Projects Official Chrysler Flathead 6 W/ Dual Carbs Dual Exhaust Thread
Discussion in 'The Hokey Ass Message Board' started by Flat Six Fix, May 12, 2016.
  1. DOCWHIT
    DOCWHIT
    Nice Coronet!! Check out mine when you have time. It has the original 326 with 29800 miles & push****on ******. I'm going to follow you to watch your progress!!
  2. DOCWHIT
    DOCWHIT
    Where did you find that fuel block? I think I need one of those for my setup. Mike
  3. 64Kaddy
    64Kaddy
    from SoCal
    IMG_7667.JPG Just got my triple AOK intake this week. Mounting on a 1954 Windsor 265 engine.
    It'll be going into my 1940 Desoto coupe
  4. 55Deso likes this.
  5. harry37
    harry37
    My project has been stalled for about a year or so, but hearing that blown flatty run has me wanting to wrench on mine again. I think I will spend a few hours in the garage tomorrow. Thanks MoparMontana!!
    Heres a shot from when I first pulled it, and where I am at right now.
    tr_rodder, 55Deso, v8flat44 and 2 others like this.
  6. JOHN H EDGE
    JOHN H EDGE
    image.jpeg image.jpeg image.jpeg Love everyone's love for these lowly little motors but I'll tell you that I always get as much attention when I open the hood on my 52 Plymouth suburban as any high dollar show cars
  7. Early Ironman
    Early Ironman
    That is gorgeous!
    My first car was a 51 Plymouth Cranbrook 2dr sedan. Bought it from dad when I was 8. Have always preferred the wagons of this body style though. Think it’s that I just don’t care for the sedans from the B pillar to the rear bumper.
    But the wagons are sharp!
  8. Crookshanks
    Crookshanks
    Love this thread. Our family duo. ‘40 Royal and ‘39 Imperial, both been in the family since the ‘60s. 40 is running a 265 with OD and a high speed rearend.
    tr_rodder likes this.
  9. patmanta
    patmanta
    from Woburn, MA
    VERY NICE!
    I guess you don't run out of juice quick with those dual Optima 6v's run in parallel, eh?
  10. JOHN H EDGE
    JOHN H EDGE
    No problems with batterys also run a 6 volt posi ground alternator. My thought was if I ever decided to go 12 volt I'd just run the batterys in series
    patmanta likes this.
  11. Ratman1953
    Ratman1953
    Awesome thread! I got a Offy intake and a couple of Carter B&Bs I will be installing myself in a couple of weeks on my 53 Cranbrook.
  12. lonejacklarry
    lonejacklarry
    To the gurus: My question has to do with the exhaust and routing. I'm planning on a split header exhaust. I've been told by some that "know" that the exhaust pipe should be no bigger than 2" and the small mufflers should be as close as possible to the front to get the proper sound. Whattya think?
    My other question has to do with where the pipes exit. I'm not a fan of two tubes coming out next to each other at the back. On the other hand routing the other pipe to the left side and back would look a lot better. With about 110 hp I'm not concerned about equal exhaust pipe length but should I be?
    Thanks!
  13. JOHN H EDGE
    JOHN H EDGE
    I tryed to run true duals with my Fenton split manifold but the gas tank location created to much interference so I ran dual 2 inch pipes to the rear axle then y'd them and then ran 2 1/2 inch pipe over rear axle and exit in stock location with large stainless tip end. Had two gl*** pack mufflers staggered forward of the rear axle. Good sound and picked up some performance
  14. lonejacklarry
    lonejacklarry
    Thanks for the information, John. I'm going to have a rear center mounted gas tank so that would not interfere. I appreciate your input.
  15. 2redrovers
    2redrovers
    Hi guys, if any Australian flathead fans are looking for an engine block please get in touch with me. I've got one going cheap as its sitting in my workshop (SE Melbourne suburbs , vic). Previous owner had it rebuilt but not used. Engine number KEW2PF3610
    Cheers guys, keep up the top work. I've got a fargo but she won't be flathead powered when its eventually back on the road.
  16. Satyr
    Satyr
    Meet Deidre, she is the girl that takes ALL of my money, she is stock as of now. But I would love to give her what she needs to be just a little racy.... Time for me to get in the cl***room with some of you guys that know the tricks to make these flatheads run a little better..
  17. j hansen
    j hansen
    Late to the party......1948 Dodge Skärmavbild 2018-06-20 kl. 17.56.16.png Skärmavbild 2018-06-20 kl. 17.57.02.png
  18. 40desoto
    40desoto
  19. 40desoto
    40desoto
  20. DivingDane
    DivingDane
    from Australia
    its a long shot but do you still have the motor and do you happen to know the size? looking for a 265ci motor.
  21. 2redrovers
    2redrovers
    Sorry but it's long gone. Was a 251ci as far as I know.
  22. As far as I am aware no 265 ever came to Oz or were used here..........the best we got were the 250/251 in the Royals which were the "KEW" , which indicates that it is a 25" engine........the 23" engine was not that common in Oz use after WW2, most mopar sixes here seem to be variations of the 25" engine, 218/228 and the 250/251's..........although the 23" engine did get some use in the industrial applications as well as the standard trans car applications.........I had an ex Sydney Airport Tug 230 that I was building to use in a 41 Plymouth Coupe a few years ago but ended up selling the car and engine separately..........like a dope......lol..........andyd.
    tr_rodder and 2redrovers like this.
  23. Work In Progress
    Work In Progress
    Thought I posted here in the past but I guess not.
    Built my own dual carb intake and headers a couple of years ago. Modified a set of SBC headers and used 2 Webers. Really woke up an otherwise stock 23” 230.
    Started here
    Headers modified
    Intake time
    Finished
    tr_rodder, Uncle Ronn, 55Deso and 3 others like this.
  24. Fortunateson
    Fortunateson
    Nothing new happening in th eland of flathead Chryslers, Doges, Fargos, and Plymouths? How about DeSotos?
  25. Caprice89
    Caprice89
    My DeSoto is still in storage; waiting for his time on the lift. As soon as I have finished and sold the C10 Panel, my son and I will start the next part of the DeSoto journey.
    Sent from my online shouting device
  26. stanlow69
    stanlow69
    I`ve got my aluminum dual carb intake. A few carbs and this. Now I need to get my motor. IMG_20210117_0002.jpg
  27. rusty rocket
    rusty rocket
    2E9AC09E-3E94-4F5D-A5FA-774E936B9147.jpeg 2D8CE282-038B-48B4-956A-FE495B2BDBBA.jpeg I have neither a dual carb or duel exhaust but this ****er pulls hard. 236 cubes and an edmunds head in a 1475 pound car!
  28. Beepx22
    Beepx22
    On a constant search for parts for these engines. My 48 Windsor could use a wee more pep in its step. I do believe I’ve found a source for split headers but that’s about it
  29. Streetdemon
    Streetdemon
    from Shelby, TX
    Where have all the flathead folks gone????
  30. Baumi
    Baumi
