Technical c4auto trans for a V8 260 5 bolt
Discussion in 'The Hokey Ass Message Board' started by sjs5764, Feb 26, 2018.
  1. sjs5764
    sjs5764
    Does anyone know if Ford EVER made, for ANY 1964 or other model year, a c4 3 speed Automatic transmission WITH a 5 bolt bell housing? Looking for one if they exist, for my '64 V8 260 with a 5 bolt bell housing. Any help would be greatly appreciated, thanks!
    Greaser Bob likes this.
  2. squirrel
    the google says yes.
  3. Yes, there was the one-year-only '64 C4 used behind the 289 five-bolt motors. Rare these days, they usually bring a premium price when you can find one. The 260 was only offered with the 2-speed auto...
    Clay Belt likes this.
  4. Yes I owned one came in a 64 station wagon. that had a 289 and C4 automatic. I sold it to a HAMBB member in Calif several years ago. The Price was $100 plus shipping. Only one I ever seen. they are pretty rare. you might post a wanted add in the HAMB cl***ifieds.
  5. Given some of the prices I see for these, it may be cheaper to swap to a later motor...
    I'll also note that the '64 bell only fits some of the later C4 trans ('65-69?), not all of them.
  6. 56sedandelivery
    56sedandelivery
    My girlfriend (wife now) had a 65 Rustang when we first met; there was a learning curve involved there with a Chevrolet guy and a Ford girl. 5 bolt C-4 and a 289; that car became my cross to bear. At one point in time, I bought a 63 Ranchero with a 260/2-speed auto; Holley 2 barrel, dual exhaust, and some chrome on the engine. It was a very responsive and fast little car, even with the 2-speed auto. A lot of parts got swapped over to the Rustang from the Ranchero; could't get my wife to drive the Ranchero, which was why I bought it. Don't discount the 2-speed if you can't find a 5 bolt bell. I am Butch/56sedandelivery.
  7. LM14
    LM14
    from Iowa
    Had a local ****** guy convert the 2 speed to a C4 a few years ago. Used a C4 valve body and kept my 5 bolt case and bell. He said we could also swap a later C4 ****** onto the 5 bolt bell. I'm not a ****** builder but his conversion worked fine!
    SPark
  8. 40 years ago, when they weren't so rare I gave one to a friend that needed one. I had bought and used the 5 bolt 289 and the ****** was just in the way.
  9. I still have a 64 5 bolt 289 4V engine it has the stick flywheel & bellhousing. same parts as a 260 has.
  10. 3speedoverdrive
    3speedoverdrive
    Yes I do, have one I pulled out of a 64 289 Fairlane recently, complete with flex plate and convertor and slip yoke. Was working fine. 20180226_162214.jpg Does have a leak where the shifter/ kickdown lever is located, needs a new seal. where are you located?
    Clay Belt and Hnstray like this.
  11. 66fora69er
    66fora69er
    I have one that I was running behind a 221 V8. It’s in great shape. Have torque converter and flex plate as well. Make me an offer. The bell housing was not cheap. Theres one on ebay right now for $550 (not mine)
  12. 3speedoverdrive
    3speedoverdrive
    I'll take $250 plus the ride for mine if your still interested.....
    Harold in Phoenix AZ.
  13. If you got a C4 you can get an adapter bell for about 400-600 bucks
  14. BillHilly
    BillHilly
    If you still needa bell let me know . Pretty sure i seen one in my storage unit today. I'll let it go cheap.
    porknbeaner likes this.
  15. sjs5764
    sjs5764
    I have found a 1964 Galaxie 500 sedan that has a 3 speed Cruisomatic transmission (Code 4) that I'm hoping to put behind my rebuilt V8 260 in my 1964 Fairlane 500 that currently has the original 2 speed Fordomatic (Code 3) in it. Both transmissions are confirmed 5 bolt bell housings. This should work...right?
  16. Yes most C4 automatic trans will fit behind this bellhousing. The flexplate might need some holes drilled in it to accept the c4 torque converter.
