Projects 1956 Pontiac "old injun" gasser project
Discussion in 'The Hokey Ass Message Board' started by D-man313, Feb 1, 2018.
  1. 55chieftain
    55chieftain
    I bet loosing the hydro trans you lost 100 lbs lol
    D-man313 and loudbang like this.
  2. D-man313
    D-man313
    Going with aluminum heads, ditching the front bumper, and that big hydro has shed quite a few pounds
    55chieftain, loudbang and enloe like this.
  3. enloe
    enloe
    from east , tn.
  4. saltflats
    saltflats
    from Missouri
    If it is the exhaust crossover that causes this I would be shutting that up at the port.
    You wont need that racing.
  5. D-man313
    D-man313
    Does anyone know of a company that's making a ****ter shield for a early 59-60 Pontiac block? Everything I'm finding is for 64 and newer. I can't be the only guy to ever put a 4 speed behind an early block and want a ****ter shield.
  6. wvenfield
    wvenfield
    There was a thread last year where someone was looking for a ****tershield for a 59 and I don't think anyone came up with an answer for them.
  7. D-man313
    D-man313
    Bowtie Coupe and loudbang like this.
  8. squirrel
    Give the company a call, to confirm, eh? It says it also fits the modern BOP engines, so if your engine is different from the modern BOP engines, it's not likely to work, is it?
    Bowtie Coupe likes this.
  9. squirrel
  10. D-man313
    D-man313
    Going to call them tomorrow.
  11. D-man313
    D-man313
    And mainly I'm concerned with my safety as well as everyone else's. If something comes apart I don't want it flying around. I don't plan on running fast enough to require this sfi housing but it's safe.
    Bowtie Coupe, loudbang and enloe like this.
  12. Bowtie Coupe and loudbang like this.
  13. Torkwrench
    Torkwrench
    I was running into the same problem with my early Caddy V8......A 1954 331 with an extended bell housing.
    Perhaps the solution is to use the trans adapter along with either a BOP or Chevy bolt pattern ****ter shield. This is what my plan is. However, in my case I had to get a 1955 - 1962 Caddy V8, to eliminate the earlier Caddy block's extended bell housing. Ended up with a 1962 390 V8.
    Bowtie Coupe, squirrel and loudbang like this.
  14. bchctybob
    bchctybob
    I read somewhere that QuickTime will make a ****tershield for uncommon applications. Or you could borrow a later Pontiac bellhousing and see just how much different they are. If the dowel pins are in the same place relative to the crank centerline you could maybe modify a later model ****tershield to fit or make 3/8" thick steel adapter plate.
  15. D-man313
    D-man313
    I read the nhra rules again tonight about ****ter shields. I was unaware that they would allow a homemade 1/4" think 360 degree ****ter shield. I was looking into making one after finding nothing that would fit my application. Wasn't aware that they'd p*** it till tonight. I have just the piece of steel for it in the garage to.
    brEad, Bowtie Coupe and loudbang like this.
  16. That was my next post, after you came up empty.
    Use a SEMA approved flywheel and clutch and a homemade shield.
    I know you can handle it, plus it's traditional:D
    squirrel, Bowtie Coupe and loudbang like this.
  17. D-man313
    D-man313
  18. D-man313
    D-man313
    Picked up the cage kit this morning we'll see if it fits! Have some other stuff to do before we get started on the install.
  19. D-man313
    D-man313
    I think I forgot to mention i dropped the motor off last weekend at the machine shop.
  20. enloe
    enloe
    from east , tn.
    I will be looking forward to seeing this car in June...
    loudbang and D-man313 like this.
  21. choptop40
    choptop40
    Garlits learned the hard way...trans blanket...an option still?
  22. D-man313
    D-man313
    Yes I'm planning on building a shield out of some 3/8" plate I have. As well as shielding the trans also inside the tunnel.
    loudbang, Bowtie Coupe and enloe like this.
  23. All good.
    You mentioned aluminum heads. Kaufmann? E-head? I think you'll find the headers will need re-working at the ports.
    Also, what's your plan for the reverse cooling set up?
    Probably going to need std. bore 400 forged TRW, minimum.
    loudbang, 48fordnut and Bowtie Coupe like this.
  24. D-man313
    D-man313
    Kauffman makes aluminum D-ports. I have a front cover that will work with the new heads.
    loudbang and Bowtie Coupe like this.
  25. I know he does. Won't take too much but will still need reshaping, depending on what they look like now, of course.
  26. D-man313
    D-man313
    We made the cut for dragweek again this year. Now we have to keep thrashing on the car!
  27. D-man313
    D-man313
    Ordered the rotating ***embly for motor today! I'm getting excited now.
  28. D-man313
    D-man313
    Made some templates up for the tinwork tonight. Going to cut the bad spots out of the floor this week, and probably start on putting the cage it this weekend.
  29. enloe
    enloe
    from east , tn.
  30. quick85
    quick85
