Technical Chop or not ...36 3 window pontiac
Discussion in 'Traditional Customs' started by Dylan smith, Mar 5, 2018.
  1. Dylan smith
    Dylan smith
    Just bought this car any one out there done it ???i haven't been able to find much out there for this car .... for info it will be low and old school style ... if it's been done I would love to see some pics
  2. I would leave it uncut.
    Vic
    51 BIRD, Just Gary, 28Hud and 4 others like this.
  3. 392
    392
    No cut. No need too
    51 BIRD, 28Hud and 6inarow like this.
  4. nunattax
    nunattax
    id leave it alone.pretty car as it is.that windscreen looks [​IMG]
    51 BIRD, chryslerfan55, 28Hud and 2 others like this.
  5. nunattax
    nunattax
    uncut it looks chopped as it is.[​IMG]
  6. 'Mo
    'Mo
    I'm not a Chopaholic, but as a matter of opinion...chop it.
    I would, however, open up the windshield a bit (i.e., less chop) as done on the Matranga Merc.
    BigO, chryslerfan55 and Jalopy Joker like this.
  7. Blue One
    Blue One
    from Alberta
    Based on this one alone, I would not chop it.
    Posting a picture of an old build like that is pretty much the same as posting an old picture of yourself with a paisley shirt and big wide bell bottoms along with a 3' diameter afro :eek: :D:D:D
  8. Clay Belt
    Clay Belt
    If you chop, I would do a mild chop of only an inch or so. Personally, I wouldn't chop at all
    28Hud, 6inarow and dana barlow like this.
  9. Graystoke
    Graystoke
    I am on the NO CHOP list.
    chryslerfan55, 28Hud, 6inarow and 2 others like this.
  10. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Depends on the build style you're going with. IMHO, the only style it would look good chopped is an early tail dragger full Custom.
    Having said that, you should first do any structural floor, rocker metal work, align the doors. No fair doing the fun stuff first! You have to earn it by doing some of the ****py work. I've seen instances where guys have chopped a Model A body that was missing a floor, rockers and needed lower patches.
    Consider building the entire car out and driving it in shake down mode. Then decide if you want to chop it.
    Post a good side profile pic. Someone will photoshop it for you.
  11. Not everything needs to be chopped. A good California rake and fenders on that one and you're golden.
    6inarow, texasred, TagMan and 3 others like this.
  12. 'Mo
    'Mo
    If going mild, I can see an inch (or more) from the windshield, another inch (or more) from above the windshield,
    and an additional inch at the back, leaning the back light forward for some rearward taper. Though conservative, this would total 2-3" front (3-4" in back), and create quite a bit more flow to the profile.
  13. Jalopy Joker
    Jalopy Joker
    BigO likes this.
  14. Dylan smith
    Dylan smith
    Ya this is the look I'm shooting for
    chryslerfan55 and 'Mo like this.
  15. Dylan smith
    Dylan smith
    Great idea
  16. BJR
    BJR
    Finish everything else and get it on the road in primer, then make the chop decision. An awful lot of cars never get finished because they get hung on radical bodywork and never see the road.
  17. 34Phil
    34Phil
    You could cut door above beltline and move window bottom up to same level as windshield.
  18. rdscotty
    rdscotty
    from red deer
    Post a direct side profile on the photoshop thread & tell them exactly what you want to see. My biggest concern is flow. In the front 3/4 view you posted, the grille looks so tall and vertical that if you start making the rood lower & leaning the pillars that it might look odd & out of proportion. A good photoshop will let you see what it will look like.
    chryslerfan55, clem and trollst like this.
  19. adam401
    adam401
    If its gonna be a custom the side profile of that car is begging for a chop. Definately too tall for a custom. Id get the stance right first. For me it would probably be a small chop at the windshield, removing some of the crown above the windshield then cut the rest to flow. Ive chopped a few pick up cabs where decreasing the crown above the windshield really made the roof flow better than if I just chopped through the a pillar alone.
    Chevy Pontiacs Oldsmobiles, they're harder to make look right than say a 36 Ford. There's a lot of surface area on the sides of the car above the fenders and they have a big long nose. Super easy to **** the proportions up.
    You could also leave it stock roof height, build an early aircraft hydraulic setup for it and build it as a lowrider bomb. That's an awesome look for early GM stuff but maybe not on topic for this website? I dunno good luck.
    chryslerfan55 and Atwater Mike like this.
  20. 34Phil
    34Phil
  21. trollst
    trollst
    No chop, the hood is too long, car will look out of proportion, I think long body style cars look best with no chop, unless a ton of other body mods are done. Secondly, ask yourself why you want to chop it? If you have any experience with a cut windshield, you'd know they can be a real pain to drive.
    nunattax likes this.
  22. A Boner
    A Boner
    This X 1000
  23. COCONUTS
    COCONUTS
    If you are going to chopped it, might as well as channel also
    Dylan smith likes this.
  24. Hollywood-East
    Hollywood-East
    Definitely in the no/Chop camp, I like the chopped one in picture above, Except with out Chop is exactly what my first thought of your car, ****ies ride!
    chryslerfan55 and Dylan smith like this.
  25. Movinman
    Movinman
    That roofline with the side window larger than the front windshield is very similar to my 36 Packard. My roof has been chopped, and I think it looks great. packard.jpg
    BigO and chryslerfan55 like this.
  26. Squablow
    Squablow
    I think 34phil has the right idea. Take a look at the top picture, which is the one he posted, untouched. Then look at the bottom picture, which has absolutely no top chop whatsoever, all that was changed is the bottom of the door opening was raised to about the height of the bottom of the windshield opening. Not sure of scale but 2" or less. Look at the dramatic difference it made, with what would be a pretty easy straightforward body modification for anyone with good sheetmetal skills.
    Top chops look best when they bring good proportions to a car that has bad ones. The roof height on your '36 is in good proportion to the grille and the rest of the body, but the door window openings are not. This is what I'd do if I had that car.
  27. edcodesign
    edcodesign
    Your door fix nailed it !
  28. edcodesign
    edcodesign
    That sounds like a good fix.
  29. Erwin
    Erwin
    With you on that Matranga technique, 'Mo. A pillars lean back several degree and the lid dropped 3" max. Figure out lesser amount for windshield opening so final profile ends up reet . Thirty-six Pontiac in any model is few & far between, Neat coupe with or without the chop.
    chryslerfan55, 'Mo and nunattax like this.
  30. goatboy
    goatboy
    from kansas
    dad has the exact car in his garage, 54000 mi gonna get it someday, will leave mine be but think it would look ok chopped maybe 2" no more
    chryslerfan55, Dylan smith and 'Mo like this.
