragstrip or Bonneville action; I'd look at the rollbar requirement that would be the tougher of the two to p*** tech. inspection.
    Only two numbers to be concerned with, tube diameter and wall thickness.
    Much easier to do now than later.
    Haven't seen a rulebook for some time but 1&3/4"x.134 wall mild steel would seem reasonable for the speeds you are planning on running.
    Here is a response from Rooman on a similar discussion.
    https://www.jalopyjournal.com/forum/threads/what-type-and-size-tubing.1025762/
    Another thing to note is that although the spec for mild steel calls for .118 wall, the commonly available HREW / ERW (seamed) tubing sold as .120 wall will usually not p*** as it may be as thin as .112/114. That is why any reputable builder uses .134 wall (and not because the tubing gets thinner on the outside of the bend as stated by buffaloracer). If you make it out of CDS (cold drawn seamless) that issue goes away but mild steel CDS costs almost the same as 4130. That said the 4130 has to be TIG welded while MIG is OK for the mild.
    Roo
  9. Splitbudaba
    Splitbudaba
    Thanks, I was planning on using NHRA rule book for my guidelines. Feel that would be the safe side. Mild steel would be my choice. Now to find the room for people, and their heads!!
  10. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    I've been going pouring over the rule book to design the roll cage in the '32. I'll be doing a funny car style double hoop over my head for a few reasons. First for helmet clearance (hoops front and back of the helmet), then safety (2 hoops gotta be better than 1) and lastly to incorporate the door hinge mounts into the upright of the forward hoop.
  11. Splitbudaba
    Splitbudaba
    My old Vette had a funny car cage, great for racing, but hell on the street. I have a letter form an NHRA tech source, informing me I can use half high braces going forward and aft to the frame from the roll bar as long as I put an X in roll bar with headrests if required. Granted it ain't no 6 second set up, but it's better than nothing.
  12. daveh1932
    daveh1932
    from UK
    i picked up the coup this morning and very pleased with the work carried out on it. It sits so much better now:
    here's before the work
    and after:
    I also checked the roll cage, it's 1 13/16th.
    I was thinking I needed bigger tyres on the rear but now the wheels are sitting snuggly in the arches I think they are just right. I want to eventually fit some red band tyres once all the other work is complete
  13. Splitbudaba
    Splitbudaba
    That sits just right! Changes the whole at***ude your car projects, bad ***!! Your running boards are almost parallel with the ground. Looks Great!! I've decided to build a rollbar to meet or exceed NHRA rules, in case I ever get lucky enough to have grandkids!! Thanks again for your help. Keep posting!
  14. 41rodderz
    41rodderz
    from Oregon
    Like your coupe in the advatar
  15. DDDenny
    Spot on!
    Looked fine before, did you just lower the back, change springs?
    1&13/16" is an odd dimension for round tubing, closest common here is 1.750, did you actually use a caliper or eyeball it with a tape measure.
    Dumb question time, is your tubing commonly called out in inches or millimeters?
  16. loudbang
    At the new height do you get rubbing on the inside of the front fenders?
  17. daveh1932
    daveh1932
    from UK
    The front wasn’t changed only the rear but no issues with tyre to fender clearance on full lock
  18. daveh1932
    daveh1932
    from UK
    Thanks, the coil overs were just relocated on to the lowest mount but I needed the exhaust modified as it was too close to the axle
  19. daveh1932
    daveh1932
    from UK
    Thank you I’m very pleased with it. It’s amazing how one small change can make such a difference, I just couldn’t live with it the way it was
  20. Splitbudaba
    Splitbudaba
    You have a good eye. The little things make all the difference, sets your car apart from the others. What next?
  21. daveh1932
    daveh1932
    from UK
    I’m giving the engine a bit of a make over as I don’t like the dress up goodies on it at the moment. Going for a more traditional style, finned ally parts, parts have been ordered and will swap them out when I get them, hopefully next couple of weeks. In addition to the steering changes it’s currently got a Unisteer rack which I’m going to change out to a Borgeson Vega box. In the photo of the steering wheel you will see a digital tacho on the dash. The rest of the dash is very cool with SW wings gauges, I’m going to replace the existing tacho with a matching clock to fill the hole and get a column mount tacho cup and SW tacho, the interior, the list goes on but I’m enjoying turning in to the way I want it.
  22. daveh1932
    daveh1932
    from UK
    I'm going to California for my holiday in June and hope to pick up most of these parts then
    rodncustomdreams and Splitbudaba like this.
  23. Splitbudaba
    Splitbudaba
    Sounds like you are a man who knows what you want. But with good taste. I plan on no chrome in the engine compartment, I want it to look like the engine came out of a 60's chevy, 327, and dropped right in the coupe. Just clean. My wife and I were discussing our vehicle needs for our new home. Well my faithful 2002 S10 goes bye-bye. we are going to look at a 2005 Suburban 4x4. Talk about from one extreme to another. Hope my depth perception hasn't gone!! I thought those Unisteer racks were unbeatable, just by dumb luck I put in the Borgeson Vega box also. Can't wait to get your input after you change the steering box. I'm sure you will be on the road way before me. My son bought me the traditional 5 gauge panel for my dash, plan on using SW standard gauges, (mechanical).
  24. daveh1932
    daveh1932
    from UK
    The engine sounds very cool and love that dash panel. The main problem with the Unisteer is that the turning circle is rubbish and much worse than a Vega box that’s the main reason I’m going to swap it out. I live in a very narrow lane and if I don’t set the coup up in exactly the right position when I pull out of the T Junction at the end of my road I can’t do it in one sweep! Here’s a photo of the engine as it is currently
    These are the air intakes that are winging their way to the UK
    Here’s another shot of my dash before I changed the steering wheel and column
    And the column mount tacho cup I’m going to get when I visit the US in June
  25. Splitbudaba
    Splitbudaba
    I must be getting old, that engine looks great but it's hard to keep it that way. I did not know the Unisteer had a limited turn radius. I see where that could be a pain, and embarr***ing when you must back up and start a turn again just to make it around a corner.
    Are you planning on getting different valve covers?
    I'm not sure where to put the tach(o) in my coupe. I have fond memories of a Dixco tach I had in my 57' chevy. I have seen some on Ebay. Not the one with painted stripes, just plane chrome.
  26. daveh1932
    daveh1932
    from UK
    Yes, it looks very good but not the style I’m after. I’m changing the valve covers, breathers, air filters and have a nice finned oil filter cover, the oil sump, and a few of the bolts on the engine such as header bolts etc
  27. Splitbudaba (and all you other guys) the car(s) on this thread rule!!
    daveh1932 - Make sure you carry LOTS of sun block as the last time I was at the June swap it was 50°C !!
    Carry on fellas..
    Dave
  28. daveh1932
    daveh1932
    from UK
    :cool: Thanks for the tip
  29. murpa
    murpa
    from .
    Congratulations on your retirement !!
  30. gregsmy
    gregsmy
    from Florida
    "daveh1932" I really like those seats. Do you have a link or seller information. Or the brand/model? I have looked and couldnt find any with the rounded back. Thanks
    rodncustomdreams and loudbang like this.
