Hot Rods Rear panhard bar
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Feb 26, 2018.
  1. HOTRODPRIMER
    HOTRODPRIMER
    When we replaced the rear springs on the old beater this past weekend I noticed the bushings on the panhard bar were shot and as old as they are they were made of rubber I would like to replace them with something more durable like urethane bushings.
    anyone know of a good source? HRP
    chryslerfan55 and 3W JOHN like this.
  2. I'm not a fan of urethane as while it can be more durable, it also transmits shock loads and NVH more than rubber does. I know that when I altered the front suspension on my '64 Comet, Global West (my A-arm suppliers), they recommended NOT using urethane in place of rubber on a street car as the increased shock loads could break parts. YMMV....
  3. catdad49
    catdad49
    Energy suspension.com, should be able to find something close if you don’t mind “upgrading”.
  4. HOTRODPRIMER
    HOTRODPRIMER
    The sedan was built almost 30 years ago and sat a few years before being road worth but I suspect there is at least 26 years of wear & tear and the rubber is so worn part of the rubber is missing. HRP
  5. catdad49
    catdad49
    The ladder bushings on the A were the same way, basically nothing left but the metal sleeves. Replaced with prothane bushings from the above company. A little measuring and you should be able to find something.
    3W JOHN and HOTRODPRIMER like this.
  6. DDDenny
    So Steve, I take it you wouldn't recommend rod ends then!
    I know GW has been a player in the suspension game for a long time but I'd be suspect of them a-arms if they have no more faith in their products than that.
  7. Call your parts store ask for jeep front track bar bushings. See how close that is, 95% chance it's exact
  8. Nope, no rod ends... LOL. Global West was very specific in their recommendations. Their a-arms featured plastic pivot bushings, but that was actually an improvement over the metal-on-metal factory arm pivots. They had no opinion on the sway bar and lower control arm bushings other than to note that urethane would transmit more noise/harshness with little handling gain. They were specific in NOT recommending urethane at the shock bushings or the strut rods, as they had seen failures in both the strut rods and upper shock mounts on street cars. I'll note that I had multiple sway bar end link failures with urethane bushings until I replaced those with rubber. It will depend on the quality of the roads you travel; many of my local roads feature potholes and I stressed that to Global West when asking.
  9. The thing to remember is urethane was developed as a 'street replacement' for race-only metal bushings which generally won't survive day-in, day-out street driving, not to mention how much NVH you get. Urethane was designed to bridge the gap between rubber/metal, but does carry a price...
  10. Rocky
    Rocky
    Classified Editor
    I've gotten the orange ones from Pet&Jakes.
  11. Urethane bushing are a low compliance-high maintenance wear item.
    They are good, have their place and purpose and life expectancy.
    Ever wonder why they are so simple and easy to install/change?
    Hint: because they need changed often when they get pounded out.
  12. HOTRODPRIMER
    HOTRODPRIMER
    Anything beats rubber with no metal bushings. HRP
    3W JOHN and catdad49 like this.
  13. Petejoe
    Petejoe
    from Zoar, Ohio
    Those lasted 26 years.
    Might as well stick to the same thing unless you plan to stick around and har*** us for another 1/4 century.
  14. HOTRODPRIMER
    HOTRODPRIMER
    Rick,they have been there that long,lasted is another story.:rolleyes:
    I have a long term plan for my future but you know as well as I that we are not in charge of when we take the dirt nap.;) HRP
  15. DDDenny
    Friend of mine has a frame/suspension business and had some issues with bushings from one of his vendors, the durometer rating was too light and they were compressing prematurely so I know there are some options.
  16. thirtytwo
    thirtytwo
    Years ago I rember going into an off-road shop and they had bins and bins of urayhane bushings all different sizes etc , you may try that on top of energy and Pete and jakes also
    If you find the right I.D. If you know someone with a lathe ( even a wood lathe) a good sharp tool bit turns them down fairly ez
  17. I've done that, and it only works well with fairly hard durometer bushings. Freezing the softer ones will help, but too soft will just tear....
  18. HOTRODPRIMER
    HOTRODPRIMER
    I guess I'm going to have to remove the bar to figure the correct size but since the sedan is currently my daily driver for the next few weeks that ain't gonna happen until I get my everyday truck back. HRP
  19. HOTRODPRIMER
    HOTRODPRIMER
    BTW,I did go by the 4x4 center and they do have bushings of all types. HRP
    3W JOHN likes this.
  20. 325w
    325w
    My coupe has TCI bars front and rear. The front bushings gave up several years back. Called TCI and ordered front and rear bushings. Replaced the fronts but the rears are still holding up good.
  21. RICH B
    RICH B
    I would guess that a bar that old may have had Chev rear panhard bar sleeved rubber bushings; like on '58-'64 full size. Same kind Pete & Jakes used in their 4 bars to start with; until they found they "twisted" out too quick. I would guess their orange bushing would be the right size, although a little stiffer then the rubber bushings; easier to install, tho.
  22. HOTRODPRIMER
    HOTRODPRIMER
    Come to think about it I may have used a TCI panhard bar.
    They did appear to be a early rubber bushing. HRP
  23. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    I think urethane bushings are a maintainence item, like change every year on a daily, could go steel on one end of panhard, if that keeps ya on the road
  24. DDDenny
    You mean as in steel rod end right.
  25. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Yes, or machine a steel piece that mimics the urethane or rubber, they do it for rubber mounted Harley handlebars to get rid of super slop
  26. DDDenny
    Steel on steel might work in that application but not on something that pivots **x a day, EVERY day.
  27. pitman
    pitman
    Mind you, this is a scurrilous off-the-cuff, why not go with two relatively hard durometer rubber bushings? Each end of the bar would then offer ''compressed" resistance, when sized to fit.
  28. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Doesn't a panhard keep the rear located only. Or are we playing pin ball with our back tires? As far as Shock. How about A framed cars with uprights and kingpins along with there A frames pivot's. There's some solid stuff going on there?
  29. HOTRODPRIMER
    HOTRODPRIMER
    That's what it is designed to do and when I was under the car I had someone pushing the rear of the body side to side and there was a little movement in the rubber,I am under the impression the urethane would be far superior to the original rubber bushings but anything would be better than the ancient hard & split ones that are going to be replaced. HRP
  30. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I believe you have your answer. ;)
