Technical Foggy haze/stain on glass
Discussion in 'The Hokey Ass Message Board' started by 46binder, Feb 24, 2018.
  1. 46binder
    46binder
    from Kenosha,Wi
    Im trying to clean a windshield of a vehicle that’s been sitting outside for years, and it has a foggy area it looks like a stain with drip marks. It’s on the outside, I’ve tried razor blades, mineral spirits, vinegar, even polishing compound. It’s a little better, but still large and too bad to use in current condition. When water or gl*** cleaner is on it it’s gone, but when dry it’s back. Any ideas?
  2. wvenfield
    wvenfield
    Replace.
    da34guy likes this.
  3. Texas Webb
    Texas Webb
  4. john worden
    john worden
    from iowa
    Sounds like something has etched the gl***.
  5. 302GMC
    302GMC
    from Idaho
    Years ago the windshield doctor guys advertised polishing streaked w/s gl***. Maybe someone still does it ...
  6. Dave Friend
    Dave Friend
  7. BJR
    BJR
    Acid rain etched the gl***. Replace it.
  8. stuart in mn
    stuart in mn
  9. 56premiere
    56premiere
  10. 41rodderz
    41rodderz
    from Oregon
  11. choptop40
    choptop40
    Live with it....
  12. southcross2631
    southcross2631
    We had a bunch of police cars that were used for skid training. They ran on wet surface all of the time and the water got on the windows daily . The water fogged the windows and nothing we tried and we tried everything worked . We had to replace the windows when they got bad enough that it hindered the vision of the students. It permeates the gl*** and you can't get it out.
  13. MercDeuceMan
    MercDeuceMan
    from Indiana
  14. Speed Gems
    Speed Gems
    I've heard Oxyclean works on foggy head lights so you may want too try that.
  15. 46binder
    46binder
    from Kenosha,Wi
    I’ll try again but it sounds like I’ll need new gl***
  16. southcross2631
    southcross2631
    We tried just about everything . We had chemical companies coming in with every product you can think of. Razor blades ,steel wool , Rubbing compound wouldn't touch it . Would only leave scratch marks on the gl***. Once it is in the gl*** it won't come out. We even had a lab ****yze the gl*** and it soaks into the gl***. It was a major expense to change out all of the side gl*** in 40 cars.
  17. paleot
    paleot
    from louisiana
    Worked in a Refinery in S/W Louisiana for 33 years, all our vehicle windows would get etched from cooling towers and stacks. We bought a compound called Cajun New Gl*** followed directions and it worked great. Don't know if it is still out there worth a look.
  18. Engine man
    Engine man
    from Wisconsin
