THE oldsmobile rocket 303 324 371 394 post to end all other posts, (lasalle related )
Discussion in 'The Hokey Ass Message Board' started by RocketDaemon, Dec 19, 2006.
  1. ROADSTER1927
    ROADSTER1927
    ,looking better all the time!
  2. Duke
    Duke
    Does not want to turn easy with a wrench on the front bolt. Might be the grease?
  3. vtwhead
    vtwhead
    you could put the balancer on and then add two bolts across from each other, get a longer bar and go across the two and see if you can rock that girl loose or do the same by flipping the engine onto the valley and crank from the rear of the crank
  4. ROADSTER1927
    ROADSTER1927
    You can also put a couple bolts ln the back flange of the crank and turn it from there. Also you may want to wipe the grease out and see if there is an obvious problem.
  5. Duke
    Duke
    I am trying to bolt the olds to the adapter to the early ford 3 speed. Are you guys using cap head Allen bolts or countersunk head Allens on the top adapter bolts? I am having issues sourcing either locally.
    Fortyfordcmm likes this.
  6. Paul
    Paul
    Editor
    Countersunk allen screws would be best.
  7. Duke
    Duke
    Where could I find those? Can’t seem to find them local or online.
    Thanks
  8. Dick Stevens
    Dick Stevens
    Sixhundred sixteen likes this.
  9. Speedy Canuck
    Speedy Canuck
    Funny, I ran into, and asked the very same question to a couple of Olds friends on Thursday night. Great minds...
  10. Duke
    Duke
    Have you found any in Canada yet? SB Simpson has them, but $25 Shipping.
  11. Duke
    Duke
    What length should they be?
    Thanks
  12. Speedy Canuck
    Speedy Canuck
    Not yet. Didn't have a chance to look this weekend. Will update you if I find something reasonable, and please do likewise.
    Off the top of my head, I believe 1".
  13. Dave Huelke
    Dave Huelke
    where can a guy buy a starter switcher for a 303 olds? do I need one for a 31 coupe on 32 rails?
  14. ROADSTER1927
    ROADSTER1927
    I do not know of a current supplier but call Ross racing engines, they have all sorts of olds stuff and you do pretty much need one for your project.
  15. Paul
    Paul
    Editor
    Are you asking about a starter change over to relocate the starter to the driver side?
    If so then they are where you find them.
    No one is recasting them.
    If you are using the stock location for the steering box you may have a conflict in that area.
    Another option is the mini starter as offered by Ross Racing and others.
    If on the other hand you are asking about the starter switch, just use a typical ignition switch.
  16. Sixhundred sixteen
    Sixhundred sixteen
    from Utah
    What do you guys use for a parts source ? I'm trying to find a clutch disc for a '51-56 Olds.
  17. Paul
    Paul
    Editor
    Centerforce 381040 Clutch Disc Fits 88-94 F Super Duty
    or equivalent, ***uming you are using the stock stick transmission.
    check spline diameter and count as well as total diameter.
    the Scout may look the same on paper but will not work, use the Ford
  18. Sixhundred sixteen
    Sixhundred sixteen
    from Utah
    Thanks Paul !
  19. Sixhundred sixteen
    Sixhundred sixteen
    from Utah
    Thanks. - Also; what do you use for a rear transmission seal these days ?
  20. vtwhead
    vtwhead
    I use a napa replacement 15041 around 4 bucks
  21. Sixhundred sixteen
    Sixhundred sixteen
    from Utah
    Thanks; appreciate that.
  22. martyk98
    martyk98
    from washington
    Hey Paul-can you tell me which engine Hilborn developed their 303-0-8 FI unit for? I tried calling Hilborn but their records don't go back that far and all the OG's are gone.
  23. jjjmm56
    jjjmm56
    from FL.
    Is there any aftermarket mechanical fuel pumps that will work with an early olds
  24. jebbesen
    jebbesen
    from Winona, MN
    You can run a mechanical fuel pump off a late 70s Buick v6. Not sure if there are any high performance ones or not for that application. There's 2 different Buick v6 pumps the outside will look a little different but one of them will have the right arm.
    gonzo likes this.
  25. jebbesen
    jebbesen
    from Winona, MN
    Screenshot_20180323-170353.png This is the one I think I stuck on to get it going.
    40FORDPU and gonzo like this.
  26. jjjmm56
    jjjmm56
    from FL.
    Do you know what kind of pressure it puts out, and thanks.
    49 olds likes this.
  27. jebbesen
    jebbesen
    from Winona, MN
    I haven't checked it but it's off a carbureted engine so probably a few psi. It works fine with the stock 4gc.
    40FORDPU and Paul like this.
  28. Freaky1
    Freaky1
    So I see the clutch plate questions above and I'm going to push that a bit farther.
    I'm putting a 4-speed Saginaw behind my 303 and due to space I'm going to run a hydraulic throw-out. Now I've found plenty of 11" ford clutch disks that have the center hole sized to fit the Saginaw. But then it gets hard because I've read that the hydraulics require the diaphragm style pressure plate over the three finger pressure plates. One of my Olds guys here said a Flathead Ford pressure plate will fit the stock flywheel. Great...except try to find a 11" diaphragm style Flathead pressure plate.
    Anyone know of any other, slightly more modern, 11" pressure plates that fit the stock '49 303 flywheel? If it's GM then I'm sure finding a clutch disk to match that will also fit the Saginaw will not be hard.
    On a separate note, the Henry J is finally getting some serious attention and I'll post an update soon.
  29. vtwhead
    vtwhead
    Can't you reposition one that would work with new holes in the flywheel ? or am I missing something here:confused:
  30. JOHN H EDGE
    JOHN H EDGE
