Projects What are we working on this weekend?
Discussion in 'The Hokey Ass Message Board' started by FullsizedFordFeller, Dec 9, 2017.
  1. G V Gordon
    G V Gordon
    from Enid OK
    Soft plugs in the 348. Will get new paint, rebuild carbs, Edelbrock valve covers and just an overall cosmetic freshening up.[​IMG][​IMG][​IMG]
    Sent from my SM-G920T using The H.A.M.B. mobile app
    Stogy, 1947knuck, Paul and 2 others like this.
  2. Vanness
    Vanness
    Finishing up wiring.then roll bar (seat belt mount) and flaring front fenders(yay!).
    ...then football.
    1947knuck likes this.
  3. big duece
    big duece
    from kansas
    Finally got this panel put together. Made new engine turn face, and dipped it in alodine. Dash to follow soon. thumbnail (94).jpg thumbnail (92).jpg
  4. leon bee
    leon bee
    I opened up about 150 little bags and boxes to start sticking parts in this:
    1947knuck, triman62 and Vanness like this.
  5. Turbo26T
    Turbo26T
    The ch***is for my A Coupe project....Not exactly "traditional " , but I'm tickled with it..
    1947knuck and big duece like this.
  6. 27 Tall T
    27 Tall T
    from Butler Pa.
    Thanks,it's been a long time project
  7. ls1yj
    ls1yj
    from Kentucky
    I cut and modified my radiator supports, to allow the front cross member to slide forward, and still keep the radiator in front, on my model 40 coupe project
    1947knuck and Vanness like this.
  8. LM14
    LM14
    from Iowa
    Running cooler lines for the ****** in my '32 ch***is. First time ***embling coated/braided PTFE lines with AN fittings. I now have no skin on my thumbs. Time to get some brackets and mounts. Also made the hard line from the vacuum modulator to the back of the intake runner.
    SPark
    1947knuck and chop job like this.
  9. Flathead Dave
    Flathead Dave
    from So. Cal.
  10. JimSibley
    JimSibley
    IMG_1577.JPG IMG_1579.JPG IMG_1577.JPG Floor work and firewall box on my 41 willys
    ls1yj, 1947knuck and Elcohaulic like this.
  11. big duece
    big duece
    from kansas
  12. The37Kid
    The37Kid
    I'm going to spend the next two hours looking for misplaced stuff. :confused:Bob
    WTF really likes this.
  13. Made some brackets out of box section to mount little motorcycle bullet-style turn signals underneath the Model T headlamps - then filled in the gaps to make it look like a cast piece. Just a small thing but I like it.
    chryslerfan55 and 1947knuck like this.
  14. As you get older this is increasingly part of the project...
  15. RMONTY
    RMONTY
    Not car related directly, but I am finishing up the install of a nice little mini split heat pump and finishing up insulating and covering interior walls in the shop, and putting up some shelving so I can get organized and get the car inside to work on it. Summer will be here in no time and I will be nice and cool with the A/C so no excuses about it being too hot or too cold to work on the car anymore!
  16. lostone
    lostone
    from kansas
    even with 40 degrees and rain I did manage to install and check clearances on the bearing adapters I turned down to fit mopar rotors to the 37-48 spindles and they came out fine, I have .090 clearance between the pads and rotors so atleast I have one success this weekend !!
    now if I could manage to get the 440 pulled from the donor vehicle..... anybody free this afternoon ?
  17. HOTRODPRIMER
    HOTRODPRIMER
    Replaced the rear springs on the Deuce sedan & finally got the coupe fired off and was able to drive it down the road,thanks to the help from my pal Dave. HRP
    Gotgas, ls1yj and triman62 like this.
  18. seb fontana
    seb fontana
    from ct
    Months ago I took apart a McCullough chain saw that needed new fuel lines after only 30 years ...made the fuel lines and installed them but have been procrastinating putting it back together because the throttle linkage went flying and I know I'm going to need three hands to put it together...I am going to do ***embly while watching race; if the race starts as weather pretty wet in Atlanta as it is here in CT..Thats my story and I'm sticking to it..:rolleyes:
  19. zzford
    zzford
    I'm working on a public intoxication charge.
  20. 1947knuck
    1947knuck
    Got the guages and vega steering box mocked up on my sons 31 Model A. The steering wheel is temporary while we finish the final column adjustment. IMG_2405.JPG IMG_2401.JPG
    TBirdGirl26, loner2, Stebo27 and 6 others like this.
  21. chop job
    chop job
    from Wisconsin
  22. ls1yj
    ls1yj
    from Kentucky
    Made a stand for a train track anvil, ground top of said anvil, and started making cowl top for my coupe [​IMG][​IMG]
    Tim, chryslerfan55, grumpy32 and 4 others like this.
  23. G V Gordon
    G V Gordon
    from Enid OK
    More cleaning and paint prep. Had to set new valve covers in place, just 'cause.[​IMG]
  24. low budget
    low budget
    from Central Ky
    Produced, as in made curved gl*** for?:eek:
  25. scotts52
    scotts52
    ^^^That's what I'm wondering too^^^
  26. klawockvet
    klawockvet
    Getting the lights up and running on the 40 Tudor thats been in limbo since 2013. I see the light at the end of the tunnel and its not a train. Ignore the wheels, they were replaced today with Vintage Genies and Pirelli V rated Cinturatos. Out of 5 tires and wheel only one required weights to balance. Should be street legal by Monday evening. IMG_3139.jpg IMG_3130.jpg IMG_3133.jpg
  27. The37Kid
    The37Kid
    DSCF7236.JPG There is always something for next weekend. Bob
  28. Kenny P
    Kenny P
    Puttin’ in this...
    chryslerfan55 and lothiandon1940 like this.
  29. Knghtcadi
    Knghtcadi
  30. lothiandon1940
    lothiandon1940
    ...........Is that top getting a lace job?;)
