History When did cross steering appear?
Discussion in 'Traditional Hot Rods' started by RPU Rick, Feb 24, 2018.
  1. RPU Rick
    RPU Rick
    Gents.
    If one is building a "Traditional AV8..." what would be the earliest build style one could ***ume and use a cross steer set up? i.e. "...it is a post war styled hot rod....that could have built as early as 19___"
    Thanks in Advance.
    Rick
    bct likes this.
  2. Rocky
    Rocky
    Classified Editor
    1937 fords....not sure about other makes.
    RPU Rick likes this.
  3. RPU Rick
    RPU Rick
    Awesome...so, an AV8 built post war/pre 1956, could indeed have cross steering and be "era correct'!
    Excellent...thanks!!!
    Rick.
  4. i think model T fords were cross steer?
    alchemy and RPU Rick like this.
  5. The37Kid
    The37Kid
    You are correct, that puts the build date back to 1908, maybe earlier, have to check on models N,R & S.:cool: Bob
  6. LOU WELLS
    LOU WELLS
    from IDAHO
    Ford 1935.....
    X38 and lewk like this.
  7. willys36
    willys36
    A loooooooong time ago!!
    Moriarity, dana barlow and LOU WELLS like this.
  8. DDDenny
    I thought it was 1971, the first year of the Vega.:oops:
  9. Pete Eastwood
    Pete Eastwood
    from california
    1901 Packard had cross steer , 4 link , panhard bar & transverse spring.
    So, there is nothing new !!!
    rpm56 likes this.
  10. sdluck
    sdluck
    LOL
  11. Sheep Dip
    Sheep Dip
    from Central Ca
    Cross steering was the only thing they got right on the Vega!
  12. sdluck
    sdluck
    One of the best drag cars
  13. VonWegener
    VonWegener
    While a lot of cars had cross steering the steering boxes of choice in the Hot Rod world were '56 F-100 because of the shorter column, Reversed Corvair for lighter cars and with the advent of street rodding in the late '70s the Mustang box and finally in the '80s the Vega cross steer. The Vega became feasible because Porsche 914s became available in the junkyards and with them came inexpensive u-joints and shafts to connect the Vega to a column.
    bct likes this.
  14. choptop40
    choptop40
    Not sure , cross dressers have been around since the renaissance ...
    TagMan and Spooner Clinton like this.
