Projects Finally My '26 Chevy Roadster Build
Discussion in 'Traditional Hot Rods' started by Six Ball, Jul 23, 2016.
  1. Stogy
    Stogy
    @Six Ball...I'm lurking, looking and enjoying your vision and p***ion...;)...quality takes time.
    Six Ball and 31chevymike like this.
  2. Six Ball
    Six Ball
    from Nevada
    Thanks Stogy, I need to make more progress than just moving your pictures to different posts. :D
    31chevymike and Stogy like this.
  3. Stogy
    Stogy
    Balance is good...;)...pat yourself on the back...your making progress and its not a job its a p***ion with no set deadlines. Good on you.
  4. Six Ball
    Six Ball
    from Nevada
    Well, there is a deadline. I'm closing in on 73 and I can see the tunnel at the end of the light. :rolleyes: :D
    Jet96, OFT, 31chevymike and 3 others like this.
  5. Stogy
    Stogy
    I am catching up and hope to be healthy and active as you are when I get there...Many more healthy years to you and may your 26 rumble under your ****ocks in the near future...;)
    cactus1, 31chevymike and Six Ball like this.
  6. Six Ball
    Six Ball
    from Nevada
    Better it than the rumbles there now! :eek:
    Jet96, cactus1, 31chevymike and 2 others like this.
  7. Stueeee
    Stueeee
    from Kent, UK
    I would go with the 24mm venturis first too. Some years ago, I was really surprised when we dynoed a car with Weber carbs, how little top end we lost going down by 3mm from the "recommended " venturis for that motor and state of tune. The real difference was in the midrange power and in the pickup/acceleration on the rolling road.
    Six Ball, Stogy and 31chevymike like this.
  8. carbking
    carbking
    Six Ball - while the adjustable main metering jets shown in your picture are highly desirable for SINGLE carb applications; they add several degrees of difficulty to dialing in a dual application.
    Jon.
  9. Six Ball
    Six Ball
    from Nevada
    Stueeee, Thanks. I really don't think I'll have to go that small but there isn't a choice between 29mm and the 24mm so the 24s and a pocket knife might be the deal.:confused: I have a pair of Webers in the drawer too.
    Jon, But they are just so cool. :( Nothing is easy for me with carbs. The more the messier. Actually I've used this type before on Chevy and GMC sixes. I've never tried to run a pair on an engine this small. If I can't get them to work there are other options. Thanks for the heads up.
  10. Six Ball
    Six Ball
    from Nevada
    I was able to weigh the flywheels this morning.
    12 3/4" 153 tooth that came with the 153 weighs 20 lbs. #366861N
    14" 168 tooth that will work with the adapter set up weighs 28 lbs. #3729004
    Both use the same 10 1/2" clutch.
    31chevymike and Tim like this.
  11. Crusty Chevy
    Crusty Chevy
    Any chance to run one carb as a dummy? I have 2 working on my 216 six and it will run well, better actually, with one blocked off and the idle screw opened up on the functioning carb.
  12. Austin kays
    Austin kays
    Tim and Six Ball like this.
  13. carbking
    carbking
    Six Ball - if you place sensors to a gas ****yzer in each exhaust port, you can make it work, but just adds several degrees of difficulty. Fixed jets are SO MUCH easier with a multiple set-up.
    Crusty - if the duals run better on one, something is very wrong! You will have a major cylinder imbalance. If you would like to discuss - 573-392-7378 (9-4 Mon-Tues central time).
    Jon.
  14. Six Ball
    Six Ball
    from Nevada
    crusty chevy, I agree with Jon. If it doesn't run better with two something isn't working right. Even bone stock 216s run better with two one barrels and dual exhaust if it's done right. one little thing can screw it up. I'm trying hard in this build to not have stuff that looks like other stuff. Thanks for offering you thoughts though this isn't all worked out yet and I know I'm not seeing it all.
    Austin, I don't know what your post is but thanks for checking in.
    Jon, The exhaust sensors makes sense and I could do that. I also have a set of very similar Zenith carbs with fixed main jets. They look the same otherwise. I'll have to check their model #. I know a lot of guys ran these 28/228s in "the day" and they were sought after but a lot has been learned since then. Thanks
    kidcampbell71, 31chevymike and Stogy like this.
  15. Tim
    Tim
    from KCMO
    @Six Ball Austin just wanted to make sure I saw your post because he knows I like the 153 stuff
  16. Six Ball
    Six Ball
    from Nevada
    That's great we need people looking out for us. There has to be something wrong with us spending all this time solving problems that could be fixed by simply bolting a 283-327 in the same hole. :rolleyes:
  17. Tim
    Tim
    from KCMO
    No ****. Lol
    That’s being said if your adapter uses the stock block mounted boss to mount the starter is there any reason you can’t use the 153 tooth fly wheel? Seems the switch to the other fly wheel is because the starter gets mounted to the adapter and moves it out further away necessitating the broader fly wheel to reach the starter?
    31chevymike, Six Ball and Stogy like this.
  18. Six Ball
    Six Ball
    from Nevada
    I could use the smaller flywheel but I'd have to butcher the power glide and aluminum adapters. I don't think the big flywheel will be a problem. A stock model A flywheel weighs 65 lbs and it takes a lot to get it to 53 lbs though they can go less. I'm sure 8 lbs more than than the stock 153 unit is not going hurt that much. Better off the line at stop lights maybe retain a little power on hills. It'll be OK. If not it won't be hard to change. It'll also give it a bit more of the older look with real Chevy parts I want.
    31chevymike likes this.
  19. Tim
    Tim
    from KCMO
    I only ask because I’ve mine bolted to a early ford trans using a speed gems sbc adapter and some of the adapters to do such a swap say they need the bigger flywheel. Just thought I’d pick Your brain a little
  20. Six Ball
    Six Ball
    from Nevada
    Jon, The other pair of carbs I have are Zenith 11480A. That is another 28/288 with fixed main jets. They use the same rebuild kit. I'm sure you know all this.
    I read a post of yours on the Stovebolt site that said:
    "The main venturi (this is the item that primarily controls air flow) of the 11275 is 30mm. The carburetor is rated 196 CFM.
    The main venturi of the 9439 is 28mm. The carburetor is rated 172 CFM."
    So it seems the 24mm venturies might be a place to start with this engine.
  21. carbking
    carbking
    Six Ball - when dealing with a four-cylinder, the CFM required REALLY depends on the design of the intake manifold, much more so than with a V-8. An IR design could require as much as 4 times the CFM required for a single carb using a plenum design
    Intake manifold design is NOT my field, however there is a gentleman that posts on some of the other forums (Stovebolt for sure), and I think here as well that goes by the username of "panic". His posts and articles on intake manifold design is WAY above my pay grade. I would certainly suggest asking his opinion.
    But looking at some "factory" data; O.M.C. used that 153 CID with dual Carter RBS carbs. The RBS carbs were horrible, but WERE low-profile, so desirable in a boat with a closed bilge. Anyway, the dual Carter RBS's used by O.M.C. had 32mm venturii.
    I am a firm believer that following the direction of the factory engineers is certainly a good starting point.
    Jon.
  22. Six Ball
    Six Ball
    from Nevada
    Yes, I am aware of panic. In fact he has responded to my questions on this on the Inliners International site. And no, I don't really understand his answers. He is far beyond my understanding. At this point I need to know what works I don't have to know why.
    Thanks for reminding me of the O.M.C. That is a good correlation the Zenith flows 195 CFM and the RBS 225. The single bbl 153 boat motor was rated at 120 hp and the dual carb was 130 hp. I thought I might need to go smaller I may have to go bigger. At least it will run with two of these and I can dial them in later. Thanks for your help.
  23. Since I'm not familiar at all with 4 cylinders, how do you plan to install your banger in the ch***is? What does a typical engine frame/mount look like anyway? Any photos to show?
  24. Six Ball
    Six Ball
    from Nevada
    Mine will have two front mounts and one from the rear of the transmission. The bell housing is the same as a small block and the front isn't too different. They were used in Chevy IIs along with 230 sixes and 283s. There are at least three threads here about these engines. Sadly a lot of the pictures are gone and some of the info is wrong. I wrote some of that. :eek: Here are some pictures I lifted from those treads.
  25. Appreciate these photos Six Ball - also wondering if your ch***is and the Model A's are similar in width in the engine bays. Are the height of the rails similar as well?
    Six Ball likes this.
  26. Six Ball
    Six Ball
    from Nevada
    I'll take some measurements and post them. I have an A frame I can measure too. The guy I bought the body from said that some of the mounting holes matched a '26-'27 T.
  27. Six Ball
    Six Ball
    from Nevada
    Well Mike I never got those measurements to you, Sorry. The Chevy and Ford frames are close. I'll try and get them for you. Another Year gone and not much progress. I've been fighting broken and worn out vehicles all summer and still need to get a 4X4 on the road before winter.
    Saturday I went to a swap meet at a friends shop. To me it is "Early Chevy 4 cylinder Heaven."The parts stash is overwhelming. When I go there the old Chevy bug bites me again. In fact I got a 1919-1922 Olds 3 port head and custom aluminum rockers. (for later) I also got the nicest, tightest, most complete early Chevy steering box and column with the nicest steering wheel I've ever seen. Today I bolted it into the frame. It was a missing link. I had planned on using another box because I never thought I'd find one like this. It will greatly help in locating the engine and firewall/cowl. Every thing on it works. I can even use the choke and horn ****on. I won't need the spark advance but maybe........? I got to see my friends Early Chevy dirt track racer that will be on the road soon. It has a 25 Chevy engine with an Olds head. Pure inspiration! Also some shame. :D
    100_0201.jpg 100_0202.jpg 100_0211.jpg 100_0199.jpg 100_0181.jpg 100_0197.jpg
    burl, brEad, GuyW and 9 others like this.
  28. Whoa! Good stuff!
  29. Stogy
    Stogy
    Quality takes time...and then there's the other stuff...and you bagged some great vintage goodies...and that is a nice Vintage hotrod of sorts isn't it throw on the goggles and find a nice winding country road...dreaming never ages...
    Six Ball, 31chevymike and volvobrynk like this.
  30. Six Ball
    Six Ball
    from Nevada
    Yeah, Thinking about so much. Headed out in the morning to meet my old boss from the 60s for breakfast. He ran a stage coach line in Columbia California and I robbed them. Best job I ever had! I learned more on that job than I did in school. After breakfast my wife and I are driving to Nevada City, CA to drop off my old Martin guitar to be repaired. It's older than me and I bought it with my stage coach money.
    On the way home Saturday I spotted a complete Chevy front axle, springs, and wheels in another friends yard. I knew it was there but forgot. I'm sure I can get it to use on the Es*** speedster. I saw a rear end at the swap Saturday. That would complete the major components for that build with all vintage parts. Once I have all the parts for every project imaginable I have to build something, right? We haven't even talked about the motorcycles yet. :eek:
