Projects 26 T Roadster Pick Up build Thread
Discussion in 'The Hokey Ass Message Board' started by Blue One, Mar 27, 2010.
  1. Tim
    Tim
    from KCMO
    You got it on page 8 lol man you guys talked about painting that thing for like 30 pages lol
    Just says it’s from griffin, is it custom or off the shelf? Looks like something I might need down the road
    loudbang and brEad like this.
  2. Blue One
    Blue One
    from Alberta
    It’s custom built to order, basically a shorter A radiator.
    Once I cut down my rad shell I ordered the rad to the size I needed .
    loudbang, brEad and Tim like this.
  3. Blue One
    Blue One
    from Alberta
    And then, an exhausting exercise and there’s a partial exhaust system in place :D:cool:
    488A37E3-A85E-489A-B821-DC873CB6E93A.jpeg BBAF7A98-88F5-46C7-95C2-A7C4CBB3AB77.jpeg
    brEad, biggeorge, Stogy and 5 others like this.
  4. Six Ball
    Six Ball
    from Nevada
    I'm glad you said "exhausting" before one of us did. That is beautiful!
    loudbang and Blue One like this.
  5. tfeverfred
    tfeverfred
    WTH!? I didn't get any alerts to your thread!:mad: Everything looks great. She's coming together nicely.
    biggeorge and Blue One like this.
  6. Blue One
    Blue One
    from Alberta
    I think the notification system was down when the switch to the different server took place.
  7. Dick Stevens
    Dick Stevens
    If you select to watch the thread, it will notify you of new posts on those threads so you don't miss any updates!
  8. atch
    atch
    However, you have to check the "and receive e-mail notifications" box when you select watch the thread if you want to get e-mail notifications.
  9. loudbang
    And if you have already selected those options but not getting notification you selected go back and hit the "unwatch thread" then start over again with a fresh "Watch Thread"
  10. bobbytnm
    bobbytnm
    Shoot, its gotten to the point where I start drooling when I see the notifications...
    ...just knowing there will be some sweet eye candy in the thread updates....LOL
    Bobby
    loudbang, Blue One and 26 T Ford RPU like this.
  11. Blue One
    Blue One
    from Alberta
    Enough with the talk about notifications :D
    Back to it.
    I combined the mounting hardware from the Lokar shifter and mounted the new Gennie shifter.
    Gutted the Lokar stick and made an adapter to mount it on the Gennie shifter.
    Then I drilled out the Gennie shift knob and re threaded it to the Lokar’s 3/8-24 thread.
    While I was at it I did the same thing to a special shift knob ;)
    So now I have a gated shifter and no annoying push ****on in the knob. :cool:
    I decided to set up the Gennies neutral safety switch and found the perfect adjustment.
    Power for starting in neutral and park only.
    Setting up the switch I found that I had to make a .049 thick shim to get the adjustment perfect.
    I’m hoping to drive this thing this coming summer but man all this stuff eats time. :D
    88CF5403-2C74-4178-9CE0-7FC47E1EE5DE.jpeg DDAFEE8D-C36E-4426-9A4E-2F647117D7F3.jpeg 0350B610-B07F-4A27-AFE4-B23E69A567AB.jpeg 916E75E6-0711-49A8-8E00-053AC51EC5C2.jpeg 83D11D58-E525-4A79-978C-0B13C21F87C4.jpeg A23A66DF-5719-468B-B651-9DA5703F7FC5.jpeg 954EC934-5EEB-4A62-BCAD-8DE969D442E0.jpeg
  12. tfeverfred
    tfeverfred
    Looks great! Good move eliminating that push ****on feature. IMO, that's a weak point with those shifters.
    Blue One likes this.
  13. Blue One
    Blue One
    from Alberta
    I like the gated shift pattern of the Gennie shifter much better.
    I hadn’t even driven it and the Lokar was annoying me :D
    brad2v, loudbang and 26 T Ford RPU like this.
  14. 26 T Ford RPU
    26 T Ford RPU
    You have a very cool shifter:cool::cool:....I only have a push ****on American ****ter:( JW
  15. Blue One
    Blue One
    from Alberta
    Sometimes I feel like the tool man :D
    I searched for and ordered up a neat little inside and outside tubing reamer for deburring brake and other tubing.
    Inline tube, it came today and it’s a nice little tool. :cool:
    0EC94D87-41D9-4D9C-8F24-86ADF074173F.jpeg EE94F08F-97BE-4B31-A56A-7C7943DB00CF.jpeg 4678CCC5-C957-4C2D-BACB-8ACF1A53EF56.jpeg
  16. 26 T Ford RPU
    26 T Ford RPU
    That looks the bizzo. :cool: JW
  17. Blue One
    Blue One
    from Alberta
    Well, one step forward and 2 steps back as they say :D
    ***embling my exhaust system and experiencing the poorly made and poorly fitting flat faced V band clamps I used, I started thinking these damned things are gonna leak. :(
    So last night I put a strong light source into the tailpipes and turned out the lights in the shop.
    :eek: Light leaking out of the ***embled and tightened exhaust connections at both ends of the mufflers. :mad:
    Edit: Another test this afternoon,I put some duct tape over the ends and squirted a little bit of air pressure in , the ****** joints leak a lot, not just a little :mad:
    So, back to the drawing board, I will continue on with other things while I order up 4 of these Marman V Band exhaust connections.
    Of course I'll have to re-coat (ceramic) some of it :( Oh well :D
    https://www.ebay.ca/itm/MARMAN-FLAN...Band-V-band-NO-LEAKS-/262837735754?rmvSB=true
  18. tfeverfred
    tfeverfred
    Rechecking your work and repairing or replacing as needed, is part of the journey. Press on, man!
  19. The 39 guy
    The 39 guy
    Looks like a good tip on the Marman flanges. Thanks for sharing your failures,success's and solutions. Keep up the pace, Spring is just around the corner, even in Alberta.
  20. b-bop
    b-bop
    Spring may be just around the corner, but the corner is a long way away this year. This pic was a week ago, and since then we got another 10 inches of the fluffy stuff.
  21. b-bop
    b-bop
    Love your build Blue One. The detail you share is fantastic. Can't wait to see you on the Alberta backroads this coming year. :)
    loudbang, 26 T Ford RPU and Blue One like this.
  22. The 39 guy
    The 39 guy
    HMMM.....Well maybe I was a little optimistic b-bop, but the intent was to keep Blue One on the fast track to finishing his roadster.
    loudbang and b-bop like this.
  23. 57 Fargo
    57 Fargo
    Yup I just plowed the yard last night, we got eight inches in a day, I’m going to have snow piles until probably June....
  24. Blue One
    Blue One
    from Alberta
    :D The way I’m going I don’t know if I’ll make it.
    I spent most of my weekend clearing snow myself.
    C’mon spring :D
  25. 57 Fargo
    57 Fargo
    The only saving grace is even my tractor is H.A.M.B. era so I still get to play with old stuff, the bad part is I don’t have a heated shop to play cars in!!
    loudbang, brEad and Blue One like this.
  26. Blue One
    Blue One
    from Alberta
    The heated shop is most definitely appreciated.
    loudbang and Stogy like this.
  27. Blue One
    Blue One
    from Alberta
    I did actually get something done :cool:
    I built a bracket to hold my Tru cool transmission cooler tucked up under the transmission tail shaft at a bit of an angle to get some air flow.
    It will also serve double duty with a support bracket coming off of it for the front ends of the emergency brake cables :cool:
    C0BCD0FB-BB45-428D-BA84-E546D3BE6F2A.jpeg F0FADB31-BFB3-4270-A0DE-E88C305302E4.jpeg 2325DD7E-9061-45F0-A674-68DFFB243B90.jpeg
  28. tfeverfred
    tfeverfred
    Oh, that's very nice!
  29. Blue One
    Blue One
    from Alberta
    Thanks Fred once I get the e brake cable bracket done it’ll get a trip to the powder coater.
  30. Blue One
    Blue One
    from Alberta
    My 4 replacement Marman joints have been shipped to me. :cool:
    I'm all set up with fire blankets to cover all the pretty and shiny bits :)
    The saga can continue. :)
