Technical SBC in a 1935-1940 Ford Chassis === BEST MOUNTS
Discussion in 'Traditional Hot Rods' started by The37Kid, Mar 2, 2018.
  1. The37Kid
    The37Kid
    Yes, I know it has been done a zillion times before But are there some motor mounts that are better than others? SBC with a 5 speed, 9 inch Ford, nothing special. Bob DSCF7034.JPG
    lowroller1 likes this.
  2. If style and ease of fabrication is important that I like a Hurst Mount. It does require a mid mount of some sort (ears off the back of the block/bell area) but they can be simple too.
    If I am using side mounts I like the ones used on '68 Camaro. They are cheap and easy to use unless you have steering box interference.
  3. manyolcars
    manyolcars
    I usually make my own and use an existing hole to bolt it on
  4. RICH B
    RICH B
  5. Pete Eastwood
    Pete Eastwood
    from california
  6. Clete
    Clete
    Rich B. nice looking install, where did you get the lower hose? it really fits well with the Hurst mount. I could use one on my 40 PU.
  7. ahewetson
    ahewetson
  8. Larry W
    Larry W
    from kansas
    Ch***is Engineering 2X
  9. olscrounger
    olscrounger
    ^^^^Ch***is Engineering in the ones I've built (12) New one starting will have CE as well.
  10. fatkoop
    fatkoop
  11. Dooley
    Dooley
    from Buffalo NY
    Hurst mount is traditional
    We took ours out in1985 after 25 years of it being there.
    I have the ch***is engineering ones now and I like them
    Both will work
    olscrounger likes this.
  12. low down A
    low down A
    anybody ever run a traditional mechanical fuel pump with a hurst mount?
    LOU WELLS likes this.
  13. RICH B
    RICH B
    If you use some of those SP-150 U-shaped gizs, Jeep mounts, a pump that you can clock the bowl, along with a little grinding; you can make it all fit. Functional; but not real clean looking.
  14. Weedburner 40
    Weedburner 40
    We make mounts for that combo.
  15. low down A
    low down A
    I was thinking about cutting a section out and welding a half round piece in. i'm not sure I follow what a sp-150 gizs is
  16. primed34
    primed34
    You would have to notch the front cross member for pump clearance.
  17. CE had the best biscuits,
    The other metal parts are pretty straight forward and hard to mess up.
    I've always wondered what they were or the real application.
  18. RICH B
    RICH B
    They are the mount spacers Hurst sold.
  19. topher5150
    topher5150
    how well does that "U" shaped piece of steel hold up?
  20. jeepsterhemi
    jeepsterhemi
    And there is the old functionnal but crude way..............good enough for the swapper in the sixties..........
  21. low down A
    low down A
    rich B those u shaped saddles are copies of the 40 merc mounts I've used those to mount a 59ab in a 33 frame. what i'm asking if you look at those pictures you posted of that hurst mount theres a block off plate bolted on the motor obviously a electric fuel pump is used.has anybody modified the hurst mount to make room for a mechanical pump
  22. 47ragtop
    47ragtop
    Yep !! I put 1 plus inch long spacers between the block and Hurst mount. Then you will need to remove part of the Horizontal part of the mount for the radiator hose to clear. The spacers were probably not the smartest thing I did ,but never had a problem. You can also use a 230 6 cylinder fuel pump which is smaller.Later Bill
  23. RICH B
    RICH B
    Piece of 3/8" steel like that is pretty tough, can't imagine it not holding up.
  24. D.Conrad
    D.Conrad
    From my experience, a mount that uses the early Ford biscuit sends engine vibration into the car. I like to use a mount that uses stock Chevy mounts. I've built my own and Pete and Jake's in a 40 Ford. The Pete and Jake's bolted right in.
  25. 40ragtopdown
    40ragtopdown
    This is what we use they use the stock chevy motor mounts and bolt in. 20170607_194956.jpg 20170923_144335.jpg 20170923_144605.jpg 20171124_141723.jpg
  26. my2nd40
    my2nd40
    from Tennessee
    Ch***is engineering.......always
  27. D.Conrad
    D.Conrad
  28. Smart62
    Smart62
    from UK Sussex
    Hi nice set up with the hurst mount. Did you have to use a mid mount too? If so any pics of it? I am building a 40 coupe with hurst mount and TH350 and am concerned about cracking the trans bell housing. Cheers.
  29. 40FORDPU
    40FORDPU
    A current '41 p/u I/m building..I've used Hurst mounts on 3 of these p/u's I've built.
    The37Kid likes this.
  30. RICH B
    RICH B
    That one used the original '40 side shift trans and rear, stock rear trans mount cushions.
