Projects 1933/34 ford roadster project
Discussion in 'Traditional Hot Rods' started by Elvis100, Jan 13, 2018.
  1. Elvis100
    Elvis100
    Thanks getting close on these doors
  2. hotrodA
    hotrodA
    I'm in awe. You're nothing less than a miracle worker. I came very close several years ago to buying a SAR roadster body and selling my 5W body. Now I wish I had. Keep it coming.
    Elvis100 and loudbang like this.
  3. Elvis100
    Elvis100
    I started with three original doors and I’m putting together two pairs of doors (one door will be a reproduction) ...when they are all done I’m going to let a pair go to help fund the project.
    kidcampbell71 and loudbang like this.
  4. AngleDrive
    AngleDrive
    from Florida
    I knew that, just being an a..hole. You are doing a great job on your build.Hopefully I will get back to work on mine this year. The doors are the most important part to get right.
    kidcampbell71, Elvis100 and loudbang like this.
  5. Elvis100
    Elvis100
  6. nunattax
    nunattax
    did you treat the wood with any wood preservative
  7. Elvis100
    Elvis100
    I have the first pair dis***embled, preparing for a linseed oil stain.
    kidcampbell71, nunattax and loudbang like this.
  8. The37Kid
    The37Kid
    Just found this thread, what a great project! Saw a 33-34 Bonneville Roadster last month, build out of a 3Window coupe, doors are twice the length.:) Bob
  9. nunattax
    nunattax
    good job.is that what was done way back in 34
  10. Elvis100
    Elvis100
    I haven’t found a reference for what they did. Probably not linseed oil because of the cure time between coats.
  11. I sure wish your “extra” door was the other side....
    On second thought I probably couldn’t afford it anyway :).
    kidcampbell71, loudbang and Elvis100 like this.
  12. Elvis100
    Elvis100
    [​IMG][​IMG]
    Laid out and drilled the hinges...
    The hardware for installing each hinge are 2 flat head 2 1/4 inch machine screws using a special nut keeper, Bill Monzo makes these exactly like Ford did.
    Here is the back side with the nut keeper in place with lock washers and nuts.
    Two #12 one inch wood screws are used in the other two holes.
    I referenced again back to Ed Solari’s great resource for most of this information.
    orbitup, lewk, kidcampbell71 and 5 others like this.
  13. The37Kid
    The37Kid
    Love seeing detailed restoration work like that! Bob
  14. nunattax
    nunattax
    agreed.X2
  15. Elvis100
    Elvis100
    Attached the check strap guide plate. This is another of Bill Monzo’s amazing reproduction parts.
  16. The37Kid
    The37Kid
    Will the inside get primed, painted, and a coat of tar or am I getting ahead of things? Bob
  17. Elvis100
    Elvis100
    The plan is to give the inside a couple coats of red oxide and linseed oil on the wood. Then once they are swinging and all the body work is done I will probably give them the tar
  18. The37Kid
    The37Kid
    The first guy I worked for doing restorations back in the late 1960's always finished off the inside of things as good as the outside. I asked him why, and he said people see all that during the restoration and judge the quality of the work long before the car is finished. This is going to be a really nice Roadster. Bob
  19. attitudor
    attitudor
    from Finland
    Good work. Ever thought repairing 34-doors for business...?
  20. Elvis100
    Elvis100
    Thanks, I thought about it briefly, but realized I would make about 65 cents an hour.
  21. nunattax
    nunattax
    what about the job satisfaction
  22. The37Kid
    The37Kid
    I'm sorry, this is NOT traditional........................you sell off junk parts and keep the good stuff. :confused: Bob
  23. ratamahata
    ratamahata
    from Argentina
    Awesome work! Congrats! That's Red oak? In my country they called North American "Roble" It's present in some Furniture from the past century! Like the red oak, the French oak it's very similar... You know wine barrels!!
    Another excellent wood that came as a ship ballast was the longleave pine heart... 3' x 4' 3' x 6' 3' x 8' beams...
    And the American Ash... Maybe in some Model T body parts and wheels spokes... But the said Hickory wood is the Best...
    Enviado desde mi SM-G610M mediante Tapatalk
  24. Elvis100
    Elvis100
    Originally the 1934’s would have been Ash, but I like the red oak better. The grain really pops with a little linseed oil. The wooden frame I used as a template came from Argentina
  25. ratamahata
    ratamahata
    from Argentina
    Uff! Small world!
    bct, kidcampbell71 and loudbang like this.
  26. Elvis100
    Elvis100
    [​IMG][​IMG][​IMG]
    Did some work on the drivers door, replacing lacy metal.
  27. Elvis100
    Elvis100
    [​IMG][​IMG]
    Changed gears a little, worked on the steering wheel and gearbox is next. I got the steering wheel off Craig’s list on the California trip. Took about 2 hours of scrubbing, but it came out amazing.
  28. Elvis100
    Elvis100
    [​IMG][​IMG][​IMG]
    Finished the repair on the drivers door and did a final fit check on the wooden internal structure. Should be able to install the screws tomorrow, do the final sanding on the wood and apply the first coat of linseed oil stain.
  29. Roadsir
    Roadsir
    Thanks fpr posting these pics. I am envious of the build!
    kidcampbell71 and Elvis100 like this.
  30. el Roach
    el Roach
