Technical Diamond Back Tyres experiences Wide White radials
Discussion in 'The Hokey Ass Message Board' started by hudson48, Feb 28, 2018.
  1. hudson48
    hudson48
    I know there has been a lot of discussion here on pros and cons of tires but mainly on bias ply V radial ply.
    On my Hudson I have always used radials with wide whites. The last set of tires were some hybrid WW's from Vanderbilt tires,made in Mexico. They were supplied here from the same guy that imports the Diamond Backs and from memory he supplied these as he had no stock of DB's at the time. I didn't realise what a **** tire they would turn out to be and have lived with them.
    The car tended to wander a lot and had a vague feel to the steering as well as a t******* sound on lines and ruts in the road.
    We are getting the car ready for a road trip and as an experiment changed over the tires to similar size generic radials and Lindsay who is working on the car said the difference between the Mexican radials and the conventional ones was like chalk and cheese. Far better road handling, steering feel etc. So I am now looking at the DB 1 from the Aussie distributor .They are rated at UTQG 440 AB with a load rating of 1601lbs and speed rating of 97 which is 112mph. With wide whites they should be run at 40-44 psi.
    The current catalogue for Diamond Back shows the current designation as UTQG 460 AA which I guess is some improvement. I think the supplier here has some old stock he is trying to unload and my other option is to order direct and get the latest version. The Hudson will be coming to USA in April and I can do the changeover in LA at Huntington Beach before hitting the road for 5000mi.
    So after all this long winded explanation I wondered what experience others had had with Diamond Backs WW radials. I will be using a 215/70R 15 and hopefully with the 2.75 inch whitewall.
    Coker doesn't appear to do an acceptable tire in 215/70R15 with good ratings and no 2.75 inch whitewall.
  2. PONTNAK123
    PONTNAK123
    I have diamond back and they are great tires. I recently got cali tires and they are the same grade and process of making them as diamond back. cali tires are a lot less money and are a lot quicker to get. I will get cali tires next time.
  3. TagMan
    TagMan
    I've had several sets of DB tires, put lots of miles on them, and had no problems. White walls cleaned up well & stayed nice & white. Well worth the money, IMO.
  4. 5brown1
    5brown1
    I have cars with DBs and Cokers. I prefer the DBs. Their white walls clean up much easier and haven't yellowed.
  5. FrankenRodz
    FrankenRodz
    Agreed. I've always used DB, and went with Coker this time, and the quality of the white wall is poor.
    Also, DB will white wall any tire brand. I had Hankook truck tires on my '32 3-window. (Sorry, no Hamb-friendly pics, but you can check my website).
  6. Automotive Stud
    Automotive Stud
    I've had a set on my '47 that has been on there for probably ten years or better. They are still holding up nice, I would buy another set.
  7. I have not yet owned a set of Diamond Backs personally but I have put them on several cars that I have not owned and everyone has given me a good report on them ( my clientele is small and exclusive, not in my circle not on my list LOL).
    I am going to suggest that you got a ****py set and I hate to say that at all. I don't like to see anyone having a bad experience with anything car related.
    If it were me I would give diamondback some feedback on the tires that you purchased. They do welcome feedback on their tires and they are a family operation so whomever gets your experience is in the loop. This will probably not get you a new set but you just never know. ;)
  8. pat59
    pat59
    Been running Diamond backs for years on my off topic car. Great tires and I'm gonna order a couple more for the spring. (thanks for reminding me) :)
  9. PONTNAK123
    PONTNAK123
  10. V8 Bob
    V8 Bob
    I've been running WW DiamondBacks on my '51 for many years and will order a new set this year. When the '40 is re***embled, WW DBs will be ordered for it also.
  11. dirty old man
    dirty old man
    I bought my roadster as a mocked up but not completed project over 10 years ago, and it had a set of Coker/BFG bias WWW on it that the prev. owner bought new several years before then. They're still on the car and somewhat bumpy and ill handling as far as following grooves worn in the roads, etc. Going to replace them when I can afford it, planned for this year, but other, more urgent things have soaked up lots of cash lately.
    My plans are to replace them with DB because of the experience of one of my friends who had a set on a '46 Ford and curbed one enough to peel out a chunk of white rubber about 2'X3" in the sidewall (but still not down to black rubber) and it never peeled any further. He has since sold the car, an AFAIK, the guy, also an acquaintance and friend I don't see as often still has the tire on the car.
    This is enough, when added to how much better my '40 Ford coupe (with radial BWs) is at road manners, is enough for me that when I finally replace those on the roadster, it will be DB WWW.
  12. amodel25
    amodel25
    Have the second set of DB on my avatar now. Drove the first set for 25,000+ miles and 13 years. I was bragging about the first set to my buddy on a trip to the LSRU 5-6 years back. On the way home, I threw the tread off the LF tire. I replaced them with another set of DB and have 15,000 on them so far. Great tires, just need to keep track of the age and don't brag about them.
  13. Rckt98
    Rckt98
    If you are going to buy them in LA check out Performance Plus Tires in Long Beach.
    I have bought wheels and tires off them in the past, good service and prices.
    Good luck with your road trip.
  14. jimmy six
    jimmy six
    My DB's are on Coopers. Very happy. I also had them make the ww 3/8" smaller.. Not a problem for them.
  15. pat59
    pat59
    I believe that they make them when you order them, and that it takes a couple weeks to get them to you. So don't wait till the last minute. :)
  16. Dave Mc
    Dave Mc
    D B's I Likem a lot
    jim snow likes this.
  17. HOTRODPRIMER
    HOTRODPRIMER
    Our experience with diamond back tires wasn't too pleasant.
    2 out of 4 Michelin tires had the vulcanized whitewall split,the tires were about 2 years old when we noticed the problem.
    It doesn't effect the tires performance but looks like ****.HRP
  18. dirty old man
    dirty old man
    Danny, what tire pressure were you running in those Michelins?
  19. Roger O'Dell
    Roger O'Dell
    I have cars, more than 8. Several different brands with the diamond back white wall, some with the optional raised white outer.All great
    Special Ed likes this.
  20. HOTRODPRIMER
    HOTRODPRIMER
    Same question the people at Diamond Back ask,I told them I always run 32 PSI and check the tires on a regular basis,during the summer more often.
    They suggested a higher air pressure and they way they talked they inferred I ran the tires too low on air. HRP
  21. harleycontracter
    harleycontracter
    Where would be the best place to price DB's
  22. Great experience with them, wonderful people.
  23. jimmy six
    jimmy six
    I bought them ......from them shipped to my home.
  24. raprap
    raprap
    from Ohio
    I have them on my Chevy. Over 16,000 miles and still ride smooth, quiet and look brand new. 0219171420.jpg
    jim snow and CME1 like this.
  25. The 39 guy
    The 39 guy
    I am happy with DB'S, quality tire, WW's are easy to clean with no faults after two years.
  26. pat59
    pat59
    Diamond backs are great stuff.
  27. AngleDrive
    AngleDrive
    from Florida
    3 sets of DB's, no issues
