Technical Who made old Craftsman welders? Need parts.
Discussion in 'The Hokey Ass Message Board' started by zzford, Mar 8, 2018.
  1. zzford
    zzford
    I recently bought an Old Craftsman stick welder, a 225 Amp model. It has the fine adjustment dial on it and you move the stinger lead to set the co**** amperage. The stinger lead is missing the plug that goes into the machine. I can't find the original Sears unit, so I ordered a general replacement, but it's too loose in the receptacle. I did a search on the 'net but couldn't find much at all. Anybody got any ideas? Thanks.
  2. Terrible80
    Terrible80
    belair, Unkl Ian and Hnstray like this.
  3. scotts52
    scotts52
    Show us a picture of your welder.
  4. CrazyVern
    CrazyVern
    I believe Century (the battery charger company) made a lot of the older Craftsman welders
    dan c likes this.
  5. BJR
    BJR
    Get a br*** bushing for the stinger lead plug.
  6. Every stick welder I've ever seen used a 'standard' plug, although there are several sizes (and they aren't similar sizes). So if it's loose, it's worn out
  7. Joe woz
    Joe woz
    Crazy Vern is right, century made sears welders and I think Panasonic did too. Go to your local weld store they might help, sometimes a miller plug will work
    battman5615 likes this.
  8. carryallman
    carryallman
    as cheap as a new or used stick welder is ?i think id just replace it?????
  9. Joe woz
    Joe woz
    At least $500 bucks, but I would probably upgrade to a better brand if I could.
    Vanness likes this.
  10. zzford
    zzford
    I won't be using it much at all so it's not worth replacing it. The previous owner had just stripped the cable end then just shoved it in the receptacle. Even like that, it did a good job. But, I just can't do it that way.
  11. zzford
    zzford
    Sounds like the best plan.
  12. 56sedandelivery
    56sedandelivery
    The male "plug" is br***, and probably "split", right? If it's split, then shove a flat blade screwdriver into the split to spread it some (carefully !!!). I have an old Sears Craftsman buzz box welder I bought used from a friend for $75.00, about 42 years ago. It also came with a bunch of rod, mask/shield, gloves, chipping hammer, and a Mickie Mouse dryer plug arrangement. Tossed the dryer plug, got the right plug, and made up a 50 foot extension cord. The welder still looks new, and gets used every couple of years or so. It's probably one of the best deals/tools I've ever bought. Or does yours have multiple "female" receptacles for different settings? I am Butch/56sedandelivery.
    zzford likes this.
  13. robracer1
    robracer1
    Try this if you haven't all ready, I worked at a Sears home store in AZ for some friends so I could live there for the winter in warm weather temps, a lot of customs would come in with some really old equipment and by going into sears website under tools parts and putting in the part/model # I was amazed that I found a lot of parts that they still carried and some of the parts I could order. Might be worth a try good luck
  14. do you have the model number? the first 3 digits indicates the manufacturer
  15. SEEKONK JIM
    SEEKONK JIM
    i have one i got in the 60s...it looks like a lincoln....same color..front panel...ckeck with them....
  16. zzford
    zzford
    My cable didn't have any plug on it at all. The one I bought is solid br***. I made a sleeve out of light br*** tubing and soldered it over the plug. It works, but I would rather do something more "factory". Thanks though for your suggestion.
  17. zzford
    zzford
  18. zzford
    zzford
    Thank you all for your replies! Hopefully I can this old gal back in shape. I used to have a Lincoln tombstone years ago and a Miller 210 mig. But my health was failing fast, and it looked like I wasn't gonna make it. So, I sold off almost all my garage stuff so it wouldn't be a burden to my wife. But, I recovered nicely (thank you Lord) and that left me tool poor. I can't do what I used to, but I can do a lot more than if I was dead. :) Thanks again.
  19. zzford
    zzford
    OK. I got a photo. I cannot find a serial number anywhere. The machine is pretty banged up so it might have gotten knocked off it.
    GuyW likes this.
  20. H380
    H380
    from Louisiana
    I have an old John Deere made by Century in the 70s-80s I think. Get a pair of calipers and measure the male plug. There are a lot of different ones. some only .012" different. This place had Lenco the connectors I needed for $7.25 EA. Just click "More Info" for the drawings. You can find something that will fit your machine. Or you can change everything out to a modern connector.
    https://weldingsupply.com/cgi-bin/einstein.pl?PNUM::1:UNDEF:OR:05270
  21. Fordors
    Fordors
  22. 56sedandelivery
    56sedandelivery
    Check with E-Bay, they have all kinds of used Craftsman welding equipment listed; might have the same model. I am Butch/56sedandelivery.
    WOW !!! The HAMB has come through, once again. I'm always amazed what this group of guys can do.
    HunterYJ and zzford like this.
  23. zzford
    zzford
    THANK YOU !!! You guys ROCK!
    Thanks Fordors. I ordered my parts last night. Thanks to all for all your help.
