Hot Rods Somebody school me on tri five transverse setup
Discussion in 'The Hokey Ass Message Board' started by blacksheep55, Mar 3, 2018.
  1. blacksheep55
    blacksheep55
    from jasper ga
    Hey guys I just acquired my first 55 Chevy that I ever owned at 13. I tracked it down and bought it back. I have my other one about where I want it at, I race it with the southeast g***ers. I want to build this new/old one more mild and make it streetable. I have a 60s GM aluminum block 302 motor, magnesium wheels, 12 bolt, and a slew of other cool parts. I built everything from the firewall forward on my other one with parallel leads, but I love the look of the transverse spring setups. This car will be a black 150 with magnesium wheels so I thought a chrome transverse spring and axle would really set it off. I've never done one so I kinda want to get it straight in my head. Maybe pics? Anyone want to school me on what the cool setup is? Thanks. I'll post a pic of my current 55 that I built, we are about to letter it up next weekend. 0916171621.jpg
    RODIST, Deuces, clem and 11 others like this.
  2. manyolcars
    manyolcars
    28-48 Fords had transverse springs. They allow to much body roll for a 55 in my opinion
  3. They are simple set ups.
    A little difficult to forget everything you know and wrap your head around the spring being mounted with preload tension.
    What ride height are you after?
    What's the track width?
    Here's a 4" drop axle, you might want one that's straight if you want taller stance. You can always add a thru frame sway bar if the body roll is too loose.
    Deuces, Hombre and blacksheep55 like this.
  4. belair
    belair
    Epic paint.
  5. 56sedandelivery
    56sedandelivery
    I'm trying to read the name of the one in your avatar; Bad JuJu? Don't "overletter" the green, laced one; it's NICE just the way it is! In need of a cross ram? I am Butch/56sedandelivery.
    RODIST and clem like this.
  6. Black Panther
    Black Panther
    from SoCal
    Screenshot_20180303-223946.jpg Look up a '55 Chevy called Tabasco....April '67 issue of Hot Rod....one my favorites...had a chromed transverse leaf setup...
    Deuces, catdad49, 31hotrodguy and 2 others like this.
  7. thirtytwo
    thirtytwo
    I started building my 57 to SEG rules, just chopped the frame up to steering box using stock steering to a arm on top of spindle , will have a deadperch , I used 48 axle ," A" bones and 48 spindles where car sits now crank centerline is about 22"
    catdad49, RICH B, 31hotrodguy and 2 others like this.
  8. chevy57dude
    chevy57dude
    Trying to get my head around what 60's GM aluminum 302 block you have.
    If it turns out like the other car, you have a winner!
    Awesome paint, wheels, radius, headers, scoop, stance and at***ude. The short list.
  9. southcross2631
    southcross2631
    The weld em up people make a really nice torsion sway bar that would help control body roll.
    zzford and mad mikey like this.
  10. Terrible80
    Terrible80
  11. Welder series. Alliance venders too.
    Very nice folks and very nice stuff.
    Here's their sway bar kit in rear application , I took some creative license with it.
    A crafty fella could put it anywhere since it's a cut to fit design.
    Deuces, Hombre, WelderSeries and 4 others like this.
  12. mad mikey
    mad mikey
  13. DDDenny
    Damn East Coast guys!
    Dude, you beat me, I was about to ask the same question.
  14. Rusty O'Toole
    Rusty O'Toole
    Transverse leaf springs were mainly used by Ford up to 1948. Their sole advantage is cheapness, nothing else. In effect he got 2 springs for the price of 1 which adds up when you are building a million cars. In every other way they are inferior to a 2 spring setup which is inferior to IFS.
    They were used on g***ers because they were cheap, available, they got the front end up in the air and were a little lighter than stock IFS if they were made for the purpose.
    You would be better off the keep the stock front end and raise it. Even better, keep the stock front end and don't raise it. The only reason for raising a car in the sixties, was to get more weight transfer onto the rear tires. This was because the best drag slicks back then weren't very good, today we have tires that grip and drag cars are not raised up the way they used to. A raised car can get pretty squirrely at high speed and as speeds rose, too many raised cars were crashing.
    I am thinking about a fast car, with a primitive front end design, wonky steering, that has been jacked up, and has no front brakes, with a trap speed of 100+. In a car like that the question is not whether you are going to have a disastrous crash but when.
  15. dana barlow
    dana barlow
    from Miami Fla.
    Wow,you did get some info,some good some off an also some that don't know how Transverse leaf springs even work. So they just repete stuff they hear about how bad they are!
    A few things that are good but often over looked or they just don't know;
    When wishbones are slpit=they became a swaybar,so you now have limited roll.
    Another is lbs is less over IFS/good for racing.
    Most other facts I could list will likely piss off some that don't know**** but think they do,bottom line is Transverse leaf springs set up right,work very very well.
  16. thirtytwo
    thirtytwo
    Are you on the right message board?
  17. JOECOOL
    JOECOOL
    Dana Barlow is correct, they work great when set up right . I got in a big spitting contest on the tri five site over this . People who don't understand the radius rods and their relation ship to the front end when split are certain the cars will roll over on every corner. Here is the deal ,a tri five chevy with a properly set up tranverse spring will not roll any more than a stock suspended one with no added sway bar.
    I contacted several people who own ,race ,and drive these the street and they all just laugh .
    If you think its difficult to convince people of that try to tell someone that has ladder bars in the rear that he is wasting his money on a sway bar. Good luck on the build ,make sure you come back and let everyone know that it drives just fine.
  18. blacksheep55
    blacksheep55
    from jasper ga
    Thanks guys for the replies, I really love the look of the transverse setups and I wanted my new/old car to be different from my green one. I heard a lot of the same with the axle setup I have now with parallel leafs about the driving bad, but I've had my green car close to 140mph and it's on rails. I've built a bunch of the same setup as mine for guys on parallels and they drive very nice. I also want to do a transverse just to learn about them.
    Hombre, dana barlow and mad mikey like this.
  19. blacksheep55
    blacksheep55
    from jasper ga
    Thanks man, the aluminum motor I have is one that I've never seen before. Its an aluminum block, 4 bolt main, 4" bore, large journal, 2 piece rear main, steel sleeves. Its identical to any cast large journal small block, except aluminum. Has GM casting number in regular spot, but it starts with 0 which I have been told was common on experimental stuff. I've had a lot of guys look at it and none have ever seen one. It also has aluminum heads with the winters "snowflake" on them, which I've only seen on factory big block heads, never small block. It also has factory GM magnesium valve covers. They look like Z28/LT1 covers only magnesium. I got it from an old guy that had some ZL1 stuff, he said he bought it at a swap meet around 35 years ago.
    lothiandon1940, Deuces, clem and 6 others like this.
  20. chevy57dude
    chevy57dude
    That's a seriously rare piece. Unobtanium. Must be worth a LOT, Leno might want it.
  21. DDDenny
    Hell, I want it, but I already have an alloy motor.
    Any cast-in dates, block, heads, anywhere, please lord make it HAMB kosher.
    Man, this could be a whole nuther thread, hint, hint.
  22. DDDenny
    If you haven't seen this you might find it interesting.
    Discusses early aluminum and magnesium GM blocks.
    https://www.corvetteforum.com/forums/c1-and-c2-corvettes/2801916-magnesium-block.html
  23. Junior Stock
    Junior Stock
    That issue has a how to article on installing a transverse setup
    blacksheep55 likes this.
  24. mad mikey
    mad mikey
    That aluminum block is dangerous, give it to me and I will properly dispose of it. :D LOL. Anyway, you a so lucky to have that block. I would like to see some pics please.;)
    lothiandon1940 likes this.
  25. blacksheep55
    blacksheep55
    from jasper ga
    Here's a pic of my aluminum 302 I'm gonna put in it.
  26. blacksheep55
    blacksheep55
    from jasper ga
    The valve covers are GM and magnesium.
  27. DDDenny
    May I have more please!
    Definately gotta see more photos.
    Coolant temp sender boss in head, first year for that was 1968 production in the 291 steel heads. Do the mag valve covers have rocker arm oil drippers cast in them?
    Do the heads have the O.....casting number like the block number sequence starts?
    Heard the experimental possibility about that.
  28. Junior Stock
    Junior Stock
    Corvettes in the 80's had magnesium valve covers and were painted.
    Unkl Ian likes this.
  29. elgringo71
    elgringo71
    You are gathering up all of the right parts for this one. That aluminum 302 is unbelievable. I never knew that something like that was ever made. Your green 55 is top notch and I believe that this one will be even better. I am definitely following this thread
  30. enloe
    enloe
    from east , tn.
